Everything posted by JohnCh
Congratulations Hank! Sounds like you are off to a great start. If you are looking for inspiration, this site lists about 50 Westfield-related sites, many of which have detailed build logs. Very good resource. Kitcat, there is at least one other Magabusa in the States. Dennis Palatov, of dp1 fame, built one several years ago (build blog here). Last I heard it was in the San Diego area, but not sure where it is now. -John
I had some made as well. I heard from a several people who had used oversized wind wings and swore by their effectiveness, so I made several mockups out of cardboard (and later MDF) to experiment with size and shape. I finally settled on the combo that reduced the buffeting the most and then took the template to a local plastics shop that made a pair out of Lexan. They attach to the stock sidescreen mounts on the windscreen pillar using a spare set of sidescreen hinges I had lying around. They work extremely well. Although not as effective as sidescreens, they make the cockpit comfortable at very high speeds, yet they allow enough air movement that the cockpit doesn’t overheat at lower speeds on warm days. There is a little more information and pictures at the bottom of this page. -John
Typical Mazda. Never missing an opportunity to up his post count :jester: -John
Hi John, Nothing wrong with a Crossflow (Kent). I used to have one and although they may not make a ton of power, they still have enough to be entertaining, and no 4-banger sounds better. A Westfield very similar to the one you describe just sold a couple of weeks ago for (I believe) $14k. The ad is here. I can put you in touch with the seller if you like. Ian7 brings up a great point about 45DCOEs and the Kent 244 cam. Are you sure those are the right parts? All the Yarwood cars I've heard about have the Kent 234 and 40DCOEs, which is a very tractable combo. -John
I would go with the shorter 1st gear as well. The 1828rpm drop is still pretty damn short. Another gear calculator to check out is on this page. It enables you to perform an A-B comparison and will also calculate optimal shift points if you enter torque data from a dyno sheet. My Motogadget tach/speedo also has a gear display that is calculated from road and engine speed. It works great with a normal gearbox, but with a sequential it would be nice to have a sensor on the gearbox. Without it I imagine it could be a little confusing when approaching a stop light with the clutch disengaged. “Did I just down shift 4 times to first, or 3 times to 2nd?” -John
That's why I have one on the Westfield I'd rather annoy the brain dead, cell phone talking, latte sipping SUV driver -- and we have a lot of those where I live -- than have him run over me because he didn't notice that funny looking little car ahead had stopped. -John
I have a similar device from Cadent Technologies and agree that it is very effective. Previously when someone was following me really closely to get a better look at the car, I would have to tap the brakes 3 or 4 times before they clued in and backed off. Now I rarely have to tap the brakes more than once. It certainly seems to get people's attention. -John
That cockpit looks downright luxurious! My tintop isn't that nice -John
I agree. I haven’t seen the S1 in person, but I have gone over a Superformance Cobra pretty closely. The workmanship and attention to detail on that car were very impressive. Tom, any pictures of the interior? -John
True, but Mazda gearboxes are a little bulky, so depending on the car, the 6-speed may not fit without chassis modifications. The 1st gear in that gearbox is also really short. At 3.815 it is even shorter than a stock Type-9 1st gear (3.65) which, speaking from personal experience, is absolutely useless with a Duratec. They do shift great though. -John
I’m curious about the 170hp spec Duratec. It isn’t shown on the UK site. I wonder if that is a US-only engine, or if the website announcement revealed a little more information that CC UK intended? -John
Still looking for a cheap side view mirror fix
JohnCh replied to DB6's topic in General Sevens Discussion
I follow your art just fine. Great idea! I'd love some of the Delrin bushings if you have enough left over for a pair of SPAs. I'll send you a PM. Thanks, John -
Sorry to hijack the thread, but I'm interested in learning more about this mod. How did you do this? Thanks, John -
I carry this with a few extra CO2 cartridges. Saves over 30lb. from the rear of the car and supposedly work pretty well. I haven't had to use it yet, but hopefully it is enough to get me to a gas station. -John
Do a search on WSCC for Mickmade. His parts are highly regarded and reasonably priced. Mick, I didn't realize you are selling to the States now. I need to chat with you about a dash for my Westfield -John
Winter is also known as Upgrade Season. If you can’t drive your car, then you can at least throw away piles of money in an attempt to make it better. -John
What Al said! It looks like a lot of new pavement has been laid down this summer. How are the roads? 107 degrees?? I bet you wish you still had your 1/2 hood yesterday Today is the run down to the sea, so the temps should be much cooler. Looking forward to seeing the next round of photos. -John
Drats...Starter advice/ID. needed..(birkin-ford question)
JohnCh replied to southwind25's topic in General Tech
Do you still have the Lucas inertia starter (see picture below)? If so, pull it (should be really easy if it is like the setup in my old crossflow-powered Westfield) and see of the spring on the shaft has broken. This happened to me and produced a similar sound. I replaced it with a gear reduction starter from Dave Bean Engineering. Much lighter and worked great. http://www.pegasusautoracing.com/Images/L/1140.JPG -John -
Back on topic: I believe 11Budlite lives in Wolcott. If you are nearby, then it might worth a PM to see if you can get together and see his car in the flesh. Back off topic : I didn't realize Scott also has a 951. I must admit that I am a bit surprised there are 4 of us on the forum. Are any others going to crawl out of the woodwork? -John
Welcome CJ! I also have a 944 turbo and can empathize with the upcoming clutch job. For those that don't know, Porsche decided that clutch replacement would also be a good time to take most of the car apart for a thorough inspection. Depending on the year, the book rate is either 16 or 20 hours. :banghead: If you have the skill and equipment, then I think the Locust is a great project. People are doing some very interesting things out there, and you'll find a lot of support on the USA Locust forum that Mazda mentioned as well as LocustBuilders in the UK. Regarding registration, where in New England are you located? Odds are someone here is also from your state and can weigh in with their experiences. -John
I had the pleasure of briefly meeting him at the local vintage races a few years ago. I’m not one for autographs, but couldn’t pass up the opportunity to have our picture taken with him. Very, very nice guy. Saw him walking around the paddock later that day, and was struck by the fact he never stopped smiling, and was happy to have a word with anyone who approached to say hello. A class act, and a great driver. -John
I have a Safecraft 2.5lb halon fire extinguisher and had to use it once. The fact that I had an extinguisher in the car saved me from certain disaster, and the thanks to the halon, there was no additional damage to anything else under the bonnet. As for mounting location, I initially mounted it to a bracket attached to the front of the passenger seat, but SWMBO didn’t like it there because it made it harder to get in/out of the car. I then moved it to the rear bulkhead between the seats. One of these days I need to replace the stock flimsy mounting bracket with a billet unit that is more up to the task of keeping it in place in an accident. -John
I recently switched from the Toyo T1-S to the R-888. The biggest surprise for me was that they grip better in cold temperatures (mid-upper 40’s) even before they get any heat into them than the T1-S in the same conditions. Prior to the T1-S I had AO32Rs and those did not stick well at all when the temps dropped. Given that I use the car all year round, good cold temp grip is important to me. Regarding noise, the R888 certainly isn’t quiet, but it’s fine in a se7en where the other noises drown it out to a faint whine. -John
We’ll have a spread. Expect low-mid 90’s on the hottest days, and mid 60’s when you hit the coast. I suggest wearing layers I heard on the radio earlier this week that the average August in Seattle has 3 days of rain. This August, it appears we are on track for 9 days of the wet stuff. :banghead: -John
Toronto, Canada member looking for a rep. 7 (street legal) for sale.
JohnCh replied to sevenseeker's topic in Cars For Sale
Looks like a great car, but is priced accordingly. From the ad: "I will be only too pleased to answer any qiestions [sic] once the bidding has exceeded $50,000.00 " -John
