Everything posted by JohnCh
Would like some advice about selling a Caterham
JohnCh replied to Saudio's topic in General Sevens Discussion
Thanks @Saudio, I've restored the images in your initial post. When you are ready to list it, please create an ad in the cars for sale forum. -
Note: the pictures were removed as that addition steered this thread too far into ad territory even if that was not the intent. It's not fair to those who join as paid club members to sell their cars. Conversation around the sales strategy is fine, but please stay away from specifics about this car or the sales price. -
I believe that gauge has three wires at the plug: signal, 12v+, and ground. If that's the case, I'd make sure the ground and power are working and that there is continuity to the green/black wire at the sender plug. I have seen a bad oil pressure gauge on a new kit, so don't assume it's not the gauge. Have you asked Bruce if he has one you could swap in as a test?
Work got in the way, and I accidentally hit submit before I had finished my post above or corrected a confusing portion When I wrote "back probe the plug", that was poor word choice on my part. Pull the plug off the fuel assembly and put the multimeter on those two inner prongs on the male end of the plug. I just tested the one I removed from my car and it ranges from 53 ohms empty to 462 ohms full. Keep in mind that's the range in bench testing, not the range it can reach in the confines of the tank. If you do need to pull the fuel assembly out of the tank for further checking, I can recommend this removal tool: https://www.amazon.com/gp/product/B0079GPYA4/ Let me know if you need me to take any other measurements. -John
You could back probe the plug on the top of the fuel assembly. The two thinner inner wires are for the sender (the thicker outer wires are for the pump): Green/black handles the signal and black is ground.
@Donnie, I suspect you may have SV seats which are a little wider than the S3 seats. It might be helpful to post some width measurements and hopefully someone with those seats in either an S3 or SV can confirm which you are selling.
We have a 3D printing forum with a grand total of three threads. https://usa7s.net/ips/forum/43-3d-printing/ If people want to start posting their designs there, I'm happy to create a section in the library and start moving them over once we get critical mass, but I don't want to create a new section to hold just two or three designs. As for file type, it's not an issue for downloads. STL is the standard for 3D printing, but the common slicers can also use STEP files which store more data and are better for things other than 3D printing.
According to the admin panel, you don't have email notifications turned on, just the notification list (bell at the top of the screen). See the help guide below on changing those settings. Also, it's a good idea to check the email address you have associated with your account to confirm it's still current (https://usa7s.net/ips/settings/). If you are receiving notification list reminders for everything except your own threads, let me know and I'll do a forced reset from the admin panel.
This will keep you busy In my opinion, the LSD is well worth it. Adding one to the Westfield years ago was transformative. The car became so much easier to steer with the throttle and really ratcheted up the fun-to-drive factor. As for the Elan, yes get that in a better state and drive it! It's a great complement to the Seven, although my rust fears prevent me from driving it in the wet despite the vastly superior weather protection of the FHC design.
We had a couple of threads on this same announcement, so I merged them together to keep the conversation in one place.
That's great to hear @wdb! Is there any other work you plan to do over the winter or are you now sitting back and counting down the days to blatting weather?
This surprises me. I didn't think US and UK sales figures were close enough to warrant an equal split. I wonder if US dealers have been pushing for this model and Caterham sees pent up demand?
Been there, done that, have the blood blisters
Also, if you have a detachable wheel, make sure it is secure.
If this was sudden, as if something moved, check that both ends of the steering U-joint are tight. The quality of mine wasn't great and without a lot of clamping force, I can see it slipping. Other than that, check torque on everything in the front end.
Great idea! I've become a big fan of rare earth magnets over the past year and have used them in various projects but hadn't thought about this. Are you sourcing from Amazon or do you order from somewhere with better and more consistent quality? If so, please share
Westfield used to fit this extension, and I had one on my car until I installed the BGH gearbox. If you do source one, you may want to read this thread which touches on some aspects of the installation process: https://forum.wscc.co.uk/forum/topic/146517-gearlever-extension-type-9-fitting
That looks like a great solution for folks on both sides of the pond.
Too bad the easiest one isn't the issue. It could also be a duff gauge. If Bruce has one on hand, that's easy to swap out and check. During my build another local owner had a bad oil pressure gauge that he confirmed by borrowing my unused gauge.
A few things come immediately to mind. The first two are quick and easy. Due to the design, the fuel level sensor can't access the last 1.5-2 gallons in the tank. How much fuel have you added? Have you reached under the dash to confirm the gauge is plugged into the harness and the connector is fully seated? If the fuel assembly is incorrectly clocked in the tank, it can prevent the float from reaching the last several gallons in the tank. Checking this requires removing the boot floor which can be maddening. There could be a break in one of the wires or the sensor is dead. This also requires removing the boot floor, then pulling out the multimeter to diagnose.
Martin Phipps is the Caterham archivist and may be able to help. I don't like publicly posting someone's PII without their permission, but if you go to the post below, he lists his email address there. I'm not sure if his help extends to non C&L7C members, but never hurts to ask: https://www.caterhamlotus7.club/forums/topic/274739-1983-caterham-bdr-cosworth-engine-nr-bdr001/?do=findComment&comment=2604188 -John
Not sure what is meant by this, a link is fine; however, everyone should be aware that this is for Caterham & Lotus Seven Club members only. Current membership price for US and Canada is 70 GBP annually (about $90 and 125 CAD respectively).
Are the heater fan and wiper switches physically the same? They are both off-on-on, but the wiper wiring also has to account for the wiper park mechanism when switched off. I think it may have an extra pin or have the pins wired differently. Hopefully someone can confirm or tell me I am wrong as per the norm.
I have been told there is no standard assembly process at the factory. Each builder is free to follow their inner voice and assemble the car in the order and way they prefer. I suspect this same philosophy applies to the people who pack the crates. Some must prefer to include the wrong parts, or duplicate part, or save some parts the trauma of shipment altogether and leave them on a shelf at the factory.
