NSXguy
1 Follower
    CT
    1984 Caterham 7 - s3
7,010 profile views
  1. Sure, I would be down for this.
  2. i'll share photos of mine tomorrow. It's been so long i don't even remember what mine looks like with the spare tire holder. Have never needed it.
  3. you'll do just fine with R888 on the street, even with spirited driving.
  4. We'll be there... NSXguy + Mrs_NSXguy + kiddo
  5. I believe I have a set in my stash. Will PM with confirmation
  6. Nice meeting you as well! Pleasant surprise to have 3 se7ens in attendance.
  7. Make sure your choke "pull" mechanism (pre carbs, in the cabin) isnt sticking. i can't see the choke mechanism in the units requiring a significant effort to activate unless maybe they have gotten gummed up from sitting; in which case, they can be removed and thoroughly cleaned. Once way to trouble shoot is to isolate variables; I would remove the cable entirely and actuate the choke mechanism on each individual carburetor. If one or both are tight, then sort the offending choke. if they both move freely, then the culprit is elsewhere; either in the routing or mounting of the cable. The chokes should work properly with the return spring mechanim installed so I would not consider removal a satisfactory permanent solution. -Dez.
  8. If you can share photos of the car/engine and we can probably be more helpful. If S.A built, it may have an AX block installed which is the best(read -strongest) for tuning/upgrade purposes. It sounds like it is running wasted spark ignition which is nice as you can achieve a tailored ignition curve and thus better performance than the standard distributor based setup. Twin 40s, 32mm venturis and 4 to 1 collectors hitns at an engine that is built to rev. You'll likely(possibly) find that it has an upgraded camshaft and double valve springs as well. -Dez
  9. I may be interested in this for my classic 7. Will PM.
  10. From this past weekend. First proper blat of 2026.
  11. Geez fellas ... there's a time and there's a place for banter. This is neither!! Forum etiquette...
  12. -As title states, I am offering for sale, 5- 14x6" panasport wheels (1 was the spare). 4 are mounted on Falken tires and the spare is mounted on older yokohama tires that are aged out. The falkens have roughly 1500 miles and 2 outings on track. Wheels are in great shape and tires Plently of life left on them. -These wheels are for the earlier 7's with the ital/marina pcd; will also fit triumphs. - Prefer not to deal with shipping if possible. Some older photos of the wheels mounted-
  13. Awesome, she looks soo good. ARI did the heavy lift, now you get to do the fine tuning! I would recommend you have a wideband o2 sensor bung added to your exhaust after your merge collector. This will help with the next step of optimizing AFRs. (you can do it other ways, but this is my personal preference even if just to use during tuning) 1-Based on your engine spec, if you wanted improved idle performance and driveability at low loads, you can choke down at the expense of performance at higher loads but i agree with above that 28mm is too small and likely causing overly rich running condition (depending on current jetting, especially when cruising). Mine is close to 1700cc and i run with 32mm chokes (have run as high as 34mm on track) but also have aggressive cams- its a balancing act with carbs. I would expect ARI set the floats to spec for DCOE 151s which are the carbs you have. Having the floats set differently will also affect your final jetting and performance as well. Based on what i see in the photos, the 4-1 exhaust and short trumpets on the DCOEs, the engine is likely setup to breathe and perform up top, so you'll want at least 32 if you want it to perform as designed, but it will also run choked down to 30s as already mentioned with the appropriate jetting. 2-Based on your engine spec, your timing may need to be tweaked as well (so it's nice that you already have the 123 ignition module installed). Even if your engine was standard spec, you can optimize the advance curve for better performance. Curious, di you get the bluetooth or the USB version of the dizzy? i have the bluetooth version for the 7 and find it really convenient for tweaking on the fly as opposed to the USB version i haven in the renault. You can post your current settings and jets (idle, mains/air corr. , accel pump, mixture turns, ignition, fuel pressure etc) and we can help/advise from there as you get on with the tuning or message me offline if your like.
