Zona
Banned
  1. These carbon-fiber stiffener slats are waterproof or not? because these can be stitched for better water proofing.
  2. I don't think you need to remove the plate, it can easily found out if you give some more attention.
  3. These flash switch are always create the problem for me, how you fix them?
  4. You did the rebuild and upgrade to the engine really great, what about the chassis brace can you fix it.
  5. It's depend upon the bolt size and torque fixing. If you manage them properly so it will be the best solution.
  6. You have done the tremendous job, fixing it properly is really a big issue for me.
  7. I totally agreed with you, if this really worthy or not? You have spend so much money and time on this project.
  8. Zona
    Ground issues?
    I think you should prefer fixing your wire straight to the battery and make it run, that's it.
  9. I think penetrating oil will help you to fix these metal parts. Try this and please let us know is it help.
  10. The problem is you didn't fix the idle mixture properly so it will need to fix and correctly adjusted. Make sure to tighten the top nut it will help in proper balance of carbs.
  11. You can see the correct fixing image upward here, just make sure you fix the same way. It will solve your problem very easily.
  12. Really you didn't finish this project yet? please update us about your recent work.
  13. You got the great project to do, but it need time and money too. Just have some patience it gonna pay you more than you demand.
  14. That's really a powerful engine, but my question is who is the lucky one guy who is going to drive this monster machine?
  15. That's really exciting sale, i'm very interested. Is it available now or somebody here can tell me when this these offers are going to available again?
