The Best Weekend Whip | Caterham 360S SV Review
Caterham 620R & Porsche 911 GT3 RS 4.0 (997.2): the best track car of the last 25 years
Vovchandr replied to Croc's topic in Cars For Sale
In this market almost nothing surprises me anymore. As a matter a fact I'm more surprised by something being cheap than something overpriced selling. This was a surprise for example clean, low miles (53k) with a hardtop That Goblin seems fair -
Started the car yesterday with all new ignition parts and now no catalytic converter. Still hard to start, still sounds like it fumbles around. Big backfire pop a few times upon startup now from intake ITB runners and or exhaust. Scared me a few times. Made progress on datalogging and got my first recorded dummy test log! @catsv7 Now have to figure out how to wire in the wideband to be added to logs and I might be in good shape soon for this. Since the battery for ancient laptop is NA, I got a small power inverter from Ridgid that works to power laptop on the move quite well! In meantime I'm leaking oil from both ends of the mechanical oil pressure gauge and will have to address that after cleaning up the spill on the driveway... I think the compression fittings have to go a lot tighter than I've tightened them to. On the pressure side of things, my pressure is about at 6 bars cold and about 3.5 warm which I'm happy with seeing as thats close to normal.
Specialty 7 Key fob availability
Vovchandr replied to Vovchandr's topic in General Sevens Discussion
June bump -
June bump
You're quite a lurker! Thank you for the input. Cams are unchanged but I figured between using tools on the caps and one of them having a mechanical failure in the alignment tab some metal could have been made there. My Accusump grendaded on the track too with failed threads but I don't think it was steel. Bearings are likely an issue regardless. Filter is still in place and I can take a look at it. I bypassed the external filter and my front oil cooler for now and just put a regular filter on the motor in meantime. I can take a look at the filter at some point. Yes 5w30. I assume you're in the industry?
After years of accumulating parts, some of them are finally getting mounted Lower headlights (god what a horrible job. It would be easier to buy a newer 7 ๐) CF pods CF headlight buckets New Led blinkers CF Westermann Aero CF nosecone aero CF Westermann CSR fenders Still figuring out some mounting Also got to utilize econoseal plugs and tools and learn how to use them and used my aluminum (stupid expensive) anodized headlight through bolt hardware for the buckets. Reused the LED light but now it's semi permanently attached to the CF headlight ring with Sikaflex as I couldn't figure out an alternative good mounting method. The ring is attached to the bucket with double sided tape for now and the headlight cover..
ABC Fire extinguisher "corrosive problem" with aluminum
Vovchandr replied to Vovchandr's topic in General Tech
Very good breakdown and useful info. What's your opinion on Element extinguishers? First Alert Fesa5 isn't "A" rated I assume? -
General Zetec powered Caterhams/7's discussion
Here is a detailed one for the SVT blue one labeled as "Doug" (2nd down on the list) Very similar to the other one posted above Zetec SVT Engine with Jenvey throttle bodies. 176hp at wheels -
Came across this graph on old California Dyno thread Very interesting to see a bunch of different Zetecs (and 2 Duratecs, 1 being a 2.3) layed against one another with different setups. Picture was very low resolution so I did the best I could with deciphering it. All but a few like the yllow one are very close to each other. Yellow being a stock ZX3 motor with no ITB's or Cams. The difference is pretty clear. This is a detailed map for the orange "MoPho" one above. About 170hp -
Element got back to me "Thank you for taking the time to contact us. The extinguishing agent your friend is referring to is Halon/Halotron which is considered to be a 100% clean extinguishing agent. In an aviation setting, an ABC extinguisher should indeed be avoided since it produces a highly corrosive powder that is almost impossible to remove entirely, is very damaging to metal alloys and electronics, and which can cause terminal damage if it gets into an engine. We are European vintage car guys here and one of the main reasons we got involved with this product is because we wanted an alternative to the ABC extinguishers that are commonly in use in the classic car world. The majority of fires that can be tackled by a car owner are small and an ABC extinguisher, most of the time, ends up doing much more damage than the fire itself. Our extinguisher utilizes a โcleanโ extinguishing chemistry that leaves virtually no secondary residue. A light blast with compressed air is normally sufficient to remove anything that remains after a fire is out. Hope this addresses your concerns." Good info -
Full disclosure. The particles could very likely be from my Accusump grenadining on the track day or the head gasket change/poking around with metal on cams and/or crack in the cam alignment tab when I left the alignment bar on but kept turning motor... I don't expect them to be high next round.
makes you feel all warm and fuzzy
Also Blackstone lab report some of you guys are geeky enough to be interested in this High iron use. Silicon could be from the headgasket change/valve cover silicon on corners of gasket. .
Thank you. I never liked the stock assembly look on the US cars and my original pod housing cracked so replacement was in order either way. Even the circuit board bulb housing on original is tied to the smaller housing and doesn't make an easy/weather proof transplant to the UK sizes lenses. I think at this moment I'll wire this up without a DRL option just to put everything back together and revisit this in the future with the suggestions listed above. Why do you find bulbs better than pop in LEDs? I've already swapped the electronic flasher as I recall because I have JAL tails. Thanks for advice on diode/resistor assembly.
That does seem useful and relevant! Thank you
Fun fact behind that is that we are used to our view of ourselves in the mirror so this makes selfie images more tolerable to our monkey brains. "real images" look uncanny. Double fun fact. Things like WebEx mirror the camera for your picture on your screen by default but sends "true" unmirrored image to everybody else seeing you.
Alright the more I look into it, the more I find that almost all LED are two wire. Am I missing something here? Can a two wire LED be wired to be a DRL with a constant 12v and he a repeater with a turn signal input?
I figured it out. I need a 3 wire LED front turn signal to make this work properly. I connected back the old 3 wire bulb and it works as expected.
Cat ๐บ is going bye bye this week. I think it's clogged worse than I even thought. The engine is struggling to crank over with the exhaust on while I'm trying to troubleshoot it and compression test it.
Thanks. I'll look into that. Prepping all the carbon bits for Sika flex with Sika primer. CSR fenders, wishbones aero, CF headlight buckets rings. Couldn't figure out any good way to secure headlights in the CF bucket rings so just going to Sika them in there. Should work.
