7Westfield
    Lincoln NE
    Westfield 7 pre-lit
  1. I couldn't find a diagram of the steering column in an S2, but if it's like my Westfield, you'll have difficulties. The wheel is too close to the dash for any QD adapter I've used. And, there's a flange welded to the end, that the wheel bolts onto, which would need to be cut off, and the wheel will end up closer to you. If I were doing it, I'd certainly fab a new shaft to mount the QD on, and not muck up the original check the ID of the QD, you might have to sleeve it to fit the shaft
  2. FWIW you can get valve covers without a hole/cap Burton has them pricey Dave Bean or Ivey ??
  3. this is similar to the can I used on mine mount it as high as possible https://www.ebay.com/itm/286815733808?_skw=oil+catch+can&itmmeta=01M0DPEJP41N0H19G0E1EH6CAT&hash=item42c78cc830:g:9LcAAOSwQuFkEXpI&itmprp=enc%3AAQALAAAA0GfYFPkwiKCW4ZNSs2u11xDvAUbi4%2FCnjDXpZqkVb1vQelnDIxAnNV%2BwJKZvcVbLyVoySB96KTaDMxkd8rQwn%2Fzabj%2B56mc8DNsyef%2FC22q5CTCr0lkgAJ86DmVfVNX85TEJxY2raRpAHUkrLLeecOUUr18N%2F7BJeaIU00RWnOoQLId%2BIvczoabQmBiJKRgCaJtuzuSuUIiqnTOpHihUMWfzNIoqMleUKQJ87lyvab4s%2FLfB1Lk6aI1xi%2BCnF6FFRRVq83CqO0Vlq1CtgW18qWM%3D|tkp%3ABlBMUMqruraDaA
  4. go for it that's how mine is vented, and also most of the Formula Fords in the world it's probably 1/2" npt or maybe 3/8
  5. Handbrake on Westfield was mounted on side of tunnel, dug into my thigh I switched to electric, with a fleabay linear accuator Too slow for "emergency" but fine for "parking"
  6. Barely... I took a silver Menards tarp. backed it with some cloth upholstery fabric I had on hand. and added loops for ratchet straps Def not pretty. but it's only for trailering, and I avoided installing any snaps
  7. Agreed I dug out my tonneau a couple of weeks ago, and checked it's fit----or lack thereof mind you, this is 40 years old, and NEVER installed from the "roll" bar to the rear end, it was about 1.5" short I didn't even check it going forward I didn't check the top why bother? I'm making a new one to keep crap out when on the trailer
  8. the cog setup Pegasus sells is for FF only 30 tooth crank pulley and 44 on the pump, and they don't have anything for the alternator I doubt if the pump does anything below 2000 rpm I have the Burton v-belt pulley on mine, and it's fine stock pump + alt pulleys Burton do have a cog setup that includes the alternator, but I don't know the ratios
  9. fun fact about the mechanical fuel pumps on these if you remove the pump, be sure when re-installing that it sits square with the block before you tighten it down if one side doesn't go all the way down, try again it means the lever is not on the cam lobe, but off to the side DON'T use the nuts to pull it down bad things happen if you force it if the pump has a cast top section with the brass nipples in it, those must be replaced with threaded fittings--at least on the output side they have a habit of popping out and spraying fuel everywhere it happened on a friend's FF H*** of a mess when it lit off same for the inlet on a DGV SCCA mandated that YEARS ago
  10. EDIT previous post only one spacer/cushion per bolt, as in SENC's photo you got 8, so you're good duh I welded a bung into the side of a 90 degree bend in my lower hose, but one of those splice things would do fine I can get a pic later if you want did it 30 years ago, so don't recall where bung came from, but it's an early VW Rabbit switch just have see what sensor will fit your particular bung that's the right fuel pump block
  11. Pegasus doesn't have v-belt pulleys theirs are for cog belts, so you have to change both pulleys and then you have an alternator problem...........and they are a serious underdrive--to much for a street car on any of the Fords, pre or crossflow, the factory fuel pump spacer is mandatory--it positions the pump lever correctly on the cam, and insulates it
  12. I think you're stuck with the single o-ring setup, since you have the grooves in the manifold Hopefully you got 8 of the grommet sets-use 2 on each bolt instructions with mine said tighten them so there's about a mm between the washers puller fans are better, in my experience mount it against the rad, and seal around the perimeter of the rad to the nose as well as you can a pusher fan turned around is not as effective as one designed to pull I have the fan switch in the lower hose, controlling the fan thru a relay with always hot power-fan runs maybe 5 minutes after shutdown if your sensor is in the engine, use switched power
  13. I was referring to something I posted
  14. the square bolt adjuster was on, among others, MGB rear drums also, early sprites (front) used a snail type adjuster between the piston and end of shoe I've never seen the type pictured here---any idea where they were borrowed?
