dvl
Everything posted by dvl
  1. Hi Allan, The set up in my car is nearly identical to Dingo's. I took a few pictures of the mount, but with the transmission in place, they didn't come out particularly well. If you're in the SoCal area, you're welcome to come buy and take measurements of of the trans mount support structure in my car. My car is LHD as well, with the support tube such as a RHD car. Best regards, Dave
  2. Hi Allan, It looks like you may have the wrong gearbox bracket. On page 72 of Tony Weale's Lotus 7 book, the riveted in gearbox bracket shown has a flat surface with holes to mate with the gearbox mount. Also, my Arch, Lotus style S2/S3 chassis, has a flat mount similar to the picture (with additional structure brazed structure to tie the mount to the steel tubes). I can send pictures if needed. I hope this helps, Best Regards, Dave
  3. If it doesn't sell as a lot and you are willing to ship parts, I am interested in the front suspension parts (Item 1, on your list). Thanks, Dave
  4. dvl
    L.A. Area
    There is lots to do, but around LAX and the general LA area. Here's my quick list. Car/Aircraft Museums: Automotive Driving Museum (http://www.automobiledrivingmuseum.org). It's right next to LAX, but relatively small. It's a good way to spend 30 minutes to an hour. Museum of Flying (http://www.museumofflying.com). It's small also, but worth the visit. The museum is located on the grounds of the Santa Monica Airport. The Peterson Mueseum Book Stores: AutoBooks AeroBooks in Burbank (http://www.autobooks-aerobooks.com). If you have a rental car it's definitely worth the drive. Jay Leno and other car owning celebs stop in pretty regularly. Roads/Driving: Drive up Mullholland and have lunch at The Rock Store (another Leno hang out). http://www.rock-store.com Drive up Angeles Crest Hwy in the San Gabriel Mountains and have lunch at Newcomb's Ranch. (http://newcombsranch.com) This is my favorite motorcycle/driving road. Use caution and watch out for motorcyclists, bicyclist, cars, and cops. I hope this helps, Back to work (you can email me with questions if needed dvanlueATgmail.com) Dave
  5. Thanks for the restrictor info. Tony (and his peers) are great resources and have been incredibly helpful to me over the years. I forgot to mention the motor mount. The Caterham unit which clears the dry sump pump is nicely made. It fits well too. Thanks again for the info. Dave
  6. Have you talked with any of the Kent based race engine builders, such as Dave Bean, Craig Chima, Tony Ingram, Jeff at JAE, MWE, Ivey, or any of the others? I know Dave Bean sells press in restrictors for Twincams and BD-series engines, which are sometimes used on push-rod motors. I'm building a similar spec engine for track and street (it's been on my engine stand for a long time, while I work on other aspects of the car) and am not currently planning to run a restrictor. I'm interested to know what you're heard or hear. Thanks, Dave
  7. Harmon Racing Cells built me a complete FIA certified bladder, with foam and a collector, for an old Fuel Safe Lotus Seven cell, for around $1K. It might be worth giving them a call to compare prices. They are a small shop of prior Fuel Safe employees, from when FS was in California. I hope this helps. http://www.harmonracingcells.com/Fuel_Cells.html Dave
  8. Nice car! I'm glad to see another Seven in the LA area too. Dave
  9. My Seven is in pieces and is a slow moving project, but I'm in LA as well. Dave
  10. http://lotus7.com/PUSHROD_PARTS.html Full disclosure, Tony is a friend of mine. I hope this helps. Dave
  11. Here's the 4 speed version, with the large diameter center thread for mounting. There's a long version as well. http://www.taylor-race.com/part.cfm?id=3671&popup=1 I have one of each and I'm in the process of determining the proper bend in the rod, so the shifter clears the dash board. I can email pictures if that will help. Dave
  12. I have a copy of the factory manual, but it had no additioanl information. If I had to guess, I'd put it together similarly to the 3 rail shifter. If Quaife doesn't have one in stock, the shifter can sometimes be found on eBay. Dave
  13. Hi, I have a MKII Cortina manual at home and will look tonight to see if it contains rebuilding instructions (or an exploded view) of that shifter. Quaife builds a nice spherical bearing version of that shifter. I'm also running a single rail 4-speed in my Seven and am using the Quaife shifter. I hope this helps, Dave
  14. I purchased a Type E "Rocket" transmission (4-speed from which the T9 was derived) gasket kit from Taylor a few weeks ago. They definitely still stock T9 type parts. Dave
  15. Hi Darrell, Finishing with wet 2000 grit or better is necessary to achieve a near scratch free appearance, from my experience. As I built up to 2000, I alternated sanding parallel and normal to the grain direction. I used Mothers to hand polish after sanding, using a damn microfiber cloth to apply and buff. It is hard work. I hope this helps, Dave
  16. $150 I have two copies of this book, after finding a 2nd copy at a relatively discounted price, compared to current Amazon listings. I'll pass the savings on to a club member who needs a copy, for $150 plus shipping. It's the 1995 reprint, in good shape, with no torn pages or stains that I could find. If interested, please PM me or email at dvanlueATgmailDOTcom. Thanks, Dave
  17. Harmon Racing Cells in Laguna Beach, CA recently built a new bladder for my Fuel Safe "Lotus 7" fuel cell. They did an excellent job and the total price was around $800, including the addition of an in-tank collector box. They are a small shop of at least one prior Fuel Safe employee. Anyway, I hope this info helps. I found their business while hunting around for shops to inspect and/or replace my bladder. http://harmonracingcells.com Dave
  18. My resolution is to finish my Seven and take it on my Angeles Forest/Crest motorcycle riding loop. I sat in the car last night and made engine noises for motivation. I can't wait to get it on the road. Dave
  19. Wow. Incredible
  20. dvl
    Hi Tim,
    I just realized I never got back with you months ago. I accidently replied to myself...and didn't realize it. The car is coming along slowly. I'll post up some more pictures soon. Thanks for your interest
    Dave
  21. I'm in the process of fitting Tillett B6's to my S3, that was orginally fitted with a bench seat. The seats drop right in, after a little trimming on edges. They will be bolted to the floor, with a u-channel under the floor for added support. Dave
  22. I'm predicting an engine speed of 3748 RPM for my car at 60mph (I'll verify when it's finally finished), with a 4 speed, 185/60/13 tires, and a 3.90 to 1 rear final drive ratio. I hope this helps, Dave
  23. It's starting to look a little more like a car. The engine and other parts a strategically placed around my garage. I'm still aiming to complete it by the end of the year. Dave
  24. My parents lived in La Quinta (20 miles from Thermal), for a few years during my childhood. I recall it being extremely hot (I also recall being chased by golf course security, while my younger brother and I cut across the private courses on a short cut to school...). That's too pricey for me. Wow, he has some nice cars. Dave
