Ferrino Posted January 18, 2017 Posted January 18, 2017 I'm aware of the problem of importing to the US a used rolling chassis that basically represents a disassembled used car (maybe less the drivetrain). But what about a completely bare Seven chassis comprising just the tubular chassis and some bodywork? Is this a straightforward import? Also, does anyone have any current contact numbers for the relevant authorities (EPA/NHTSA) who could help me? It's been a while since I looked into this. Thanks!
mrmustang Posted January 19, 2017 Posted January 19, 2017 I'm aware of the problem of importing to the US a used rolling chassis that basically represents a disassembled used car (maybe less the drivetrain). But what about a completely bare Seven chassis comprising just the tubular chassis and some bodywork? Is this a straightforward import? Also, does anyone have any current contact numbers for the relevant authorities (EPA/NHTSA) who could help me? It's been a while since I looked into this. Thanks! Start here https://icsw.nhtsa.gov/cars/rules/import/
James A Posted January 19, 2017 Posted January 19, 2017 I have seen a replacement chassis imported as replacement/spare parts, no vehicle paperwork needed, just customs. Chassis came from Arch Motors and was no different than shipping engine or suspension parts over.
Croc Posted January 19, 2017 Posted January 19, 2017 Agree with James - thats how Blubarisax's replacement chassis from Arch came in. It was a brand new "spare"
Ferrino Posted January 20, 2017 Author Posted January 20, 2017 Thanks all. I'm wondering if a used chassis raises more alarm bells with customs than a new one?
Ian7 Posted January 20, 2017 Posted January 20, 2017 Coincidentally, I did stay in a Holiday Inn last night (really! LOL), but this is PURE speculation: It seems that if you avoided any serial numbering or stamping, (assuming you are replacing a chassis like-for-like anyway), that would reduce the chance of alarms ringing?
Ferrino Posted January 29, 2017 Author Posted January 29, 2017 Thanks all. This would actually be for a fresh build, rather than replacement.
Sean Posted January 31, 2017 Posted January 31, 2017 When I was researching getting my first 7 long ago, I eventually got through to who I believe was the "right guy" at the NHTSA who told me that once an assembly of "car parts" has an engine or gearbox installed, it forevermore becomes a "car" from that point on, even if later disassembled. So, assuming that information was correct, attempting to bring in a chassis that you know had come from a "car" as defined above would most likely be viewed in a negative light by the NHTSA. Or so I believe.
Ferrino Posted February 7, 2017 Author Posted February 7, 2017 Thanks Sean. As usual, this seems really ambiguous to me. For example, would this not imply that any used part that has ever come into contact with a running car is not legal to bring in? My understanding of the wording was more a case of: stripping a car down in the host country, shipping parts separately and then reassembling it to recreate the car on these shores. When I was researching getting my first 7 long ago, I eventually got through to who I believe was the "right guy" at the NHTSA who told me that once an assembly of "car parts" has an engine or gearbox installed, it forevermore becomes a "car" from that point on, even if later disassembled. So, assuming that information was correct, attempting to bring in a chassis that you know had come from a "car" as defined above would most likely be viewed in a negative light by the NHTSA. Or so I believe.
lucky dawg Posted February 7, 2017 Posted February 7, 2017 Thanks Sean. As usual, this seems really ambiguous to me. For example, would this not imply that any used part that has ever come into contact with a running car is not legal to bring in? My understanding of the wording was more a case of: stripping a car down in the host country, shipping parts separately and then reassembling it to recreate the car on these shores. The chassis has a VIN stamped on it, a fender (or whatever other used part example you want) doesn't.
