alternator?
lova
Good morning, New to the 7 family. I purchase a 1996 Caterham with the 1600 Ford crossflow engine in July. Im in the need
of an alternator. It has a Valeo but all of the numbers don't cross to anything. Im hoping someone can help. Thanks
FWIW, a few of us on the forum (some Storker owners, in particular...and maybe others of different makes) are using the light weight Denso 55 amp alternator pirated from something such as a 1997 Geo Prism. Going forward, it may be an alternative; easy to source.
And here is a good video link to a Denso install:
Edited by xcarguy
Addendum to the suave stork message
If you're looking for a direct replacement: I discovered my car was originally supplied with a NipponDenso forklift alternator.
It worked well but no one could identify it because their searches were only automotive.
Another small and lite Wt option would be the 40 Amp Denso that is fitted to a Daihatsu and Suzuki bandit.
P/N A073, also Tractor Spares Co. P/N 196300. but you would probably have to change the pulley, I'm assuming you have a "V" belt. Dave W
