Seat options for a clone 7
TBone1209
I've got a 7 clone with 17.5" from the tunnel to the external frame. I'd like to change my seating situation.
With such a limited space (and budget) I wanted to query the collective genius of this August group to see what others may be using....outside of the $1200 Tillet B6's. Something like 400-500 bucks would be OK. This is for a street car with spirited driving but minimal track work.
The Tillett W1i looks OK but with the internal frame it's $900 per seat...
Anything else out there that's narrow, good support and decently priced?
Edited by TBone1209
Yea, that's great for a track car but in most respects this is a nice looking street car and the idea was keeping it that way if possible. Pics added in earlier post because everyone likes pictures...
Having said that, I agree, bead seats are great for track mobiles...
Edited by TBone1209
Hi Tbone,
I agree most people think of bead seats as not very attractive. I don't track my car; but on both of my previous S3, I built a "foam in place" seat bottom, not a bead seat. The car was so tight for me (6'4" 220 lbs) that I didn't need the seat back. Below is a picture of the covered seat cushion. As I said, I didn't use beads I used this product:
https://www.sunmatecushions.com/pages/liquid-sunmate-foam-in-place-seating
My current car is an SV, with lowered floors and leather seats. Although the seats are pretty comfortable, I am just beginning the process to build a new seat cushion. I am not trying to change your mind, but thought I would post this here so that in the future if someone is searching the site for seat options, they will find this info. Good luck in finding your perfect seat.
I drive a lot on the street and lots of track time, the Ultrashield seats suit my needs completely, a little memory foam and they are good for some long trips. Also several widths to choose from.
I've used a Kirkey seat in a Miata track car and found them to be pretty rigid with good support, and they're not too expensive.  I don't remember the model number but like the Ultrashield they're available in different widths to fit.  I ended up getting a 14" Kirkey #38140 to use in my Series 2 vintage rep and had to modify the rib brace/wings to get it to fit in the narrow space available....and that's the 14" model!   I really like the standard Caterham seats that I have in my 310 for comfort, but they could use more side support if you were going to go on track.  Like most things, you really need to sit in one to see how it fits.
Nice looking Seven clone TBone!
I ran into the same issue with the Kirkey's in my Birkin. You need to use the "Drag" version of the same seat. It's dimensionally the same except no shoulder supports. I cut the supports off of my seats and salvaged the soft aluminum edge trim and tack welded it to fit the revised edges. I had a local upholsterer (hot rod guy) modify and re-cover the Kirkey upholstery to fit.
I think I did pretty much the same thing as you did Papak.  I also cut off the seat headrest because I'm using the headrest from the rollbar.  The modified seat looks like this.
I saw those after looking on the spec Miata sites. I believe that's the Rally seat? The only issue is shipping from the UK. Based on the dimensions they look to be a good fit for the 17.5" space I'm dealing with. I'll see if I can find a dealer stateside...
Just spoke with Ultrashield about the spec Miata seat they have. Pretty remarkable that they will customize it within bounds for little to no additional costs. Custom width for no additional costs. Move the harness holes up or down by an inch for no cost and potentially remove 3-4 inches from the top for free. Pretty amazing. I'll have to wait until January but everything has a wait time these days...
Edited by TBone1209
