Sean Posted January 3, 2023 Posted January 3, 2023 "Boosts the performance and speed of your car instantly" Hahahaha!
Croc Posted January 3, 2023 Posted January 3, 2023 If you have a flat battery then yes it would boost the performance of a currently dead engine. Captain Obvious here! 1
panamericano Posted January 3, 2023 Posted January 3, 2023 2 hours ago, Croc said: If you have a flat battery then yes it would boost the performance of a currently dead engine. Captain Obvious here! My thoughts exactly. Home Depot knows a thing or two. No deceptive advertising. Though, we once coasted down a mountain, with a dead engine, about 3 km. to a known safe spot. After putting the car on it's head. Jumper cables would not have helped. 1
MV8 Posted January 4, 2023 Posted January 4, 2023 They could try putting the negative on the positive and the positive on the negative but if you asked if I were absolutely positive, I'd say negative. 1
IamScotticus Posted January 4, 2023 Posted January 4, 2023 (edited) 42 minutes ago, MV8 said: They could try putting the negative on the positive and the positive on the negative but if you asked if I were absolutely positive, I'd say negative. You are a medical doctor? Edited January 4, 2023 by IamScotticus
MV8 Posted January 4, 2023 Posted January 4, 2023 You just push whatever the administration decides without question or else. How hard can it be? I can fold quicker than a lawn chair.
Alex-Ks1 Posted January 5, 2023 Posted January 5, 2023 if you read the add real good, it aluminum clad wire, very cheap. probably only about 6 strands of wire, I have cut these apart in my shop, Chinese crap. we have 2/0 welding cable with 1350 strands of pure o2 free copper wires. this goes to a D-4 battery on wheels. Its just to use in the shop. My truck has a Anderosn 350 amp, socket in the grill from my battery, this plugs into the 20 ft welding cable with clamps so strong you need two hands to open them and attach to the dead battery ..... cheap will always outsell quality
