Getting closer to a purchase. More questions.
Saudio
8 hours ago, KnifeySpoony said:
Hey, compared to an atom or BAC mono, a 7 is incredibly practical.
Yeh, I drove an Atom a couple years ago.  It was just too raw for me.  But I loved parts of it.
I was able to commute to work a few times ~ 70 miles round trip with the weather in the mid 30s. With the roof up and the back window open and heater on, I was plenty warm.
Apparently the de-dion has a deeper trunk than the live axles (I haven't compared), but I am able to store a work bag + small motorcycle tool kit + jump box + misc oil / radiator hose / gear oil and still have plenty of space in the trunk. The car is surprisingly practical. With the roof up and doors on, getting in is a bit of a challenge, but I am pretty short so it works out.
Regarding visibility, the 3rd brake light is a must. I find with the roof up I still do not have the visibility I like.
I picked up some awning fabric and velcro from Jo-Ann fabric last weekend. I'd like to make some 3M reflective straps which I can velcro over the rear roll bar which will provide some reflective visibility. I will probably do the same on the front cycle wings, or something of the sort as the nose visibility can be tough for the average driver.
The cat 7 is maybe marginally more difficult than my Z4... at the end of the day it's a roadster, if you're used to the confines of a small coupe, you won't be as shocked. I think a lot of the commentary I watched and read online about the car being small is true, but there seems to be some hyperbole for YouTube views too.
  • 1 month later...
Welp, I skipped the entire build process and purchased a very slightly used 620S from Hillbank in LA.  It was almost exactly what I was looking for, color and everything, and I didn't want to wait.  I flew out last week and drove it, and made a deal I was satisfied with.
Take delivery first week of March.   I'm excited as hell.  Just in time for Spring driving.  :-)
I remember the second seven I test drove was a 620s can’t remember the dealers name  (kemper?) but it was up north here in CA. I only remember two things. One it was insane like insane speed, two shifting with my left made me super nervous. But holy shit the speed! congrats buddy.
  • Haha 1
11 hours ago, KnifeySpoony said:
Awesome, congrats. Look into the 620 overcooling issues on blatchat. There is a fix.
Thanks for the heads up.  I did some reading. Do you know if there are specific parameters that would tell me if I have that problem with my car, that is, a temperature range that is out of spec?  I read that Caterham had a fix that they were charging 1000 pounds for but that seems a bit cheeky if it is a known issue.
I'll be sure to address this before completing the paperwork.
5 minutes ago, Saudio said:
I was surprised that it didn't seem that weird to shift with my left.  I don't think it will be an issue.
My wife bought me a racing wheel and shifter for Christmas. It was the base Logitech at the time. While not anywhere close to driving a car in real life, mounting the shifter on the left side really helped with muscle memory for the H pattern, I found my 2 - 3 shift really improved after using the sim wheel and shifter. It's really not that bad, and RHD is a little wierd for left hand turns with an SUV next to you, but just be patient, like riding a motorcycle etc.
The overcooling was news to me, but I'm not on Blat. I did "a little" research. The issue as I understand it is the 620 warms up normally but once racing or running hard (i.e. hot revs), the stat can't close against the coolant pressure.
Fit a tee to the upper hose that will connect to a heater hose fitting on the engine, then install a spring loaded check valve (pressure relief) that only flows when the pressure exceeds 12 or so psi, to bypass the thermostat. There should be no downside.
