No first-hand knowledge of this one, but I'm certain the red cage snaps on and must be removed to do any re pinning. Most connectors are assembled with the pin inserted/removed from the rear instead of the mating surface. Very small allen wrenches are often adequate to release pins. They sell universal key sets on ebay.
Draw the connector wiring on paper, take good pictures to show the color coding by each pin, then have no more than two de pinned at a time.
Edited by MV8
The red cage needed to be removed. Then I had a very thin Tweezer for vinyl that I was able to disengage the clip, then pushed it out from the front using a piece of Tig filler wire. Put it all back together and it started right up.
