I may (or may not) have an issue with the handbrake wiring. The wiring diagram on the assembly guide version 2015c on page 218 doesn’t even seem to show any handbrake wiring on the chassis wiring diagram but there are 2 wires connecting to a switch that is actuated when the handbrake is pulled up. What’s the handbrake switch supposed to do? Should the brake lights come on when the handbrake is up? Any info appreciated!
I would think that it triggers the warning light on the tach.  Mine lights up if the handbrake is on (even slightly).
Same circuit as the brake reservoir low fluid sensor. Either will cause the same indication.
Ok thanks guys. I see the warning light now, just wanted to make sure there wasn’t an issue with the brake light. Strange that it’s not on the wiring diagram.
Given how long you've owned a Caterham, you should know that incomplete or inaccurate technical information is anything but strange :D
I believe the word you're looking for is "charming".
