11Budlite Posted July 31 Posted July 31 My 2019 310 has a black painted Caterham rack and pinion. Does anyone know what the difference is on a blue painted Caterham rack like this one?
Croc Posted July 31 Posted July 31 Black was always S3 chassis. SV chassis steering rack were a different color. Is this an SV rack?
11Budlite Posted July 31 Author Posted July 31 1 hour ago, Croc said: Black was always S3 chassis. SV chassis steering rack were a different color. Is this an SV rack? I'm not sure. The total width is 39-7/8" without the outer tie rods, and the mount spacing is 7-3/4". I won't have access to my Caterham until tomorrow to compare.
11Budlite Posted August 1 Author Posted August 1 The mount spacing on the black rack of my 310 S3 is the same 7-3/4". I'm leaving for a NH track day so didn't want to mess with the toe to compare the total width.
IamScotticus Posted August 1 Posted August 1 One is black and one is blue Seriously, @Croc my 96 S3 is blue. I've been wondering the same thing myself. I have a black one I bought off someone. I can do some turns to see if there is a difference. 1
IamScotticus Posted August 2 Posted August 2 (edited) Here is my black rack. I think it is longer than the blue rack. Just sayin'. I affixed tape on the shaft at 90° for both right and left lock. The other arrows are the stop angles for R&L plus 360°. Like 1.75 turns L2L. Due to my current circumstances, it will take time to get to my blue rack to do the test. I'm sure someone has a blue rack to help you. Model #, not serial. Serial is stamped elsewhere 90° from both R&L full lock. Not true middle. Left turn: Right turn: So, for R&L turns, add 360° and divide by half. Is this a quick rack? IDK. Edited August 2 by IamScotticus 1
CarlB Posted August 5 Posted August 5 When I got my car it had a blue rack quick rack. I got a new one and it wasn't painted. 1
11Budlite Posted August 5 Author Posted August 5 Thanks guys, when I get a chance I'll do the lock to lock rotation check to compare.
11Budlite Posted August 8 Author Posted August 8 I finally got around to this. My blue rack has this P/N stamped on the housing near the pinion: B9905029. I did a lock to lock measurement and it looks like it's just under 2 turns. I put a protracter on the photos and estimated it at 1.88 turns L2L. Total rack movement L2L looks to be right at 4.0".
IamScotticus Posted August 8 Posted August 8 (edited) B9905... is a serial #. You don't have a Cat part # etched in the tube underside flat? Edited August 8 by IamScotticus
Croc Posted August 8 Posted August 8 5 hours ago, 11Budlite said: …it looks like it's just under 2 turns. race rack. 1
11Budlite Posted August 8 Author Posted August 8 5 hours ago, IamScotticus said: B9905... is a serial #. You don't have a Cat part # etched in the tube underside flat? I couldn't find anything else stamped or etched in the housing. 1
wdb Posted August 8 Posted August 8 1 hour ago, Croc said: race rack. Hmm. That explains why the steering in my car is so quick!
