9 hours ago, CBuff said:
Minnesota is a two-plate state, but Collector Class (20 years old) cars, AND cars old enough to eligible for Collector Class even if not registered that way, only need to display a rear plate.  I may get away with not having a rear plate light on the Birken.  Or do what I did with a former trailer; install the plate using mounting bolts incorporating directional LEDs.    I think I even saw an MK Car so-equipped in one of their promo pix.
I haven’t ever really determined my maximum range or filled my tank all the way (except the time I overflowed!) but I tried to crunch the numbers from my notepad-based drive log over the past two years and it seems I get around 20mpg, give or take.
This is mostly on canyon drives (since the hills start 10 minutes away), so I guess I’m satisfied. Would always like to see a little better though!
Edit: Zetec on TWM throttles, Pectel T2, 13” Toyo 185/205 tires. Actually a bigger rolling diameter than stock so my economy should be *slightly* above indicated but not enough to matter.
Edited by Slonie
Car notes
