As some of you may know, I ran out of gas on the road last week... that event was the catalyst to me finding out the gas tank should be closer to 9.5 gallons, with about 1.5 gallons un-usable.
I was always under the assumption the tank was around 5 gallons, so this was great news to me.
I also found out that I was filling up the gas incorrectly... just cuz the nozzle shuts off doesn't mean that it's full.
I guess the size and shape of the tank makes the gas easily shut the nozzle off.
My dealer told me the trick was to fill it much more slowly.
I tried this today... I filled it until the nozzle shut off, then filled it more AS SLOWLY AS THE PUMP ALLOWED.
I filled it until it overflowed, and then verified that the fuel was indeed filling up the section between the flap and the gas cap... and if I open the flap, it wasn't flowing down into the tank.
The math is as follows:
When I ran out of gas, I got a 2 gallon jerry can to fill it up.
Then drove about 15 miles to a gas station, and filled it up 1 more gallon (it shut the nozzle off so I stopped).
Today, the total I was able to fill it up was 1.5 gallons.
That seems like I'm still just totaling around 5 gallons.
What is my dumb ass missing here?
Somewhat related note... I have the @BruceBe fuel gauge mod... it's always designated full tank historically when it's about 1/4 tank and I fill up roughly 4 gallons.
Edited by hahuang65
If your totals and fill procedure above are accurate, and assuming your car wasn't used to smuggle anything into the country via a hidden compartment in the fuel tank, I wonder if you experienced a fuel delivery issue, that is discrete from your gauge accuracy? Either some kind of blockage in the tank or the fuel pump cutting out? Has this only happened once?
@JohnCh only once.
When we were out of gas I attempted to crank the starter twice. Seemed like definitely out of gas.
As soon as get got the 2 gallons of fuel in via jerry can , cranked and started immediately.
Definitely seemed like out of gas.
Something's not adding up. Are you saying from running out of gas to filling the tank until overflowing that it took 5 gallons? Or that the tank only ever took 5 gallons on initial fill after build?
I'm saying this.
I'm possibly saying this. I only ever filled it to 5 gallons because
1) that's how big my jerry can was on initial fill
2) I thought it was 5 gallon capacity because the pump nozzle would auto-stop anytime I filled around 5 gallons. (I'm now aware of why this happens)
Currently, meter reads full, and seems absolutely topped out. I don't see how I could have made a mistake given I was literally out of fuel and kept track of how much I filled up....
but I'm gonna drive around until the meter reads 1/2 and then see how much I can fill up. I'm at 777 miles exactly when I topped the tank off.
Edited by hahuang65
I'll just add that I hold the gas pump nozzle upside down when I'm filling my 1990 Caterham to get a better angle... I kinda lean into it with my body weight to keep the vapor-recovery belows thing compressed to prevent auto shut-off (might just be a California thing).  It holds about 10 gallons, but most of the time I misjudge and get overflow.  The filler neck on my older car might be a differnt shape from the more modern Cats, however.
Cheers,  -David
Edited by DavidL
I've never been able to use the auto-stop at the fuel pump in my r500.  The speed at which I can fill the tank varies from location to location, but its rarely full go.  Once I get to about 6gal I'll usually slow it down and listen for when its getting full (I'm usually only putting in around 7gal).
I've also noticed the fuel gauge isn't overly accurate.  It takes significantly more time to go from 30L to 20L than it does from 10L to 0L.  Once I get to 10L I'm starting to look for a place to stop.  I don't think I've ever put more than 7.5 gal in.  While I also have a 36L tank, I'm not sure if its 1-2 gal of unusable space or if 0L on the gauge actually means another gal or so of fuel left (I don't plan on finding out).
1 hour ago, KnifeySpoony said:
So have you ever driven it from "fully full" until empty, or tested the range since a true fill up?
I remember trying this with my very first fill-up, but I can't remember what the results were. But again, I think that was with only 5 gallons... as my habit was to stop filling when the pump nozzle stops.
I'm gonna carry around a small jerry can, and test the range. I'm at 777 having pumped "fully" and then drove 2 miles home.
I'll check the mileage at 1/2 tank and then attempt to fill back to "full" and see what that volume is.
I have the Bruce fuel mod which works well 420R. The first half of the tank lasts longer than the second half. I usually run it down to fairly solid on E and it will take 7.5-8 gallons (SV so 10.8 gals minus the roughly 1.5 unreachable). One time at the track i got distracted and buried the needle on E. It took almost 10 gals so maybe the 1.5 is overly safe but I dont try for that.  Here is NY they have taken the auto locks off the pumps so you have to hold it anyway. With some practice you can judge it but 1/4 of the time i still have spill over.
I wouldn't trust linearity of the gauge. Also, given that your gauge would read full with your prior filling technique, it suggests that you were probably getting the tank mostly full, unless your gauge is way off. I say drive it till you run out of gas (if practical), then you will actually know how much gas you've used to get to that point.
I do too.
I haven't ruled out just me being a really dumb fellow quite yet, but so far, with me only filling up ~5 gallons, it's always displayed full on the gauge and will go steadily down towards empty. I always filled it when it hit then 1/4 mark, and it'll take about 4 gallons (until the nozzle shuts itself off).
I just have a lot of experimenting and note taking to do for the next few fill ups just to see where I'm going off the rails.
Yeah I'm gonna do that. I just wanna see exactly how many miles and how many gallons (from full) each 1/4 tick of the gauge is. Was gonna do half a tank first, then I can see where 3/4 tank and 1/4 tank is... and then finally just drive til basically empty and see what that is.
I think by that point, I might have enough data points to be able to guess relatively close where empty actually is.
Can you get some rough measurements and calculate the capacity (roughly)? Then you know if you can only put 5 gallons in a 10 gallon tank, you have a problem. I am not exactly sure what that problem would be, but it's a starting point.
@hahuang65 I am not sure how easy it would be from underneath, but if you can get the length, width, and height, you can calculate the approximate volume.
Gallons  = (LxWxH)/231
Caterham doesn't offer smaller fuel tanks, so even if they somehow managed to install the slightly smaller S3 tank in your SV, you would still have 9.5 gallons less ~1.5 gallons the fuel pump can't reach. That doesn't mean the tank wasn't crushed, but you that would be pretty obvious from beneath the car. From the owner's manual:
It seems there are only two possibilities: The way you checked earlier that the tank was full was done incorrectly, or you have an issue with the tank. Although it's a little tricky to do because of the flap and the curvature of the filler neck, you could make a curved dipstick out of thick single strand wire or thin rod to confirm the fuel level. I have done this before when troubleshooting, but it took several attempts to get an accurate reading. I found putting painter's tape on the rod was helpful to see the actual level. Another possibility is repeatedly tapping the front of the tank going from bottom to top to see if you note a change in the thud that delineates the transition from fuel to air. I've never tried this myself, so the difference may be too subtle to hear. If you do attempt it, avoid the middle of the tank where the baffle is located.
If you think the tank should be nearly full and the dipstick or thump test shows about half, then you know the issue is with filling it. If not, then there could be a blockage, or possibly an issue with the baffle, which divides the fill side and pump side of the tank.
The foolproof method to confirm the fuel level is to remove the floor and pull the fuel pump/sensor assembly and do a visual check. However, that isn't easy as an uncut floor can be very frustrating to remove, and you need a special tool to remove the fuel assembly's locking ring. Fortunately, that tool is readily available and isn't expensive.
My boot floor is currently removed, so let me know if you need pictures of anything.
BTW all the suggestions above are assuming your car is running well and you aren't getting @Vovchandr-like fuel consumption.
  • Shocked 1
What is his fuel consumption? I went from thinking I had a full tank (5g by my definition at the time) to empty in like 40 miles .
  • Shocked 1
