wow, 400+ pounds, and at only 120 mph ?
sounds an aggressive claim,
not to mention the "quality" of the airflow towards the rear of a 7-esque car
will be eager to hear about real-world results
cheers
  • Replies 184
Posted Images
Never thought of it before..... having some kind of automatic adjustments based on speed and turning of the steering wheel would be the ultimate. Imagine F1 does that, if allowed.
That is not 400 lbs per wing, that is combined down force between the 2 wings.
178 lbs front/ 229 lbs rear, Duel element w/ nearly 800 sq in. of surface.
The max AOA on these wings is 40 degrees without creating a
stall condition. Of course at that AOA we are talking about
a significant amount of drag and turbulence over the car. But you don't
love a 7 because of its aerodynamics. Even the Atom has very poor aero.
Because of the hp of the car drag is not as much of a concern as down force
Last year at Road Atlanta we turned 175 down the back stretch before cresting the hill
and heading into turn 10a. At that speed the car is nearly impossible to keep planted and under control.
This year we thought it would be wise to beef up the roll cage and wing it to try and keep it attached to the planet.
If you run the numbers (800 sq in) on a piece of 1/2 inch plywood at 120 mph
@ 40 degrees AOA you would be surprised at the results.
Here is some thing new we are trying to reduce heat in the cockpit.
Its called Lizard Skin.
http://www.usa7s.com/aspnetforum/upload/1991105981_Resized_DSCN6347.jpg
http://www.usa7s.com/aspnetforum/upload/1280113863_Resized_DSCN6349.jpg
http://www.usa7s.com/aspnetforum/upload/597604015_Resized_DSCN6351.jpg
Its a Spray-on Ceramic Insulation and Sound Control
# Reduce engine and solar heat transfer by 25-30 degrees or more (we are hoping for more)
# Reduce noise by 10-12 decibels or more
# Protect surfaces from moisture and corrosion
# Withstand temperatures to 500° F. (260° C.)
We'll see. We have also used spray in foam insulation (tiger Foam) to try and get the heat down.
We will keep you informed if any one is interested.
Cheers
Kevin
7evin:
Some of the better airfoils have lift to drag coefficient of 3. In other words for every 3 pounds of lift you create 1 pound of drag. Do you what it is for your wings?
:7head:
Please post later how you like the Lizard Skin. I plan on spraying the tub area with Linex which I suppose could be done over Lizard Skin.
7even,
I've been looking at a product called Fibrox. It's a hi-grade glass insulation/sound-deadener that's used in manufacturing (e.g. between the catalytic converter and the aluminum shell around the converter) of production cars. It's light and really heat resistant (1500 degrees F), has very high insulating value, and does its work as thin sheet (1/4 inch). The downside is that, since it's inorganic/glass, it's not impact resistant. The combination of this insulation covered by Lizard Skin (for protection and additional insulatin+deadening) sounds like a good combination. What'dya think?
Cheers,
7even,
Cheers,
Hi JohnK,
Here is a link to the product that you want to use. It is a good product but can be heavy in certain applications.
http://www.fibrox.com/home.htm
From experience it works very well with a reflective surface of foil (face side) and a thin coat of silicone on the back side which also helps keep it together when flexed.
Hope this helps.
7evin:
:7head:
Hey Bob,
I do not have the info in front of me. I will look it up once we have the car ready to be tuned. WestTex is cracking the whip on me to produce, so I'll do it later.
Cheers
Kevin
We rhino lined the interior of the car and put the lizard skin in the engine compartment.
We shall see. We are also looking at heat reflective material.
Go easy with linex the weight adds up quick. We put a very thin layer on.
Not a big deal if you are not racing and trying save every ounce.
Cheers
Kevin
Hope this helps.
Hi Martin,
This is indeed the manufacturer. I got a sample from the factory in Canada and,
1) "300 Paper" 1/4 inch thick weighs 84 grams per sq foot - I figure around 2 lbs and change for the 12 sq. ft. it would take to do an Ultralite, and
2) if you drop something on it it breaks the fibers - so I can't imagine it living very long without something stout (perhaps Lizard Skin) between it and ordinary road debris.
My question is from whom do you source it? The factory told me that their US distributor and value-added supplier is Tritex in SC, and that the smallest quantity was 125 sq. ft, at $2-3 per sq. ft. Since I only need a tenth of this, I was looking for someone to split up a roll with me to save money.
Again, my take on this is that it's light and very highly insulating, and sounds like a good partner with Lizard Skin.
Cheers,
Hi JohnK,
I worked for a company call Hi-Temp insulation for a while and they used it in a test application and to my knowledge have not used it for anything else due to it being brittle and heavy for what they produce (think Sputnick an that is all I can say). Their are some other insulators that are even better and thinner and lighter but the expence is very high for a automotive use. Moss Motors sells a heat and sound deadening material that works very very well and is easy to use it is called Dynamat and it's part number is 409-026 and is 4 each at 1x3 ft and cost $114.95 which if used correctly should cover the areas you need to protect from heat. They also have so other sutff 409-015 which is sold by the sheet 48"x72" for $38.95 each.
Hope this helps.
Martin Keller
Ventura, Ca.
Yes, please keep me-us informed on this lizardskin sheilding.
we took out the trashy looking aluminized "stuff" we found on the birkin. We have the headers wrapped inside the bodywork but are sure more will be needed. dont want to melt our new shoes!:ack:
Few update pics fuel cells/ dual tank, main and sump tank
http://www.usa7s.com/aspnetforum/upload/1549612987_DSC01943.JPG
Fuel pumps
http://www.usa7s.com/aspnetforum/upload/275430516_DSC01944.JPG
rear suspension
http://www.usa7s.com/aspnetforum/upload/434426889_DSC01945.JPG
carbon fiber dash
http://www.usa7s.com/aspnetforum/upload/1147860940_DSC01946.JPG
header
http://www.usa7s.com/aspnetforum/upload/1162368233_DSC01948.JPG
header on car
http://www.usa7s.com/aspnetforum/upload/545862251_DSC01949.JPG
engine shot
http://www.usa7s.com/aspnetforum/upload/1375341888_DSC01950.JPG
side view
http://www.usa7s.com/aspnetforum/upload/1904362106_DSC01953.JPG
rear view
http://www.usa7s.com/aspnetforum/upload/332627712_DSC01954.JPG
screw actuator for pedal adjustment
http://www.usa7s.com/aspnetforum/upload/2011407142_DSC01955.JPG
intercooler
http://www.usa7s.com/aspnetforum/upload/610814243_DSC01956.JPG
Hopefully we can get this thing running this week.
look forward to seeing the supercharger set up (and numbers):thumbs:
What is that "mocal" thing with the light blue hoses attached to it?
I remember on your write up you had problems with the previous rear of the car during one of the races. Are you planning on a cooler or something for back there, or figure it was a fluke and not real concerned? Or a completely different rear?
We changed to a beefier rear diff it has held so far. Hope that it will handel the addidtional power. We may need to get it Cryo treated if we still have issues.
Mondo you can see the supercharger down on the bottom right in the engine pic hopefully by end of next week it will be on the dyno and we will have some numbers.
The Mocal unit is an engine oil cooler that uses radiator fluid to help keep the oil cool.
has that intercooler setup been tried before? it looks like the endtanks are going to impede a lot of air circulation to the radiator.
We are really concerned about that ourselves. We specd the core and where we wanted the outlets and they built it with those huge tanks. So we will just have to give it a try. kind of hard to not use such an expensive part. 7s just have such a limited space. We were trying to stay away from water to air intercooler with heat exchanger fluid tank pump and all that hardware. This car is going to be running on Ethanol which should help keep the temps down. We will see. We might have to go with plan B.
