So the other day I finally took Orange out for a spin with my younger daughter and we stopped to put some air in the tires.
For starters, what are people running as typical F/R pressures for the 15" CR500s? (I put in 40 all around...44 is the limit printed on the tire).
Also, can anyone guess what the Treadwear rating is?
I was shocked, shocked I say, to find out that they are UTOQ 20!!!
I don't think I've ever had a tire that was under 240.
From what I've read on Blatchat, 20 psi and lower is "normal" for a Seven. I usually run around 18 - 20 psi (with the infamous Michelin Pilots aka "pileups").
Steve
Even on the CR500s, hunh? (I thought the ACB10s ran that way.)
Wow. I guess it's got pretty stiff sidewalls.
40 is way too high. you'll get much more grip at lower pressures. I'd say play with it a little, starting at 25, and see how you like it. With a car like yours, it'll probably end up being lower than 25.
The best way is to take her to autox or skid pad with a tire temp gauge http://www.usa7s.com/aspnetforum/images/emoticons/smile5.gif
40 is too high. I'm at 20 psi on 14" rims (recommended by Caterham). Folks with the same tire/wheel set up as mine recommend anything from 15 to 20 psi.
Gosh, I feel like such a rube now!
I am immediately going home to let some air out!
Happy New Year all.
i run 18-21 psi on my avon zr1s. u don't ned the high psi in our tyres becaus ethe car is so light. i run just under 40psi on my subarus, and they are 2.5x the weight.
didn't mean to rub in in, Al, just wanted to get to 100 posts http://www.usa7s.com/aspnetforum/images/emoticons/hurray.gif
Thanks for the info! I had no idea that the PSI was that low either! http://www.usa7s.com/aspnetforum/images/emoticons/confused5.gif
Rob Mitchell
solder_guy2006-12-30 07:37:31
