BruceBowker Posted April 18, 2010 Share Posted April 18, 2010 Any suggestions on a very low profile battery? Mine is located on the firewall "shelf" and has near zero clearance from the engine cover. Thanks Bruce Link to comment Share on other sites More sharing options...
yellowss7 Posted April 18, 2010 Share Posted April 18, 2010 Odesssey PC625 works nicely for me. Although I did mount it down low under the intakes. Tom Link to comment Share on other sites More sharing options...
Hank Posted April 18, 2010 Share Posted April 18, 2010 ^ What Tom said. Never any trouble crankin' the Busa. Course, I make 1/5th the torque of Frankin7. ahahha Link to comment Share on other sites More sharing options...
pksurveyor Posted April 18, 2010 Share Posted April 18, 2010 I used a dry absorbed glass mat battery by Extreme from Battery Plus. It is about half the size of the Caterham original battery and cheaper than the Odessey. There is no acid to spill and you can mount it in any position. Link to comment Share on other sites More sharing options...
slngsht Posted April 18, 2010 Share Posted April 18, 2010 I ran the 625 with my LS1 for a year or two. Cranking over wasn't a problem. Just not much capacity if you leave any accessories on. Link to comment Share on other sites More sharing options...
jimrankin Posted April 18, 2010 Share Posted April 18, 2010 There are several absorbed glass mat barreries for jet skis that are small, lots of cranking amps, can be mounted in any position and are fairly cheap and available. have one cranking over an S2000 2.2L without a problem. Link to comment Share on other sites More sharing options...
pierats Posted April 18, 2010 Share Posted April 18, 2010 I had a generic AGM battery, but it eventually died. I replaced it with the Odyssey PC680. The two batteries are the same dimensions, but the PC680 is probably twice the weight. I took this to mean that there is more capacity (quality?) in the Odyssey than the generic version. The Odyssey was more expensive...I suppose you get what you pay for. Link to comment Share on other sites More sharing options...
drew... Posted April 18, 2010 Share Posted April 18, 2010 PC625 under the intake stars the SVT motor with no problems - going on two years. Link to comment Share on other sites More sharing options...
yellowss7 Posted April 18, 2010 Share Posted April 18, 2010 Whoops, I meant 680 not 625. My bad. Tom Link to comment Share on other sites More sharing options...
BruceBowker Posted April 19, 2010 Author Share Posted April 19, 2010 Thanks. Some ideas to consider. Link to comment Share on other sites More sharing options...
solder_guy Posted April 19, 2010 Share Posted April 19, 2010 I keep a trickle charger on my PC680 all the time! My first PC680 died after two years .. I guess I let it get too low .. for too long of a time. Link to comment Share on other sites More sharing options...
Ian7 Posted April 20, 2010 Share Posted April 20, 2010 Assuming you don't need to start the car in cold weather, you don't need much in the way of cranking amps at all. I run my (admittedly low compression) Kent off a lawn tractor battery that is half the size and one third the cost of a 'regular' car battery. Link to comment Share on other sites More sharing options...
JohnK Posted April 20, 2010 Share Posted April 20, 2010 I keep a trickle charger on my PC680 all the time! My first PC680 died after two years .. I guess I let it get too low .. for too long of a time. Watch your voltage - in their docs they specify that it should never be over 15. I found that an ordinary Schauer 6 Amp charger set on "conventional" fills this bill. Link to comment Share on other sites More sharing options...
southwind25 Posted April 20, 2010 Share Posted April 20, 2010 I got a used Odyssey from a fellow member (Mike) and it works reasonably well.. (She's birkin though and will discharge after a couple months of sitting.) Link to comment Share on other sites More sharing options...
solder_guy Posted April 20, 2010 Share Posted April 20, 2010 Watch your voltage - in their docs they specify that it should never be over 15. I found that an ordinary Schauer 6 Amp charger set on "conventional" fills this bill. My charger is made specifically for Odyssey batteries .. Link to comment Share on other sites More sharing options...
HankMauel Posted April 23, 2010 Share Posted April 23, 2010 (edited) I use an Optima battery with side mount terminals (as well as the normal "top posts"). Left the plastic covers on the top posts and the posts clear the aluminum bonnet by about an inch. When not in use I hook up a small Battery Tender unit to charge/monitor the Optima. They may now have a "side post only" model. Edited April 23, 2010 by HankMauel Link to comment Share on other sites More sharing options...
khamai Posted April 24, 2010 Share Posted April 24, 2010 The GGLC has a BCI size chart for most standard car batteries. The shortest batteries are a bit under 7" tall. http://gglotus.org/ggtech/battery-bci/battery-bci-size.htm Cheers, Kiyoshi Link to comment Share on other sites More sharing options...
rnr Posted April 24, 2010 Share Posted April 24, 2010 You could try the Lithium Ion battery from Porsche: http://axisofoversteer.blogspot.com/2010/04/add-lightness-porsche-motorsport.html Only $2000 Link to comment Share on other sites More sharing options...
Hudson Posted April 24, 2010 Share Posted April 24, 2010 Here you go and I just saved you a $1000 https://p10.secure.hostingprod.com/@www.voltphreaks.com/ssl/catalog/product_info.php?cPath=1_5&products_id=87 Ed Link to comment Share on other sites More sharing options...
