New 2013 Birkin S3
Lotus 7 Reproduction
This car is newly constructed to the highest standards and is ready for your enjoyment. The following is a list of this car’s features and equipment.
• Wide track front suspension
• Full independent rear suspension
• 210 horsepower 2.0 liter Ford Duratec
• Crower Stage 2 cams
• AT Power throttle bodies
• Specialist Components Typhoon ECU with wide band oxygen sensor
• 5 speed close ratio gearbox
• 4:11 limited slip rear differential
• Gaz adjustable dampers
• Wilwood 4 piston front brakes
• Clutch Masters aluminum flywheel and clutch
• Speed Hut custom gauges with GPS speedometer
• G Force 5 point safety harness
• Newton fuel filler
• Full stainless steel fuel lines with AN fittings
• Light weight 949 Racing 15” X 7” front and 15” X 8” rear wheels
• Toyo R1R 195/50 front and 225/45 rear tires
• Tonneau cover
• Quick release steering wheel
• Birkini top
• Full satin black powder coated trim
• Full width rear diffuser with extended floor pan
• Hella 5 ¼” headlights
• Braille 9 ½ pound battery
• Raceline wet sump oil pan
• Cockpit heater with 3 speed fan
• Heated wind screen
• Color coat clear coat Viper Red paint with a Black stripe and nose band
This car is located in Colorado. If you have any questions or would like to arrange a showing or a demonstration ride please e-mail or call Tom at 970-376-5188.
This car is FOR SALE locally and the auction may be cancelled at any time.
Thank you for looking.
I am a Birkin Representative and built the car to sell. I enjoy building them.
Tom
Edited by Tbox56
Looks good. I thot that Texas Motor Works was the only authorized dealer/representative but I was obviously wrong. When did you start selling them officially? Do you get your kits thru TMW, or straight from S Africa?
Thank you for the nice comment. I have worked with Dick in the past and have just recently started working directly with the factory.
Tom
Very nice!
You might want to put a "buy now" price to give people an idea of what your looking to get (I'm sure it's more than the $25 grand bid)
The car did not sell on ebay. I had the reserve at $45,000. If you are interested in the car give me a call or contact me offline and we can discuss it further.
Thanks,
Tom
970-376-5188
  • 2 years later...
I have a container of the latest narrow body Birkins due to arrive in a month and would like to sell this car. I will be using one or the new cars as a demonstrator. This car now has about 1100 miles and has been trouble free. I will consider offers in the range of $41,000. Replacement cost would be in the mid $50's.
Thanks,
Tom
Birkin Direct-USA
http://www.birkindirect-usa.com
970-376-5188
