I read a post by a guy with a Cobra replica that ran no air filters for over 50k miles with no discernible damage to anything in the engine internally. He just changed the oil every 1000 miles or so.
BT
An intriguing, arguably sevenesque vehickle (after quite a few drinks)
http://www.ebay.com/itm/161440921603
A Velocity Exo Contour. 2.8 V6, 5 speed "tiptronic" out of a VW Passat. 1760 pounds with 190hp so a respectable power to weight ratio. Seats look comfy. Chunky rear tires. Not sure about the slab looking front view? Interesting car to check out. Current bid $10100 with reserve not met and 1.5 days to run.
BT
Must have been a Superformance owner :svengo:
Speaking of Superformance owners, I just found this lovely specimen 1965 Superformance S-1 for sale in Wilmington DE. I have see this car in person at the Carlisle Kit car show back in 2009 (I think that was the year) - it was in beautiful condition then. Great color.
http://www.ebay.com/itm/Lotus-Super-Seven-Super-7-Superformance-S1-/321544323842?forcerrptr=true&hash=item4add890302&item=321544323842&pt=US_Cars_Trucks
Buy it now is $21500 with 4 days left to run on the "make me a bid"
Dang, #6 of 53 ever made. And I have #55. Curses.
Tom
BT
You can't do that here in the desert. If I leave my car outside for one day, it's covered with a fine dusting of decomposed granite. Sure it will run fine for a few thousand miles, but the rings and cylinders are wearing thinner.
As far as performance is concerned, it's losing power compared to well designed intake runners. Those sharp edges at the carbs are cutting max power by at least 5%.
I too have seen this car at Carlisle....He has had it for sale for 2+ years at that price, with all of the spares he has for the car, I'm extremely surprised that nobody has snapped it up yet. Think it is most likely the way it is titled that has this one going unsold for so long.
Wonder if the wife would notice it suddenly appear in the back garage :D
Bill S.
Edited by mrmustang
The SV is a Caterham too! :rofl: The SPF S1 is slightly narrower than an Caterham SV but wider than the Caterham S3. I fit in the S1 and I am a monumentally fat bastard so I would say go give it a try.
Mike,
My son and I met the owner on the turnpike and drove out to Carlisle , your correct
with the year. Owner is a stand up guy....
Here is a Lotus Seven S2 for sale on Fleabay in MA
http://www.ebay.com/itm/Lotus-Super-Seven-cosworth-1964-lotus-super-seven-restored-excellent-driver-/331336583869?forcerrptr=true&hash=item4d25330abd&item=331336583869&pt=US_Cars_Trucks
Bid is at $20100 with reserve not met. From the ad:
Series 2 Super Seven Cosworth
Current owner since 1997, previous owner from early 70's known personally and still in touch. Previously raced in the midwest. Authenticity checked via Lotus Seven register in England, have original chassis plate, matching frame number, original Weber carbs. This is one of the nicest, most drivable original Lotus Sevens you will find. It has enough original details to be turned into a show car, and enough updates to become a race car, but really, buy it and drive it, it is what they are made for.
Rare details include original Cosworth intake manifolds, exhaust header and cam cover.
restored 1999
chassis reinforced, including diagonal bracing of cockpit sides, engine bay bottom, connecting rack mounts, tubes down floor in tunnel with trans mount. frame acrylic urethane painted
new red lamiplate cockpit sides and dash
all new alloy
wind wings
new rear wings and nose, restored original front wings, Glasso urethane red
custom pedal box extended 1 inch
New stainless exhaust
Wingard tail lights
reinforced TR10 axle
Triumph Tr7 final drive[3.64] with large diameter axles
Quaife limited slip
semi close gears
completely rewired
custom real red leather seats
Nicely ported precrossflow over 701M lower end, .06 over twin cam bore
gear reduction starter
55 amp alternator
AC gauges [proper Tach and Speedo, temp,oil are close. has VDO fuel gauge]
Bosch radiator fan, original radiator
custom lower/wider fuel tank gives additional storage space
Period cosmic alloys, have set of lotus wheels[in need of paint] and chrome hubcaps
kept original bonnet and scuttle, original fuel tank, headers, original pedal box,
Mileage is approximate
Can take anymore pics required. Weather has cleared, so may take it out for a video run, check back for it
Have available additional red lamiplate to make new dash to delete[non original] fuel gauge if desired, but do you really want to carry a stick around?
This is a really solid, fun car, and it is a real one, so if you really want a Lotus, not a something else, and you don't need a project, this is the car.
Ok its time for the weekly morning coffee search for sevens. Usual rules - no affiliations or connections to me - just reposting as a service to show what is out there for the prospective shoppers/dreamers/"time wasters":
1973 Lotus/Caterham Seven
Its still out there - same one from previous weeks with 17k miles, twin engine and 4 speed box, asking $33990
http://www.ebay.com/itm/Lotus-Super-Seven-Caterham-S3-1973-super-7-2-owners-13-k-orig-mi-surviovr-s-match-twin-cam-big-valve-/331340421081?forcerrptr=true&hash=item4d256d97d9&item=331340421081&pt=US_Cars_Trucks
Its so nice to actually see Birkins for sale rather than handbags when you go looking.
Nice looking 2002 Birkin in Buford GA, listed last week with the playground monkey bar sized roll bar. 2L zetec with 5 speed T9 in yellow upper body, ali lower body with dark green (I think) fenders/wings. Asking $31950
http://www.ebay.com/itm/Lotus-Super-Seven-2002-birkin-factory-built-version-of-1967-lotus-super-seven-ford-zetec-engine-/251665980600?forcerrptr=true&hash=item3a98761cb8&item=251665980600&pt=US_Cars_Trucks
2013 Birkin at Land Rover South Carolina is back at $36616 buy it now. IRS, 2L Duratec, 5 speed T9, nice looking panasports, black with only 650 miles.
http://www.ebay.com/itm/Lotus-Super-Seven-Birkin-S3-2013-lotus-seven-birkin-s-3-2-0-duratec-irs-profesionally-built-/151436177367?forcerrptr=true&hash=item23424cafd7&item=151436177367&pt=US_Cars_Trucks
2003 Superformance S1 in dark green, included here again for completeness. Asking $21500 buy it now in DE.
1964 Lotus Seven S2 listed in the last few days on this thread and included again for completeness. $20100 bid with reserve not met.
Lotus Seven replica project. Bid $910 with reserve not yet met in FL.
Space type frame. Frame was just media blasted and ospho'd
Subaru outback independent rear suspension not mounted just mocked up.
Four new 5 x 100 bolt pattern 18 inch wheels with 2 (95%) tires mounted .
A-arm front suspension with Subaru calipers.
Fiberglass body includes rear section beautifully done,hood and two front fenders.
Steering column, pedals.
This was completed car at one time.
This includes manual "Build your own Sports Car on a budget", by Chris Gibbs and 2 Brand new T-shirts, woman's blue, man's green.
http://www.ebay.com/itm/Lotus-Super-Seven-NA-Lotus-seven-project-/161441664316?forcerrptr=true&hash=item2596ac4d3c&item=161441664316&pt=US_Cars_Trucks
Reserve is somewhere closer to $1500 per the Craigslist ad I found for the same car
http://tampa.craigslist.org/pnl/cto/4697258503.html
Bargain of the week possibly. A 2003 Superformance S1 in black. Asking $14000...wow! I think this is a USA7s forum member's car and I can see he is a reluctant seller. Smartest seller I have seen - codes the ad with all the right search words to be easily found - give the man a beer! :cheers:
http://palmsprings.craigslist.org/cto/4696850426.html
Same seller as the S1 with a Ultralite S2k asking $27500 with a great spec
Engine Honda S2000 2L 16 valve DOHC V-Tec™
Aluminum In-Line 4 Cylinder
Horsepower 240 @ 8300 rpm
Torque 153 lb-ft @ 7500 rpm
Displacement (cc/cu.in.) 1997/121.9
Weight 1240 lbs / 524 kg
458 HP per ton (1000 kg)
1 HP per 5.16 lbs / 2.18 kg
Transmission Honda S2000 close ratio 6 speed
0-60mph/98kmh 3.5 sec
Wheel base 88" / 223,5 cm
Track front 59.5" / 131.3 cm
Track rear 61" / 155 cm
Height 33" / 84 cm
Length 124" / 315 cm
Width 68" / 173 cm
Turning circle 26' / 8 m
Wheels 17" x 7" aluminum
front 225/45 * 17
rear 245/45 * 17
Brakes Front 12" drilled solid rotors, with forged alum. 4 piston calipers
Back 10.5" solid rotors, with forged alum. 4 piston calipers
60 to 0 mph in 100 feet
Fully adjustable pedal assembly
Steering Turns lock to lock: 2.75
Suspension Shocks: aluminum coil overs
Rear: Subaru WRX with Limites Slip centers, hubs and axles
10 bars IRS differential
Cooling Radiator: aluminum with two 1" cores
Coolant recovery system
Safety features In chassis integrated Roll Bar (not bolted)
Master battery cut-off on dash
Aircraft grade hardware and locknuts
Detachable steering wheel
Seats and carpet marine grade flame retardent
Aluminum racing seats with 3" 5 point harness
Crash zones front and rear
Center backbone and dash panel bracing
Drive shaft loop
LED taillights
Chassis material 1" X 16 ga. round and square DOM and 1-1/2" X .095 DOM Powdercoated
http://inlandempire.craigslist.org/cto/4696364122.html
The new build 2013 Caterham CSR with F1 team colors is back at a price of $79500
http://sfbay.craigslist.org/nby/cto/4700333894.html
Electric (or is that eclectic?) blue project car from Janesville WI is back for $1500
http://janesville.craigslist.org/cto/4674910930.html
This Lotus 7 replica project car has periodically emerged for sale over recent time $5450 in Huntsville AL
http://huntsville.craigslist.org/cto/4672068031.html
And here is the last one - 1974 Lotus Seven S4 in CO asking $29900. A repeat visitor to this thread.
http://denver.craigslist.org/cto/4706549273.html
Lotus Super 7 D Modified SCCA Street Legal Race Car w/BDR Cosworth Engine. It's a turn key SCCA vintage Lotus racer.
It's sad to part with my 1974 Lotus 7 S4 (The final final Original Lotus 7) Car. It is a Spec D Modified Race Car with a Formula (Lotus) Ford BDR 1700cc 16V (not A, R is more desirable) engine - tuned and setup for the street. The Engine is fully rebuilt with about a couple hundred miles on it and was rebuilt in the mid 90's, has the Firebottle system installed, Accu-pump Oil pressure system, Sump pump system, new battery, and a whole lot of other modifications - too many to list. I have most all of the receipts, restoration (body & engine) photos and also have many of the original and extra bits like the glass panels, top, side door panels, tire bracket in the rear, engine blanket, et al. Also, I'll throw in hoosier slicks (2 pairs) and wheels if the price is at asking. Currently the motor has a pair of Weber DCOE 45's and shifts really smooth.
Car runs really strong. The frame is strait and no accidents. The car is sprayed in the GM Corvette Perl White with a few minor flaws.
It's a lot of fun to drive around.
Clear Colorado Title. My car is located in Denver.
Asking: $29,900 / ob serious offer or reasonable trades welcome (specifically, Early Porsche's)
Edited by Croc
added some more ads
The $14,000 SPF S1 is a scam. I got the "I'm on a research ship, you can send me a deposit and I'll get you in touch with my friend to finish the deal" response.
Let the potential buyers beware
I figured as much, given the price and the fact that the seller of the WCM Ultralite whose ad details were partially copied knows the value of such things and did not mention here that it was for sale. I did a google search on the picture in the craigslist ad and found where the craigslist scammer got his photos from: http://www.ebay.com/itm/191342767206
I was just thinking that the pictures looked exactly like the one that's been for sale in Ohio! Another CL dirtbag.
A dirtbag, for sure; but, at least his prey is a wealthy first worlder who wouldn't miss it. Someone who would send $14k to an anonymous person somewhere unknown on the planet in hopes of buying a toy at a discounted price. (That is how this ends up if he hooks a fish).
It annoys me because I know that the fish he hopes to land looks just like me and many board members here as far as age, sex, financial assets. I hate to think one of "us" is still naive enough to swallow the hook, line and sinker; but, it isn't impossible, so, these guys keep on fishing. They don't even have to invest in a boat, trailer, truck, tackle or beer for their sport !
