GunshipDriver Posted July 9, 2014 Share Posted July 9, 2014 Anyone use LED lights on their seven? I've done some research on them in general and would like to make the swap. Also, anyone eve get harassed or a ticket for not using dot approved lights? I'd like to remove my current headlights from my S2K and replace with LED lights mounted in the noise cone / cowl. Link to comment Share on other sites More sharing options...
xcarguy Posted July 10, 2014 Share Posted July 10, 2014 MightyMike uses LEDs. Link to comment Share on other sites More sharing options...
coffee break Posted July 10, 2014 Share Posted July 10, 2014 I guess the only time DOT inspection might happen is if you get stopped. This is something I like to avoid. I luckily was behaving when passing two radar traps this afternoon. :cooldude: Link to comment Share on other sites More sharing options...
MightyMike Posted July 10, 2014 Share Posted July 10, 2014 My LEDs are DOT approved - pricey though. http://i62.tinypic.com/nl8so4.jpg Link to comment Share on other sites More sharing options...
GunshipDriver Posted July 10, 2014 Author Share Posted July 10, 2014 Nice setup MM. I've also given thought to mounting lights atop the front fenders so they would point where you turn... Link to comment Share on other sites More sharing options...
MightyMike Posted July 10, 2014 Share Posted July 10, 2014 Thanks! I would not recommend mounting your lights on your fenders as they would bounce up and down like a pair of floppy tits. Link to comment Share on other sites More sharing options...
jevs Posted September 13, 2014 Share Posted September 13, 2014 (edited) I am doing LED headlights as well. GE Nighthawks. Right now you can get $100 off each headlight on Amazon with the "clip coupon". However, it is one per account so I had to order one and then my wife ordered one. Saved $200. $305.96 shipped for the pair (looks like they are 310.06 a pair today). These also look closer to normal headlights than the others I was able to find (if you somewhat want to keep it period looking). http://www.usa7s.net/vb/showpost.php?p=89210&postcount=49 They also say these are the same as Trucklight, but I think they have changed. They now have a strip in the middle with the GE logo. Edited September 13, 2014 by jevs Link to comment Share on other sites More sharing options...
RGTorque Posted September 13, 2014 Share Posted September 13, 2014 is it possible to remove that strip? Link to comment Share on other sites More sharing options...
jevs Posted September 13, 2014 Share Posted September 13, 2014 Only if you want to try to get the sealant loose on the lens. Link to comment Share on other sites More sharing options...
jimrankin Posted September 13, 2014 Share Posted September 13, 2014 I wanted to keep my headlights with the LED ring turn signals so went with the "New Bright's LED" replacement bulb units. Lot of stuff to fit into a standard bucket but it all went in OK. Replaced my H4 Halogens. Haven't been out at night, or even aimed them yet but look pretty bright in the garage. The light has a separate ballast and a fan at the back plus all the wiring to stuff in. I decided to pop rivet the ballast in place as it seemed too heavy to just stick in with tape or try to make epoxy work on the round bucket and square ballast. Link to comment Share on other sites More sharing options...
jevs Posted September 13, 2014 Share Posted September 13, 2014 Is that a fan? I am not sure it is going to do much inside a bucket if it is. Link to comment Share on other sites More sharing options...
jimrankin Posted September 14, 2014 Share Posted September 14, 2014 I'm debating the need for drilling some cooling air holes in the bucket. There should be enough exposed metal in the headlight bucket to radiate heat to the outside air. The LED's produce less heat than the H4 Halogens they replaced and the fan is just to move air over the heat sink at the base of the bulb. When I get the chance I'll drive around in the heat of day and see if the bucket gets too warm. Mostly will have the lights on when it's night so probably cooler air moving over the bucket. Link to comment Share on other sites More sharing options...
