Everything posted by Gherkin
Resurrecting an old thread alert! I am running a 2.0 Duratec in my Birkin and also have an issue with the warm-up time seeming long. Now, to throw a few variables in, I am running a Davies Craig electric water pump with their pump and fan controller. The max temp is set at 190* and the pump and fan seem to be functioning as designed, gauge rarely reads over 195* even on a hot NorCal day. The pump controller runs 10 seconds on/30 seconds off to 20c below the set temp then 10 seconds on/off to within 5c of set temp then full on.The odd part of the system is that it is set up to run the coolant in reverse to the stock configuration. Water is drawn from the thermostat housing (no thermostat) by the pump and run into the bottom of the rad. then out the top to the manifold at the back of the head. The temp sensors (ECU, Gauge, pump/fan controller) are between the thermostat housing and pump so they are seeing engine temp water. My main question is: Does the coolant flow direction really matter if there isn't a thermostat in the system?? Thanks, Chris
Anyone in NorCal with standard body S3 chassis?
Gherkin replied to KnifeySpoony's topic in General Sevens Discussion
I intentionally avoided the term "roomy"... I don't track my car, for street it works for me but maybe in the more dynamic track environment it would be nice to have a bit more room. -
I'm 6'-2" and about 255lbs and drive my Birkin S3 pretty comfortably even on a 100 mile day. Standard floor with the Birkin padded "shell" style seats and fixed steering wheel. The seat is moved back as far as it will go and the pedal box is as far forward as the adjustments will allow. And yes, I need to wear my skinny shoes in order to use one pedal at a time. I do have to look through the top of the windshield frame some of the time. I'm in NorCal about 30 miles east of Sacramento, if you find yourself in the area you are welcome to have a test sit. Chris -
The weather is here, wish yours was beautiful too.
Gherkin replied to Shoe String Racing's topic in Seven Videos
He took the shortcut home, we went the long way as should always be taken (when the wife allows, of course...). Chris -
I have a very similar car from TMW that I rebuilt and detuned to get all dialed in and am in the process of bringing the HP back up. The car is an absolute hoot, you'll love it!
led replacements for the lights (specifically headlights to start with)
Gherkin replied to mbwever's topic in General Tech
I don't believe so, the DOT headlight replacements all seem to be pretty pricey with the JW Speaker units often leading the way. There are companies pushing H4 LED replacement bulbs but stay away from the low cost units as they often produce less light than the halogen bulbs they are replacing and some only allow one beam, no high/low function. Also scattered light can be a real issue with the lower cost replacement bulbs. If you are concerned about street legality anything but a certified complete replacement insert will not pass inspection. Another unit from a competitor is this one from KC but I haven't seen them in the wild yet... http://www.kchilites.com/catalog/product/view/id/640/s/7-led-headlight-set-dot-street-legal-kc-42321/category/36/ Chris -
They do but the automotive lamps are slightly different to keep the Harley unit exclusive. -
As much as I hate to recommend a competitor... http://www.truck-lite.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10001&productId=92025 http://www.jwspeaker.com/products/headlights/#product=500463 These are both popular conversions that are DOT/SAE legal. The Truck-Lite product looks a bit more like a conventional lamp. Chris -
Engine Machine Shop in San Jose Calif?
Gherkin replied to khamai's topic in General Sevens Discussion
Kiyoshi, I have a customer in Walnut Creek that is a well respected machine shop in the Bay Area. This is a pretty old school shop that does machine work on all sorts of engines from american V8's to Ferrari. They have vintage Ferrari blocks sent to them from all over the country and some international. Morgan's Machine and Marine 1285 Parkside Drive Walnut Creek 925-939-7346 Ask for Chris and tell him that Chris from PIAA sent you Chris -
Gherkin replied to Croc's topic in Cars For Sale
Careful now, I resemble that remark! Wait... The Californian part, not the Russian brides from xcarguy's searches. -
Yah, I saw that picture and thought "wow that oil filter is going to hang really low, I hope he has a skid plate for it..." Being a Duratec I was also surprised you could run the S2K engine on its side. Thanks for clearing that up. :jester: Chris
You will want a cam locking tool for this job as mentioned in an earlier post. These kits (at least the Duratec units) usually come with thread in crank stops as well. Example here on eBay: http://www.ebay.com/itm/Massive-Absolute-Cam-Timing-Alignment-Tool-Set-Pin-Bar-Zetec-2-0-Focus-SVT-ST170-/261508694272?hash=item3ce3220100&item=261508694272&pt=Motors_Automotive_Tools&vxp=mtr Chris
Great video, looks like a great time! Running well over 140 in an open car must be a rush. Now, a bit off the subject but... Can anyone explain the odd camera movement and the flexy look it gives the roll cage? Chris
Birkin S3 reliability/ownership
Gherkin replied to DreamofBoost's topic in General Sevens Discussion
Hi Martin, First off welcome to the forum. I own a supercharged Duratec Birkin built by TMW and would love to give you any insight I have on the car and TMW. Dick is a good guy, helpful and as you said he is passionate about these cars. With that said his mechanic does not necessarily do things the same way I would. I purchased the car from TMW and it was very honestly described as a whole, any issues I had with the car laid mostly in the details. A car like the Seven will always need some sort of fetteling, it's part of the "charm", but I did need to change/fix a few issues from the original build. My car has a bit of a history so its needs included many of the issues Kitcat mentions and went above and beyond. Any "home built" car like these should be gone over carefully when built by someone else. Once the car is all dialed in it should be a reliable, insanely fun, driver. Since these are practically race cars for the street you will find they are more work than most production cars, especially a Honda, mostly in routine going-over to check bushings, bolt/nut torque, etc. Much like the S2000 the Duratec engine is reliable, parts are readily available, and there is a lot of support in the tuner community. I didn't have any allegiance to a specific power source but I like the slightly lower hood (bonnet) line offered by the Duratec powered cars. I'll PM you my contact info, please don't hesitate to reach out with any questions or concerns. Chris -
Email sent today. Chris -
48 mm offset seems a bit high for these, usually a 7" wide wheel will be around 40mm. I had them done at the Cameron Park Big O, they have done stuff for me before and are good if you make sure they know it is something special. I believe the manager at the EDH Big O is still Chris, he is good too.
I'm running 195/50-15 front and 225/45-15 rear R888's on my Birkin and love them. So far they have proven to be very grippy and predictable, except for that time I came across a late spring patch of snow around a blind curve on Mormon Immigrant Trail, that was almost :willy_nilly:! The fit is great, fronts are about like the pic you included and rears clear with no problem. I'm running 15x7 wheels with 38mm offset. Chris
Holy crap, that thing can hog out some material in those early stages! I saw the video was 13 mins long and I thought "I won't watch the whole thing". Call me a process nerd but I couldn't stop watching! Thanks for sharing. Chris
Continuing the thread derailment... Yah, what they said, and is it loud? Also, Wings can you give us a wider shot of your "garage"?
Beautiful car Mark, I like the all black treatment. Welcome to the addiction (or affliction), mine was a bit of an impulse too but it doesn't take long to become all consuming, not that that's a bad thing... Looking forward to getting together for a blat! Chris
You'll never see a DNF on record for the Birkin F1 team... I'm just say'n.
Welcome to the forum! As a satisfied Birkin owner I like your choice in cars... Not blue but has some carbon and the price seems right... http://birkindirect-usa.com/pre-owned/ I'm not affiliated with the car but this example is being brokered by Birkin Direct USA. Chris
Great chronology laid out there, thanks! I work for PIAA and it's nice to see the 1989 Type 101 on display still showing the sponsorship love...
I saw this car at SEMA and it is amazing. The attention to detail and craftsmanship on a BEAST of a car make it the ultimate in functional art. Not my pics... http://www.tunedph.com/wp-content/uploads/2014/11/Hoonigan-3.jpg http://www.drivingline.com/wp-content/uploads/2014/11/ford_hoon2.jpg
