bball7754
  1. Temp was normal for a track day - even after I started steaming (which I think was just the overflow tank, umm..., well, overflowing and coolant hitting the exhaust headers) the temp didn't go much over 90 c. There was one modification made to the cooling flow. There is a heater connection on the water pump and a another on the intake manifold. I don't have a heater, so the two were just connected with a length of hose. He removed the hose, and sealed both connection points. But, that's what he does on all the Formula Ford engines, and they don't have an issue with overheating. And the sound on the video is hard to hear, so the tinkling sound could have been something else vibrating. Octane should have been 93 - but that was one theory thrown around the shop that day. Bad tank of gas - maybe filled with the wrong octane, so could have been running with 87. What worries me (and my engine builder) the most is that there hasn't been any kind of definitive explanation. So, it's currently being rebuilt just as it was the first time.
  2. Timing is still what I'm thinking, but he said total advance was 35-36, which should have been ok. I didn't think of the pre-rebuild tune as being that radical, so using the same total advance should have been ok - but, maybe the timing was off and it was more than that. If you look at the AFR on the dyno sheet (the Dyno run PDF) it stays around 12.5, so in theory (again) not too lean. He thought he was going to need to change the jets, etc. on the Weber's, but the AFR was fine and consistent, so he left them the way they were.
  3. No bent rods or valves. There also was no evidence on the valves of them being hit by pieces of the piston. I didn't show all the pictures, but the pistons on cylinders 1 and 2 were also damaged in the same way, although not as extensively. And those cylinders were dry - no coolant in them. There was quite a crowd at his shop that day, including his next door neighbor who I believe now holds the land speed record in whatever class an Audi A4 would be in. Think he's making over 1,000 hp out of the Audi 4 banger. Anyway, everyone was pretty mystified. But because there was no shrapnel damage, they were characterizing the pistons as having melted. And when all is said and done, the only real change to the tune was upping the compression ratio. Same cam, same valves, miminal additional porting of the head, same distributor and curve. So, really didn't expect this. Jerry - now you know why I haven't returned the engine hoist.
  4. After close to 45,000 miles and many track days, my Crossflow was in need of a refresh. I spoke to a known Formula Ford engine builder (30 years experience), who was willing to do the job. The spec on my engine was some head work, Hepolite cast pistons, Kent 244 Cam, double valve springs, and roller rockers. It’s the “150 hp” spec. The only thing I knew I wanted was to upgrade to forged pistons. He recommended I replace my crank with the SCCA SCAT crank. While not as robust as a forged crank, it was about a third of the price and would allow me to confidently move my redline from 6500 to 7000-7200 rpm. Pistons were ordered from Burton’s in the UK, along with a new set of springs. Main bearings were replaced, the block bored and honed, some cleanup of the head work, rebuild the carbs – fairly basic stuff. Cam was in good shape, so that went back in. Replaced the clutch, which I sent to him and he balanced the crank/flywheel/clutch as a unit. Also brought the compression ratio up from around 9.5 to 10.4. He called me when it was finished, and was both happy and surprised that it made 157 hp at 7200 rpm. Dyno run.pdf https://picasaweb.google.com/lh/photo/fwVqNSWYLVDXoTLED1fIDnM5pEeHaNF-jFxcQZ5j3uY?feat=directlink Fast forward (skipping over fixing my leaking transmission) to the NJMP track weekend. At this point I had about a grand total of one hour of road time on the engine. First session starts, and I’m excited. The car feels lighter, and it’s still pulling at the end of the main straight as I get to 7000 rpm. This is going to be a great weekend! As I’m coming down the main straight at the end of my 5th lap, the engine seems to go “soft”. Through turn one, and it seems to be missing a bit. Then it’s missing more, then it’s really running like crap, now I have steam coming out from under the bonnet. I limp towards the pits, kill the engine on the pit entry, and coast toward where we’re all parked. I take the bonnet off, and there is coolant all over the place. The coolant catch tank is completely full, and clearly had overflowed. I also notice that there is coolant dripping out of the exhaust. I call my engine builder and we have a long discussion. He thinks I may have split a cylinder wall. Suggests I let it cool, then pull the plugs and turn it over. Which I do, and shoot a geyser of coolant out of cylinder 4. Call him back, and he suggests I drain the coolant, and spray WD-40 in the cylinders and both the intake and exhaust ports. Which, again, I do. The following Friday, I drive back to his shop with the Crossflow. He has another owner there, but he immediately pulls the head off – and here is what we found: https://picasaweb.google.com/lh/photo/b9hQjWlt5MZN5sYAjqgW83M5pEeHaNF-jFxcQZ5j3uY?feat=directlink https://picasaweb.google.com/lh/photo/BBzK1GmJ8DL34kNBK3pfdXM5pEeHaNF-jFxcQZ5j3uY?feat=directlink https://picasaweb.google.com/lh/photo/FwTe-H96pImxnJTQC74ObHM5pEeHaNF-jFxcQZ5j3uY?feat=directlink https://picasaweb.google.com/lh/photo/ZfpBFnggSIDhiY7qspIELXM5pEeHaNF-jFxcQZ5j3uY?feat=directlink Which is not what he expected. Now, the blown head gasket and subsequent coolant in the cylinders are a symptom, but not the cause. Conjecture has centered on overheating, but to be honest I’m not sold. I had borrowed a camera and microphone from Croc, but unfortunately the sound is distant at best. If you turn the sound up all the way, though, you can hear the engine. My first 5 laps are here – jump to 9 minutes 30 seconds to skip me getting into the Seven, wandering around the paddock, and sitting in line: http://youtu.be/OFXx0S3UucM There is a tinkling/pinging sound whenever the engine is under load. And the temp gauge (right gauge of the center two) sits around 80-85 centigrade the whole time. So, maybe timing? A really bad tank of gas? Both? Here is the lap where it all went south: http://youtu.be/Rv679Jb7UFc About the only good news in all this is that the cylinders cleaned up, and another rebore wasn’t necessary. It should be all back together in the next week or two, but not knowing why the pistons melted has me real nervous. Steve Dyno run.pdf
  5. Mike - I use the Prodigy RF and it's worked well. The Volvo tow package came with a 3-prong connection. By using the Prodigy, I was able to just have a power line run directly from the battery and switch the 3-way to a 5-way. Didn't have to splice into the harness, which I understand can make the computerized systems unhappy. Plus, no ugly brake controller in the car that's only used 1% of the time. Steve
  6. Nicely done. Agree that you probably won't notice any difference due to the filter change. The trumpet length change, on the other hand....... http://www.emeraldm3d.com/articles/emr-adj-length-intake/ Steve
  7. My Caterham has a spacer/adapter for the knob. It fits over the T9 shift lever, and has a larger thread for the knob than the lever itself. The knob itself is "rubber", and looks like it came from the Merkur/Sierra.
  8. Mike - You beat me to it. MichaelD's generosity definitely took a bit of the sting out of loosing my engine. And, it was interesting how driving his Seven was the same as driving mine - but also very different. And not just the additional power. Thoroughly enjoyed my two sessions, although when the engine started sputtering in the first session I was bit nervous. Then I noticed the fuel gauge was on "E". That Zetec sure can drink it in. Steve
  9. I'll be driving down from north NJ on Friday. Based on my experience last year, assume I should avoid the NJ Turnpike and come down on the GS Parkway? Looks like the construction is still going on. Steve
  10. Tom - Thanks. Passing rules are different between the two Intermediate groups. Looks like we can pass anywhere. Steve
  11. Anyone know which of the Intermediate groups we're in? I'm thinking probably the Yellow? Steve
  12. Mike - Still haven't pulled the trigger on a video camera purchase, so would be interested in your loaner offer. Should be arriving mid-afternoon on Friday. Steve
  13. Mike - I think it had been leaking at the front into the bell housing for quite some time. Believe the rear leak was relatively new, and was likely because all three of the left side bolts had come loose. Tom - I haven't done my yearly polish yet, but have been debating whether to try and squeeze it in before NJMP. We'll see. Steve
  14. Ok, good news update. Decided to use a local shop that has done lots of work on a friends Lotus 11. Before I dropped it off, pulled the bell housing off and found that there was no gasket between the gearbox and spacer. So, reason for front leak found. Left the gearbox at the shop on Monday, received the gasket/seal kit on Tuesday, and picked up a "resealed" gearbox this afternoon. So, install tomorrow, drive on Sunday. Steve
  15. Pierce manifolds and Weber Carbs Direct are good sources for Weber parts. I've purchased parts from both. http://www.piercemanifolds.com/ http://www.webercarbsdirect.com/ The Caterham linkage is simple and, I think, unique. It's not listed on their parts site, but an email to their parts department should answer whether it's available. Working from memory, your spec's look the same as what's on my Crossflow. Previous owner was in Denver, and it came with the 115 mains. The only change I made was to go to 120 mains. I'd start with checking that the carbs are in synch first. I also read somewhere that 90% of carb problems are electrical. Steve
  16. First, let me correct the side that the drip is on. It's the left rear, not the right. Tightened up 4 of the 6 - couldn't figure out a way to get to the top two, including using u-joints and extensions. But, both the middle and bottom left were loose. Used 35 ft lbs, and the right bolts were fine, the left took maybe a quarter of a turn or so. But - it didn't help. It's leaking around the middle bolt between the alloy bearing plate and gearbox. I could wipe away the fluid, and then watch it reaccumulate on the gearbox. Suppose it's possible it's running down from around the top left bolt, but I couldn't get my hand up there to feel for fluid. So, definitely coming back out now. But after looking at the instructions to get the alloy bearing plate off, I think it's over my pay grade. Opinions on whether a good local transmission shop (assuming I can find one) would be able to replace the rear gaskets and seal? Shipping the gearbox and extension half way across the country seems like a more difficult solution approach than should be needed. Steve
  17. Bob - In case you can't tell, at this point I'm not positive of anything. Appreciate your input, and will pull the tunnel cover off tonight and see if I can more accurately find the source. Don't think it's the speedo connection, as it's on the other side of the trans and I didn't see (in my quick check this morning) any evidence of it traveling across the trans. Also don't think it's the rear seal the propshaft runs in, for pretty much the same reason - no evidence of fluid running down the bottom of the tailshaft housing. Should be fun to try and tighten those six bolts with the trans in the tunnel. Steve
  18. The plot thickens. Thought I would try to confirm that the leak was at the front of the trans. Put the car on jack stands, wiped down the bottom of the trans, started the engine and ran it till it warmed up - including revving it. Looked under the car, and there was a nice 6-8" puddle - at the rear of the trans. The drip was on the left hand side of the trans at the rear corner, but definitely on the trans side and not on the extension housing. I'll have that gasket and seal in my kit, so guess I can replace them, although removing the extension seems more complicated than removing the bell housing. I've also read that excess fluid will come out the breather - but confess I didn't notice a breather while I had the trans out. By any chance is it at the right rear of the trans? Haven't pulled the tunnel cover yet to take a look.
  19. Gasket and seal kit ordered from Quantum Mechanics. I'll start on engine/trans removal tonight.
  20. Good news, I think, relatively speaking. Called BGH over in the UK this morning, and had a long conversation (30 minutes or so) with .... someone, maybe Brian? Anyway, my major concern was the vertical play in the input shaft. Per BGH, this is totally normal - it's how it's designed. He also said that, at least in the past, Caterham didn't put a gasket between the gearbox and bell housing. The selector shaft apparently acts, somewhat, as a pump, and with no gasket a leak can develop between the box and bell housing. It's also possible that the front oil seal is worn. So, my plan now is to pull everything back out, then replace the front oil seal, the CRB nosecone gasket, and replace/add the box to bell housing gasket. Prior to the engine rebuild I was not experiencing any clutch slippage, so don't believe the CRB nosecone lip seal is leaking. Wasn't aware of that seal, and haven't seen it listed, but maybe I should also replace that one? I think the box itself is fine. Anyway, my hope is that all of this will work, and I'll be at NJMP in 3+ weeks. Steve
  21. Mike - Thanks for the lead on Midatlantic Caterham. I'll give them a call tomorrow, as well as Quantum Mechanics (http://www.quantumechanics.com/qm-htm/home1.htm). Tackling a rebuild of the T9 is more than I want to take on, or feel comfortable with. Plus, it would probably take me 6 months to do. I'm also actually considering just replacing the gearbox. BGH has a long first Road and Track box that doesn't seem totally unreasonable. More than a rebuild, but I'd get better ratios, etc. Shipping wouldn't be cheap, but probably worth a call/email to investigate. Not sure they have them built sitting around, though.
  22. bball7754
    T9 Woes
    When I pulled my Crossflow for a rebuild, the inside of the bellhousing was an oily mess. The smell test didn't indicate transmission fluid, and I decided that it was engine oil (being apparently somewhat in denial), and cleaned it up. Prior to reinstalling everything, I did notice that the gearbox input shaft had quite a bit of play in it - it wiggled up and down more than I would have expected. But, remaining in denial, I put it all together and reinstalled. Started the engine up for the first time yesterday while it was still up on jack stands. Noticed that there was trans fluid around where the clutch arm comes through the bellhousing. Hmm... Went for the first test drive, and when I got back there was trans fluid dripping from the bottom of the gear box. Appears to be coming down from the spacer between the box and the bell housing. It's possible I overfilled the gearbox slightly, but would that really account for this? I have a new gasket for the CRB guide, but obviously didn't install it. I also understand that fluid can leak from around the selector shaft that comes through the bellhousing. Thoughts? Anyone know where I can have a T9 rebuilt - quickly? Steve
  23. I'm partially able to justify the 1000 mile tow by visiting my family in NJ (I'm a native). But I would make the trip regardless. Steve
  24. These would be brand new. My current RA1's are pretty much down to the "slick" level. Maybe it was the track surface, but at COTA in Austin my tires were squealing more than usual, and didn't seem to have much grip. I'd read somewhere that tires should be replaced after 5 years, so I'm thinking maybe it's time.
  25. After 5 years, I think it's time to replace my Toyo RA1 track tires. The set I have started out as full depth (one of the reasons they are still alive - and let's not talk about other possible reasons having to do with my track speed ). I thought I'd go with having the new set shaved to either 6/32" or 4/32". Any recommendations or experience with dealers regarding the quality of their shaving? Thanks. Steve
