EdWills
Everything posted by EdWills
  1. Hello Henry. I contacted my pal who updates the web site, and he will add a postscript to my article that provides information on J.W.s site in the U.K. Thanks for suggesting it. Cheers, W.
  2. Hello Henry and forum members above. Many thanks for the compliment. John Watson provided a lot of information to me for the article, I didn't want to duplicate (copy) other information he has previously provided on his web site, so I noted his site in the reference section. On reflection, I should have mentioned where to find this info! John's 'Lotus Seven Register' has a couple of photos that show the possible location(s) where the frame identification is stamped by the frame contractor. They are shown by clicking the 'register page' and scrolling down. J.W. does advise that the frame identifier letter/number can be in various locations depending on when the frame was constructed, but there is no mention if Lotus (or the frame builder) ever recorded exactly where they would be located. Lotus fitters similarly seem to have riveted the Lotus plate in different orientations to fit around the heater for example, but in all of the photos I have seen, on the flat horizontal aluminium sheet in front of the scuttle. Which side of the flat panel would depend on whether it was a l.h.d. or r.h.d. car. It does appear that the 1" angled steel bracket - that holds the front of the brake and clutch master cylinders alloy bracket - was the location used by Universal Radiators, but J.W. also shows another location on older cars produced by Progress Chassis. I am guessing, and this is only my guess, that the angled bracket would be easier to stamp before being welded on to the frame. Similarly, the plate that John refers to as being welded on to the frames constructed by Progress, would be pre-stamped. It really wouldn't matter what order the frames came off the production line, as the mis-match in frame builder letter/number combinations to the Lotus chassis number combinations reveal. Some may be very close to each other, some hundreds of numbers apart. I have only found one Lotus Seven so far that had the exact same builders i.d. number to the number on the Lotus plate. And just to throw another bit of confusion into the mix, John advised me that the last Lotus Seven Series 3s to be produced were SB2649 a, b, and c. I queried this, but it seems that as Lotus was at the end of the Series 3 line, someone at Lotus involved with the Series 4, decided (insisted?) that the Series 4 (or IV) should start with the chassis number of '2650'. With three Series 3 chassis waiting for completion, they were given the numbers SB2649a, SB2649b, and SB2649c. Not sure how this was viewed by the U.K. vehicle licensing office, but it must have been accepted, as they are fully recorded as individual cars in the Lotus factory records that J.W. has, and were registered for the road. W.
  3. For Lotus Seven owners or prospective purchasers of a Lotus Seven, I have added a section "Lotus Seven Frame and Chassis Numbers" on https://anglocanadianlotus7.ca dealing with frame and chassis numbers, plus the estimated numbers of cars built. The article was written with the help of John Watson of the Lotus Seven Register, plus a few recommended books. John Watson has detailed on his Lotus Seven Registry the locations on the Lotus Seven frame where the frame constructor stamped their build number, before bodywork was added by another company, with Lotus then riveting their aluminium chassis plate with their serial number on to the flat scuttle area. Hope it is of assistance. W
  4. Just rechecked the Burton Power web site, and the 2025/26 catalogue is free with free delivery world-wide (Just ordered one. I have no connection to this company, but have sourced many parts from them in the past). A download version of the catalogue is available at https://burtonpower.com and on pages 114 and 115 there are colour photos of each Ford transmission with parts list and details of each. W
  5. Hi CHristopher. According to author Paul Davies who wrote a book for Cars and Car Conversions titled "Tuning Four Cylinder Fords" (published 1971), quote: 'First all-syncro box was that fitted to the 1200cc Anglia Super and the 1200 Mk 1 Cortina. Apart from the advantage of having a syncro first, this unit should be regarded in the same light as the 105E/109E boxes (my note - no syncro on first on these earlier boxes) having ratios unsuitable for spirited motoring. In this same form this box was also used in the 1500 Cortina, Classic and Corsair models, and - initially - in the GT versions with the addition of a remote change" (remote change part 113E). He also notes: "Ford Performance Centre (as it was then) marketed a special kit which provided uprated 1st, 2nd and 3rd cogs for the 1500 GT casings." These were later incorporated into the 'new' (for 1967) box known 'incorrectly' (Mr. Davies' words) as the 2000E box (actual 2821E). The 2821E was later fitment into some 1969 manufactured Lotus Seven Series 3 models as supplies of the 116E dried up, plus the Seven Series 4 and Elan. The Lotus Cortina Mk 1 received an ultra close ratio box which Mr. Davies noted proved a little unsuitable for everyday use. In the Lotus Seven Owners Manual, Lotus refers to the 116E as an engine and gearbox combination. Christopher, I mentioned to you once before about Burton Performance in the U.K. I realize with the ongoing tariff situation that importing from the U.K. has become overly expensive, but Burton does have good reference material for clutch and gearbox combinations. The 1 inch 23 spline you note was used with the 'Type E' Rocket Box' (single rail operation - as used on the European Ford Taunus and others?). The original equipment gearboxes used the 7/8" x 20 hub according to Burton. I will attach a page from their old print-out regarding AP clutches (these original AP clutches may not be available now, but replacements are), which may help decipher the combinations. If you think it will be useful, a copy of the latest Burton catalogue may be very helpful to you, or just check on-line https://burtonpower.com Only cost for the catalogue will be postage (no tariff charge). It details the full range of gearboxes produced for the U.K. and European markets with all the necessary accessories noted. I have also added a page from the Autopress Ltd Ford Cortina 1967/68 manual where I noted the parts required for my 116E box rebuild as fitted to my 1969 reg. (built in 1968) Series 3. I am guessing that these parts have been unavailable for some time?. Cheers, W.
  6. Maybe check with your health professional?
  7. A GPS tracker is a great idea for expensive equipment such as a trailer. A neighbour of mine around the block, had his utility trailer stolen from his front driveway during the night. The thief had to drag it out onto the street backwards in order to attach it to the get-away vehicle. Unfortunately, no one heard the probable racket, even the owner. He was able to track the trailer to a trailer storage yard, and the yard owner found it hidden in the back of the lot. An employee of the yard was charged with the theft. Presumably the thief hoped to store it for a while, with no one at the yard noticing, and then sell it on. W
  8. Hi Scott. Most of the LHD and RHD Series 3 cars that I have seen were fitted by Lotus with the amber Lucas L691 signal lights mounted on a bracket fitted directly under the headlamps (as per mine and other Series 3 Sevens that were imported into the city where I live). Lotus attached the amber signal lamps to the side of the nose cone on the 13 or so Twin-Cam cars (all RHD except 1), and possibly some owners chose to do the same? Photos on https://simplesevens.org will show how Series 1, 2 and 3 cars are equipped. Also Tony Weale has a number of photos of how the lamps were mounted. (see page 111 for example of a Series 3 RHD). My scuttle came from Arch after the Caterham take-over (I have no photos of my original unit unfortunately), so possibly Arch may have followed suggested aircraft practice and placed the pop rivets at the recommended spacing (roughly 1 inch apart for a 5/32 inch rivet @MV8?). I don't think that Lotus were practising 'add lightness' by only providing 23,24, or 25 rivets on Timothy's or your scuttle Scott, but maybe cutting costs because, as noted, the scuttle is not structural? Also, if an owner wishes to keep the firewall and scuttle in one piece, it does make it stronger to handle to remove and replace and it keeps its shape better this way to avoid having it buckle. Only the hole above where the steering column slot is located needs to be modified to join the two up. (see: 'where can I get a Series 2 nose cone by @Bill. His scuttle appears to have the modification I am referring to). In any event, to remove the scuttle without a firewall attached, you still have to unbolt it from the frame, and remove the wiper mechanisms. With a scuttle that is kept intact, the choke cable also comes off with the scuttle, after unbolting the end from the carb(s). So naturally, whatever works best for you. Cheers, W. Just a P.S. Just read an article from the 1980s by a Lotus Seven racer in the U.S. He described the twisting that an original (unmodified) Lotus Seven Series 2 frame goes through in a race situation, and the stresses placed on the frame, ally body, and rivets. I would have to defer to @MV8 to advise if Arch - with my scuttle at least - were trying to make this body part more structural? With double the amount of rivets than required by Lotus, double bolt and nut fixing on each side of the chassis, and a strong channel piece to cover the area of the scuttle that bolts to the frame, possibly Arch have attempted to provide some structural support to the top of the chassis. I wonder though, how much extra it would provide? W.
  9. Hi Timothy. I think I see what you have done. My scuttle has 47 Monel rivets (spaced at approximately 1 inch apart) that connect the vertical firewall panel to the 'U' shaped scuttle front. Each rivet has a steel washer fitted (on the opposite side of the sheets to the domed head) that the pulled stem of the rivet sits against. The scuttle is not a structural component, but where ally to ally is riveted together, a washer on the opposite side to the domed head of the rivet of the 2 pieces to be joined is good practice, and Lotus and Arch seem to have followed this method in most instances. This is the same practice used by Lotus for the structural floor under-tray and prop shaft tunnel riveting method. The vertical firewall also has the starter solenoid installed, and the choke cable pokes out of a hole beside the solenoid unit. The battery clamp shown in the pic. for the Exide battery was used on some Series 2 models and more so on the Series 3. The vertical firewall slots into a 'U' shape formed in the horizontal firewall panel that the battery sits on. My appreciation to John Watson for the photo of a LHD Series 3 Seven engine compartment. In this rather grainy photo reproduced from a Lotus ad, there are quite a lot of rivets on the scuttle firewall. W
  10. Hi Timothy. Just my take on this, but if I understand it correctly, you are referring to the scuttle - which is the shaped aluminum section that holds the windscreen and the wiper mechanisms and wiper arms/blades? I see that your scuttle does not have a flat aluminum firewall sheet permanently riveted to the front of the scuttle as designed by Lotus. Lotus did not intend the scuttle to be riveted or held to the top of the dash tube by any means. On most? Unirad constructed Series 2 and Series 3 chassis frames, it was held on to the top of the chassis using 1 threaded bolt welded into the top of the frame. The scuttle was then held in place by a washer and captive nut either side. Later Arch frames incorporated 2 bolts either side, and Arch/Caterham specified a metal channel section to fit over the bottom section of the scuttle to snug it down over the studs and on to the frame using 4 washers and 4 captive nuts. Some owners discovered that the hole in the scuttle through which the oil pressure tube, water temperature mechanism, and speedometer cable (at least as applied to my l.h.d. 1969 Series 3 Unirad built Seven), just above where the steering column exits, caused problems when the scuttle had to be removed. The scuttle was modified by some owners to join the steering column slot to the hole therefore allowing the scuttle to be removed more easily without disturbing the 3 gauge connections. A rubber grommet would still be used on the 3 connections, but would easily slide out of the slot as necessary. The only other items to be unbolted from the scuttle for removal would be the wiper blade mechanisms with their tubes still attached. Many scuttles have press studs riveted or bolted into the scuttle to allow the tonneau cover to be attached, but - as relating to my frame - they were not attached to the dash tubes. I have found that my replacement scuttle does sit a tad too high when loosely placed on my frame, but when bolted tightly with the windshield unit in place, it should sit correctly on top of the curved dash tube. Best. W.
  11. The attached photo (apologies for the lousy angle, the book kept sliding out of the printer!) shows a 1979 registered (U.K.) Caterham 7 (the nose cone looks Caterham not Lotus) fitted with a large square scoop, probably covering a V8? From the book 'Illustrated Lotus Buyer's Guide' by Graham Arnold (published 1986). He describes the car as a 'Lotus Seven Series 2', but it appears to be a modified Caterham.
  12. Hello Christopher. Apologies, but perhaps this ties in with @pethier's unnatural act above?
  13. Not sure if this will be helpful and save you a bit of cash, but many years ago a company in the U.K. - John Aley - used to manufacture custom roll bars for many British saloon and open cockpit racing cars. For taller drivers, he would add a curved bar on top of the 'standard'** shape type of roll bar, to cover the driver's head and helmet. I have searched the web, but cannot find any photos of this or any in my collection unfortunately (apparently Aley closed after the death of John Aley - although Rimmer U.K. carry a couple of his examples). The radius of the additional tubing was quite large and not a hoop as such more a 'bump' added on to the existing bar top. Not sure how the roll bar fitted to the Seven shown below passed scrutiny, but in the 60s and 70s from other photos available, roll (over) bars hardly ever protected the top of a driver's head and helmet, often ending below the top of the helmet (even F1, F2 and F3, etc.). W Apologies for the rather crude addition to the drawing, but this is how Aley modified some custom bars.
  14. The spec. pages for both the Cosworth BDR engine, and the many parts that Holbay Engineering sold for their engines is now listed under 'Technical' on the website: https://anglocanadianlotus7.ca I am advised that it is in both jpeg and pdf format for free download if it is of interest. JohnCh has been advised, and it may end up in the library. The Cosworth sheets are spoken for and will be on their way to a BDR 7 owner. W.
  15. Hi Scott. The son of a friend of ours here in Canada worked for Cosworth in California when the company had a facility there. His mother went through a lot of challenges to get him a green card (had to hire an immigration lawyer), as merely using 'auto mechanic' or 'auto technician' didn't separate him from all of the other men and women in the same occupation. He had originally been hired by Toyota to build racing engines, and finally moved to Indianapolis where he opened his own machine shop building engines for the truck racing category. He suffered a fatal heart attack and his business folded. He provided me with a lot of engine build tips, which I still have in my collection, although I would prefer to leave engine building to the professionals as twice is enough for me (Honda 250cc m/c engine, and Triumph Herald!). W
  16. For Canadian 7 owners and just to confirm what many of you may already know, but Aircraft Spruce Canada (Brantford, Ontario) carries all of the same quality hardware that Pegasus in the U.S. carries, at the same or lower list price, but in Canadian Dollars. I like Pegasus, but with the exchange rate between us and the U.S. making it more expensive to purchase hardware for our cars from our neighbour, buying from Aircraft Spruce in Canada is a win-win. I had to wait a few days until some special lock nuts came in to Canada from the U.S. warehouse (so that my order would arrive in one package), but the price was lower than Pegasus, and the shipping by Loomis ground was cheaper than shipping from the U.S. and naturally in $CDN.W
      • 2
      • Like
  17. Just an update. As the BDR is not applicable to a Lotus constructed car, I have finally been able to successfully scan all 18 pages and sent a note to @Croc and @JohnCh for their approval to add the pages to the forum library (the first attempt at scanning probably ended up in the ozone, as I still cannot find them on my computer.!). I will still add the Holbay parts list to my website as time allows. Chris Rees in 'Caterham Sevens' advised that "480 BDR engines have been built to date, and only two remained unfitted to cars at the time of writing (note: my copy published 1996); 331 were 1700s, the remaining 149 being 1600s. Some 400 Cosworths went to Japan" (page 77 in your hymn book). The 1987 Cosworth parts list that I have only mentions the 1600 cc version (1601 cc actual) but in 120, 150, 160 and 170 BHP tune. Rees mentioned weeping cylinder head gaskets, comparatively temperamental running, and carburettor flat-spots (plus being a very expensive engine). As far as effort goes, I've curtailed the riveting on my chassis, and packed up all the tools for the fall and winter. Snow expected this weekend (0 deg. C) + no heated garage! Oh well. W
  18. If I'm going to scan 18 pages, I may as well have them added to my website along with the information from Holbay with all of the original parts they offered. I have found a way into my HP printer via a 'back door'. It's slow, but it seems to work so far. The pages are U.K. sized paper, which is longer than North American standard, but just fits on my printer platten. I didn't realize that there was interest in the BDR. According to a Caterham book, there were not that many produced, but some must have made it 'over the pond' to North America. I also do not know if any/many of the parts listed are available anymore? Same with Holbay.? Will advise, and you can then download whatever info. is of use to you. W
  19. Hello @wdb. Unfortunately my HP printer/scanner has not kept up with my iMac updates - even with the assistance of HP technical help line, and so I am looking at purchasing a new one. I have received a request from a BDR owner, and the 18 pages of assembly data will be sent to him. If he wishes, perhaps he can add them to this site? Cheers. W.
  20. Does anyone on this forum have a Caterham fitted with a Cosworth BDR engine? If so, I have a full set of spec. sheets from 1987 sent to me by Cosworth, that are available free - if you don't mind paying postage (at the lowest rate available from Canada)? Unfortunately, there is a postal strike going on here, but I just thought that I would put the offer out to see if there are any BDR engined cars in North America prior to the strike being settled. You can buzz me a message if you are interested. W.
  21. Hi Scott. I was checking out the Holden Vintage (U.K.) web site, and they sell this type of mirror and also variations with curved stem etc. If you can get them to send as noted in another forum, you may not have to pay too much to import them? W.
  22. Burton Power U.K. sells a brand new 701M 1500cc Lotus block with the same specs. as the 1600cc block as sold by Ivey, Pegasus, BAT etc. Part No. FL105. 7.8" deck height, bores semi finished to 3.228", 40,000 PSI grey iron, includes cam bearings, upper and lower thrust washer on centre main, etc. L3000.00 Pounds Sterling without tax for export (L3600.00 Sterling in the U.K.) Produced by Ford Racing. With tariffs added on, won't be cheap, but it is available brand new, and stronger than original. Perhaps Ivey or Pegasus can bring one in for you Craig? W
  23. @craig chima. I like the way you have engineered the top suspension link. With your racing rules, are suspension, tires and engine modifications all free choice? W
  24. @MV8 I have the same page and totally agree with you. It shows 'Seven Ser. 1 as 93 F, 65 R'. 'Seven Ser. 2 as 95F 54 R.' I also have a 'blow-up' of the page, and the 'Rate 105 in' is actually "RATE lbs in.' The lbs has been lazily written and on my copy is a tad blurred and looks a lot like 105. However, a page from the Armstrong catalogue that was sent to me by one of the members of this forum notes: "Mark 7 Series 1 up to C/No. 1000 1959 - 60, spring rate lbs/inch is 93 front , 65 rear". "Mark 7 Series II and Super 7 1960 the spring rate lbs/inch is 95 front, 50 rear" Tony Weale advised in the appendix to his book that the Series 1 used the same Spax damper and spring combination as the Series 2 and 3 on the front of the car. In an article from a 'Motor Sport' magazine (U.K.), Caterham raced an early Seven built by them and the rate was 105F/75R, but the springs sagged due to manufacturing errors. They then tried 90F/70 R. These spring rates were controlled by rules in the British 1980 Prodsports Championship. The same article advised that for a road-going Caterham 7 (1980-81) fitted with an Ital axle, the rates were 100 F/ 55 R. Later in Series 2 production (and later copied for Series 3), Mick Lincoln, former co-director at Redline, advised me that Lotus changed their specifications to 105 front, 75 rear as standard. DSK (U.S.) used to offer street springs rated at 85F/60 R. Their auto cross springs were 125F/90R. Tom Robertson used 140F, 100R. on his Series 2 race car (1977). Dave Bean recommended 115F/75 rear for standard road use. Mick Beveridge, formerly of Xtra Special Sevens (U.K.), liked 125/11" free length F, with 80/14" free length R. on his road cars, but noted that most companies in the U.K. don't make the 80s, so he went to 100 lbs/inch with 14 inch free length. W.
  25. Hi Scott. I think the magazine writer also got the spring rate numbers for the basic Seven Series 2 and 3 wrong. They were originally 105lbs on the front and 75lbs on the rear (o.k. we'll give them 80!) @SENC very kindly sent me a list of Armstrong dampers and springs a while back from an old catalogue. Not sure if they are in the library though? W. My wife thinks that I am lotus intolerant. I think she meant to say lactose, but either way seems to fit!
