7Westfield
Everything posted by 7Westfield
  1. did you use the VDO sender?
  2. the spare I have (new) doesn't have that slop it's out, and they're cheap.......
  3. I left the gear in place, with a new seal. I'll need it whenever I get around to the Racetech Folk on the Westfield forum say to just use a freeze plug, and silicone it in, if deleting the gear I didn't use one of the cheap round fleabay units because they are 85mm, and the hole in the dash is 80mm, which suits the racetech
  4. I opened up one that I have, and it looks like there's a bit of grease in there, but it would take a pretty small needle to get more in. That is the "standard" unit on MGB's, Triumphs, etc, so maybe Moss Motors can help you. Never seen a reference to alternate gears for T9, usually you have the speedo regeared to suit the cable revs per mile. I got a price to redo my Smith's recently, $250-300. For that money, I'll just use a Racetech unit with electric sender There are cheap GPS speedos on fleabay
  5. maybe a US only "nanny state" thing?
  6. My xr4ti shop manual says the forward one is reverse light switch, rear one is neutral safety switch BUT I wonder if that's right--other way round makes more sense my box -from a merkur- does have a divot in the shift rod at the bottom of the front one, and the hole is threaded
  7. if you end up drilling them, use a left hand bit you might get lucky and have them unscrew inside that cam cover looks really bad
  8. ZDDP goes in the oil if they say "tank", they're refering to a dry sump oil tank this may help https://www.speedwaymotors.com/the-toolbox/what-is-zddp-benefits-of-zinc-in-oil/30870
  9. No direct knowledge, but I suspect the Fit motor is ok without ZDDP after all, it's a modern street engine, and AFAIK overhead cams don't need it
  10. FF now has 2 engine options, xflow and Honda Fit, hence change to current name of Formula F. Nobody runs the "cortina" engine anymore, it's all the "uprated" version. 711 block Very simply put, balance and blueprint is about all you can do, but it's an art form. Power of 115+ hp common, power falls off over about 6700 rpm The Fit motor runs basically stock, with a restrictor in the intake to tone it down It's only 1500cc, but I've heard numbers up to about 140hp if you lose the restrictor and they just don't break amazing what 50 years of engineering progress will do
  11. Every formula ford engine builder I've dealt with wanted ZDDP oil. Current guy likes Penn Grade 15-40 syn blend. So, that goes in the FF, the xflow Westfield, and the tow vehicle--simplifies inventory Charlie
  12. What's it supposed to fit? Those primaries look too long for a "7", seem to be more for a sedan, like a cortina --they look to go more "back" than "out the side" Better pix?
  13. back to burton BH3
  14. what are you going to use for bellhousing? --merkur does not fit crossflow
  15. Note that if you use the Burton parts, the release bearing they sell for cable operation is 34mm ID. The Merkur boxes may be the only ones with 36mm snoots. They sell a 34mm replacement, I went with their concentric hydraulic setup nice
  16. take the spring off your shock, and check the top of the shock body itself. If it looks like a cap unscrews, they may be rebuildable you just might find those bushings at the hardware store, if you mean the ones on the sides of the lever the ball is a whole 'nuther story but it does look Ford I got a ball from Dave Bean several years ago that fixed my type 3 box
  17. first, you need to know if your shocks are rebuildable at all. Can't tell from the pics. Do they have a top that can be removed, or just a welded cap? I checked into it a few years back, mine were not serviceable, but new ones weren't much more than rebuild would have been. I called Spax on Monday, had them Thursday. I believe Spax has a deal plan for the Westfield club, you'd think they do Cat too.
  18. Re. upper arms the best way I've found to remove a ball joint/tie rod end is to whack it with a dead blow hammer. in your pic above, you want to hit it down on the end of the upright what you'll do is compress the sides of the tapered hole just a bit, and it will squirt the stud out. don't worry about distorting the hole, the stud being inside will prevent that leave the nut on, in case you miss I'm assuming the lower arms have want they call a silentbloc or metalastic bushing in them. This is an inner and outer steel sleeve with rubber molded between them. Bolt thru center and outside presses into end of arm. For the bolts stuck in the bushing, your only choice may be to put a big bar on the bolt, and just rip the rubber center out. For replacements, call Eileen @ GMT Racing, she can send you a list of the sizes they stock -about 20 -in your neighborhood, and good folks
  19. mine met up with a hole saw... that's not the bearing, it's the front part of a 2 piece shaft, identifies it as later production
  20. My experience with header wrap............ When I bought my pre-lit the first time, it was hot in the footwell, so I wrapped the header. When I bought it back 5 years ago, the wrap was still there. 25 years It was getting crunchy, so I peeled it off in order to measure for building a new one, since primaries are very small. SUPRISE it's as good as new, except that it's now got a green hue to it. It's chrome plated, must have been a reaction between wrap and plating I always heard wrapping would cause a header to rust out, but not this one. Maybe the plating saved it, maybe not. It's also pretty thick gauge tube. I'll wrap the new one as well, really helps with foot temps, and paint with Eastwood paint
  21. I'm assuming you're rebuilding an "uprated" engine--711M block, but if it happens to be an old "cortina" block, I have a set of Hepolite 10.5 compression .040 over pistons that need a new home Charlie
  22. all of them I've seen were DIY
  23. I just made a mount for my engine stand. A piece of tube to fit stand with a plate welded on end, drilled to bolt on side of block. Put it on left side mount, and you can spin the motor and get to everything. Using the shipping stands seems like a real PITA, especially for getting at the pan gasket. Charlie
