Those locks seize up in hot weather. So I always turn on my se7en's air conditioing when that happens to me....
Are you using the left side key in the right side lock? Turn the car half way around and see if that solves the problem.
Again I'm glad I have the SV--as you know everything is bigger and has more clearance on the SV, so the door locks presumably don't jam as bad!
