Anker Posted January 8, 2020 Share Posted January 8, 2020 Yesterday I did the paperwork and drove the car home. In traffic it runs rough, pops out the exhaust and spits out of the carburetors. I didn't notice that when I test drove it because that was a spirited drive on open roads. From 3ooo RPM it runs just fine, as well as at idle. My theory is that it is a result of having sat so long and possibly old pugs, wrong plug and points gaps, plus a partially gummed up carburetor. I was anxious to get it home because it was a clear, sunny day at 40 degrees F. Starting was also hard. Needed starter spray and lots of choke. No choke cable, so the seller had to manage the choke. I knew that and had ordered a choke cable and received it. After putting it in the garage we went out to dinner and celebrated with dinner at a local restaurant. Got home and watched TV until bed time. When I emptied my pockets the Caterham keys were not there. I know I can't sleep if I have done something like that, so I backtracked as much as I could and didn't locate the keys. Went dejectedly to bed and slept poorly as expected. Next morning I checked outside, and to my delight I found them right outside the garage door. Phew. The only filler cap key was on that chain. I have duplicates for all other keys. First to the hardware store to see if they could make another filler cap key. No blanks for that. Checked the interweb and none there to be found either. Checked another hardware store and they didn't have one, but the lady there pointed me to a third one that apparently has a blank of every key made. She was right, so I now have spares for all keys. At Autozone I picked up a set of spark plugs, a timing light, feeler gauges, Sea Spray and a bottle of Stabil. Even though it was cold when I got home I decided to start the project. First I reinstalled the filler, which I had brought along so I could test keys as they were made. Then I poured the can of Sea Spray in the full gas tank. After that I moved on to installing the choke cable. Not as easy as I expected, but still easy enough. The holes for the wire un the choke connection were too small and has to be drilled larger. I decided to to proceed to running the cable to the dash before testing it. I can reach the loose end of the cable from the driver's seat. Kery turned, wait for the fuel pump to do its thing, full choke and turned the key. Fired right up and kept running as I gradually reduced choke. Real progress. By now it was getting dark, so I wrapped up by letting it warm up and then trying to apply choke with partial throttle. As I expected, the revs went up, a good indication that I am on the right track. If the weather is decent tomorrow I'll install the choke in the dash and take it out for a spin so the Sea Spray can do its job cleaning out the carburetors. If the balancer vacuum gauge has arrived I plan to proceed to balancing the carbs and setting the low range mixture. After that plugs and gaps plus timing. With luck I'll cure the popping and spitting. I also have a compression gauge and will see what that shows. Depending on how well everything turns out I will decide whether it is worth pulling the head and sending it out for refurbishment. This feels good! Link to comment Share on other sites More sharing options...
xcarguy Posted January 8, 2020 Share Posted January 8, 2020 Let the fun begin. Time to make it yours. Link to comment Share on other sites More sharing options...
panamericano Posted January 9, 2020 Share Posted January 9, 2020 "... possibly old pugs..." Yes, pugs never seem to be able to breathe right. They always seem to gag and spit and snort. Maybe they should all be choked. No offense to owners. Sweet little ones, I'm sure. Link to comment Share on other sites More sharing options...
coffee break Posted January 9, 2020 Share Posted January 9, 2020 I've experience the carb spitting and such. I had to clean up the right side clam after running the car w/o airfilters. I've since put them back on, but they sure sound great unrestricted. I figured the spitting had to do with the overlap between intake and exhaust valve timing. Link to comment Share on other sites More sharing options...
Anker Posted January 9, 2020 Author Share Posted January 9, 2020 Thanks, good to know. Is this generally the case? I seem to remember that spitting through the carbs isn't good for them. Link to comment Share on other sites More sharing options...
Anker Posted January 9, 2020 Author Share Posted January 9, 2020 I have a bad keyboard. It can't spell, transposes letters and omits others! Grammar is also bad! Link to comment Share on other sites More sharing options...
xcarguy Posted January 9, 2020 Share Posted January 9, 2020 I have a bad keyboard. It can't spell, transposes letters and omits others! Grammar is also bad! Bad keyboards and spellcheck make for great satire.:jester: Link to comment Share on other sites More sharing options...
Anker Posted January 9, 2020 Author Share Posted January 9, 2020 Pictures: Link to comment Share on other sites More sharing options...
panamericano Posted January 9, 2020 Share Posted January 9, 2020 Looking good. I see you have the cone bumper. Ready for the first autocross of spring. Link to comment Share on other sites More sharing options...
Anker Posted January 9, 2020 Author Share Posted January 9, 2020 It will be ready. Could be autocrossed as it is, but I want to make sure everything is in perfect shape, so a lot of maintenance and acouple of small repairs ahead. I plan to build a tire carrier to be mounted on the roll bar. The 12" rims with 45 aspect tires bring the car too low to drive in the street. Do you autocross? Link to comment Share on other sites More sharing options...
Anker Posted January 9, 2020 Author Share Posted January 9, 2020 It will be ready. Could be autocrossed as it is, but I want to make sure everything is in perfect shape, so a lot of maintenance and acouple of small repairs ahead. I plan to build a tire carrier to be mounted on the roll bar. The 12" rims with 45 aspect tires bring the car too low to drive in the street. Do you autocross? If so, where and with what club? I autocross with PCA, NE-SVT and Track Club USA. Link to comment Share on other sites More sharing options...
panamericano Posted January 9, 2020 Share Posted January 9, 2020 "Do you autocross?" Sure. It is unfortunate that a plain street Seven has to run in D Mod. If a real DM showed up, it would weight 300 pounds less, have double the engine power and double the tire. Lucky there is no one doing that locally. These are fun cars for that. Drive to the "track", run, drive home. [ATTACH=CONFIG]16394[/ATTACH] Link to comment Share on other sites More sharing options...
Anker Posted January 10, 2020 Author Share Posted January 10, 2020 Similar situation here. In PCA I will be in non-Porsche, R rated tires battling anything that fits that description. In NE-SVT classification is by experience, so there I will be better off. Anyway, I just wantr to have as much fun as my limited funds can buy, and this fits the bill. I am a SCCA member and will do them too when they run locally. We have the Moore airfield in Ayer, MAssachusetts. One of the best venues in the US. We lay out over a mile long courses on the taxiways and runways. Only drawback is that the pavement is cracking, so we have to run the cone course around the worst spots. Advantage is that there are no objects to run into of you spin out. Link to comment Share on other sites More sharing options...
Croc Posted January 10, 2020 Share Posted January 10, 2020 [ATTACH=CONFIG]16394[/ATTACH] You look like you are barely moving? Did you stall? Need a push? :jester: Link to comment Share on other sites More sharing options...
panamericano Posted January 10, 2020 Share Posted January 10, 2020 You look like you are barely moving? Did you stall? Need a push? :jester: Can't you see it's up hill? Link to comment Share on other sites More sharing options...
Lonnie-S Posted January 10, 2020 Share Posted January 10, 2020 @Anker That's a really nice looking Caterham. I'll be looking forward to seeing how your experiences with it play out. Cheers, Link to comment Share on other sites More sharing options...
