360S S3 "Yellowjacket" Build in Upstate SC
57 minutes ago, JohnCh said:
If you want to approach the problem from a different perspective, consider buying motorcycle jumper cables.  Their smaller clamps work well with the bolt heads on the battery.  I carry these on tour and have jumped a Caterham with a PC680.  https://www.amazon.com/gp/product/B000UKD6II/
Love the benefits of a creative community!  Always a new angle you haven't thought about.  Thanks, John!
Having invested already a bit of time and "emotional buy-in" into the conventional jumpers solution, will try for now to see it through.
Just ordered on Amazon 10' of red 3/8" ID x 5/8" OD silicone hose for $5.  https://www.amazon.com/dp/B0BXSQN2XV?smid=A132D7PL1YID8X&ref_=chk_typ_imgToDp&th=1
We'll see if/how a short length will fit on my little bracket.  (oooops, haven't caught at first the visual one can get reading this, but will leave it there...  :classic_blush::classic_biggrin: )
Edited by Yoram
We are car guys, not middle-school kids.
  • Shocked 1
I think you could do shrink tube. Adhesive on the horizontal portion of the tab. And non adhesive on the vertical leg. Making it removable.  While heated pinch the end with pliers to make a cap.
https://www.cabletiesandmore.com/heat-shrink-tubing-2-1?pid=1262&gad_source=1&gbraid=0AAAAADfXKhj64GLT7gr0mo9-a42_2eD6z&gclid=Cj0KCQjwgrO4BhC2ARIsAKQ7zUkCR5KkTBAIrvaia4MFBwKSJzdyeCqA6ilYVY00MDgkIzYcOFDlVHEaAt2ZEALw_wcB
Thanks!  Will try this next if the silicone hose does not work.
I ended up ordering a pair of these jumpers, primarily because they are much smaller and lighter (shorter and smaller gauge) than the sets I have in the other cars, so more fitting for the 7...
I will keep my terminal mods for now (belt and suspenders approach) and report about the success or otherwise of my contraceptive solution.
The silicone hose (see my post above from 10/14) did the trick. It was not too hard to push around the corner to cover the entire length of the exposed bracket.
Before:
After:
Seems quite tight.  And please no one suggest this reminds them of Peyronie's disease.
Cheers.
Edited by Yoram
Great meeting you today at C&C, sorry I had to bail early, something came up that needed my immediate attention elsewhere. We will catch up again.
Bill S.
Bill S.
Bill, no worries and same from my side!  Looking forward to it.  :cheers2:
Small updates and Happy Holidays!
Battery and charging
Left car for a test case without trickle charging for over a month while we were in Michigan.  Upon return it cranked barely and then died.
Started right away with jumping.
Two lessons:
1.  My fully charged Odyssey PC680 AGM battery does not last a month feeding the immobilizer -- need to trickle charge whenever leaving the car for more than ~2 weeks.
2.  My terminal modifications to facilitate jumping with standard cables (see posts above from Oct 7 and 18) work as intended.
Shoulder belt ends flapping
As some others with 4 or 5 point harnesses have reported, we also have experienced the shoulder belt loose ends flapping at our faces at speed.
I tried to solve this with zip-tie loops but they would not stay in position.  I tried 3-prong metal buckles over the loose ends (from Summit Racing I believe) but they severely restricted adjustability.  After quite a bit more searching I decided to try 3" plastic loops from Strapworks:
https://www.strapworks.com/3-inch-plastic-loop-black
These did the trick.
They work fine and do not get in the way of easily adjusting the length.
Last but not least:  Wishing everyone here Happy Holidays and a Great New Year!
Drive'em like Sir Colin is watching!  (he is!)
Cheers,
-Yoram
Edited by Yoram
5 minutes ago, IamScotticus said:
What charger? An AGM type I hope.
Yes, my trickle charger has an AGM setting which I'm careful to select.  Wanted to see how long the little PC680 will last without it...  not very long I'm afraid.
At least now it's quick to jump it with standard cables as any other regular car.
Edited by Yoram
AGM charger… hmm. I trickle my cars on a harbor freight whatever charger…
should I check a setting?  Real question.
thanks in advance.
j.
Don't know almost nothing regarding batteries... googling (or duckduckgoing in my case) like most of us...
From the little I read, AGM batteries cannot tolerate high charging voltage levels at the level of regular ("flooded") batteries and risk popping their safety valve and losing capacity.  To my understanding this is because the internal resistance of AGM batteries is lower and therefore the charging current at a given voltage would be higher, which may create overheating and popping of the safety valve.  Also to my (limited!) understanding, trickle/maintenance charging is not the main risk.  Deep charging under high current of a deeply discharged battery is mainly where one needs to be careful and use an AGM charger or an AGM setting. Since I switched to an AGM battery and needed to do both (deep and trickle charging) I decided to invest in a charger with "regular" and AGM settings.  These are very common and affordable nowadays.
But I plead the Fifth...
Since my maintainers are all only 1 amp (or maybe some are 1.5) I think I'm OK with my AGM batteries.
Edited by pethier
Fumble-fingered typing.
Back last September I put together a photo book with few annotations to have on the coffee table and for occasions like the Euro Auto Festival (which BTW got postponed and now rescheduled).  I used Mixbook.com and highly recommend them.
As I was mindlessly leafing through it the other day I discovered a serious error:  The reported final camber angles were missing the minus signs!
Had the car been aligned to those values (1.5 and 1.6 deg) it would have resembled a flattened MG TA with loose wheel bearings.
I wasn't going to have the book reprinted so I just added the minus signs with a fine black pen/marker and a ruler.  Came out OK...
But... what about my other documentation?  To my horror, the error was propagated consistently in my build journal, my (manual) alignment data sheet, and in this thread!  :banghead:
It's all fixed now (phew...), including in my edited post from Sep 7 2023.
Quite surprised that no hawk-eyed member, not even @mrmustang or @IamScotticus, caught this.
Or maybe you did but decided to be nice for a change and let it go... :classic_smile:
Cheers!
  • Haha 1
