360S S3 "Yellowjacket" Build in Upstate SC
17 hours ago, Yoram said:
Back last September I put together a photo book with few annotations to have on the coffee table and for occasions like the Euro Auto Festival (which BTW got postponed and now rescheduled).  I used Mixbook.com and highly recommend them.
As I was mindlessly leafing through it the other day I discovered a serious error:  The reported final camber angles were missing the minus signs!
Had the car been aligned to those values (1.5 and 1.6 deg) it would have resembled a flattened MG TA with loose wheel bearings.
I wasn't going to have the book reprinted so I just added the minus signs with a fine black pen/marker and a ruler.  Came out OK...
But... what about my other documentation?  To my horror, the error was propagated consistently in my build journal, my (manual) alignment data sheet, and in this thread!  :banghead:
It's all fixed now (phew...), including in my edited post from Sep 7 2023.
Quite surprised that no hawk-eyed member, not even @mrmustang or @IamScotticus, caught this.
Or maybe you did but decided to be nice for a change and let it go... :classic_smile:
Cheers!
I'm only here for the pretty pictures :leaving:
  • Haha 1
On 2/20/2025 at 10:07 PM, IamScotticus said:
I only critique tyre carrier colors
Scott, I think you meant colours.
  • Haha 1
We are discussing English cars on a site called "USA".  I think either is correct.
"It's all 4/4 to Milcho" - Don Ellis
Here in South Carolina those could be fighting words :classic_ninja:
Mine is Ford Moonstone Blue. Hope that's OK.
5 hours ago, IamScotticus said:
Right mate. Colours and tyres it is.
If you paint your chassis yellow, a yellow tyre carrier is OK.
I won't complain about that.
What is a tyre carrier?? I don't know if I have one.
It's for mounting a spare wheel to the back of the body/chassis. They used to be part of the chassis, but now they're optional/removable: https://caterhamparts.co.uk/other/3798-spare-wheel-carrier-bolt-on-metric-cars.html?search_query=spare+tire+carrier&results=13
Edited by 11Budlite
Thank you, I know.  Just being a smart aleck, sorry.
  • Haha 1
23 minutes ago, 11Budlite said:
I'm such an idiot!!!
No, I am!! I insist!! 👹
  • Haha 1
For you, sure :classic_wink:
Edited by IamScotticus
In Ford Moonstone Blue to match the body, just the way it came to me.
I am unable to spot the colour of the spare wheel carrier, however I must cheer your exquisite taste in choosing Firecracker Yellow wings!  :cheers2:
The nose is also Caterham Firecracker Yellow.
What I consider the "spare wheel carrier" is easy to spot.  The license plate is attached to it.  All the same paint.
And no, I don't really see the "blue" in Ford Moonstone Blue either.  Not in this light or any other.
Most Caterhams that have the spare tyre carrier/license plate bracket welded in place are painted body colour. Cars with bare aluminium bodies are the exception being left in the frame colour. Our car's carrier and plate are therefore in the same Cadbury's Purple as the rest of the car.
Edited by theDreamer
13 hours ago, pethier said:
<snip >
FYI: Moonstone Blue Metallic was first used on the Ford Sierra Cosworth 3 door (hatch). This particular colour requires a light grey undercoat. The top coat is produced only as a varnish finish with a dominant blue colour.
The photos I found on-line show it to be more like metallic silver with a slight blue hue. Obviously, what base coat colour was used plus the thickness of the top coat would play a part in the final product.
Ahh, now I see it.  Wasn't looking closely at the bottom.  Not being familiar with it I was expecting a bracket in the middle of the rear panel (obviously obscured by the wheel) with a couple/three studs, like in Jeeps etc.
Funny what a can of worms @IamScotticus  opened with his nonsensical line...
I was pondering a spare wheel carrier when speccing my kit but Josh Robbins talked me out of it.  Looks cool though, and serves a purpose.
Interesting.  Your carrier apparently came from the factory with with a carrier set up for a Canada/USA license plate.
My 1700 Super Sprint is an English car (lived most of its life in Northwich) so the number-plate plinth is a different shape.
Dunno when Caterham started having two setups for these license plates.  As far as I knew, my 1979 was always a USA car, and it had the English plinth.  I bought the car in Wisconsin.  Here it is ready to go on the transporter to Cape Cod.  There are only two holes in the plinth, and they are correct for a Canada/USA plate.
IMG_4293
Edited by pethier
