Caterham Rocker Switch - help needed
DanM
Hey everyone,
I am building a Mazda SDV and am using the MX-5 instrument cluster and wiring loom. The Westfield kit doesn't come with a hazard switch so I need to add one myself........  and to ensure that my OCD tendencies are satisfied, I want to replace the supplied demister switch at the same time so that they match.
I am thinking of getting the standard Caterham rocker switches, but noticed on the website that there are two different options available.
https://caterhamparts.co.uk/switches/229-rocker-switch-hazard-1981-2010.html?search_query=hazard&results=6
https://caterhamparts.co.uk/switches/4242-switch-hazard.html?search_query=hazard&results=6
Here are my questions:
1. What is the physical difference between the two rocker switches?
2. Which one would be best for the Mazda wiring loom?
3. What else will I need to get to make them work?  I have read some forum posts talking about controllers etc.
Thanks
The 1981-2010 switch has six pins and the other has four. You'd need the mating socket and socket pins to use either switch. The pins may require a special crimp tool if they come bare with no wire crimped on for splicing. You may need to buy an instrument loom if they don't offer the hazard pigtail portion.
It would also take some time analyzing schematics for both but you can use any switch with enough extra effort. I suggest carling switches, where you can have any option, everything is available, the crimper is not expensive/proprietary, and the switches are very durable. Typically used for high-end marine applications.
If you do decide to go with the standard Caterham type switch, you can get the plugs and terminals from British Wiring. When I rewired my old Birkin I was able to get everything I needed to make it a plug and play setup with none of the wires being soldered directly to the switch like it was previously.  Check out the C835 switch plug here:   http://www.britishwiring.com/Plugs-s/36.htm
On 12/27/2022 at 10:47 AM, IamScotticus said:
Caterham toggle switches fade quickly.
May consider sommore UV resistant.
I'm trying to figure out what to do about my very gray switches at the moment.  this post is as intriguing as it is confusing.
Lots of products for restoring rubber and plastic.  you may want something specific to plastic like Mother's Back To Black,  but a rubber polymer may be similar.  Im not a chemist.
https://atpautomotive.com/featured/re-seal
Edited by IamScotticus
Simplest answer for me after trying all nature of solutions and products which never lasted that long was to replace them on my old yellow 2004.
Car Builder Solutions sells the replacement switches - this is just one of the full collection plus they have a blank switch if you have something unusual
IVA Rocker Switch Fan Green | Car Builder - Kit & Classic Car Parts Specialist
They ship to the USA - I have always had good service from them.
I've tried a few products that I've used successfully on other projects to no avail.
Car builder solutions is definitely a possibility.  Caterham also sells the switches but I have a stinking suspicion that they're the same ones Car Builder Solutions sells.
They are identical manufacture.
