weighted shift knob?
Austin David
new Caterham, MX-5 transmission with what I assume is a not-quite-Miata shifter (at least, shorter than my NB MX-5 which AFAIK is the same transmission).
Should I use a weighted knob?  My stock knob is pretty heavy, and I'm making a new one because bored and whatnot.  Current iteration is about 40-50g, but I could fill it with tin or tungsten or something and get it much heavier, if it matters.
The innernets are relatively divided between "lighter is more agile" and "heavier is more smooth."  And of course, both are best.
What do y'all think?
Personally, I'd experiment to determine which I prefer.  Even if 9 out of 10 people here state they prefer the stock weight, if you prefer heavier, then that's the right answer for you.  Perhaps tape different amounts of lead weight to the stock knob and try it out?
Ah, I misread that and thought the comment about making it heavier was referring to the stock knob not a new one you have already fabricated.  But yeah, experiment ;)
Yeah, trying to see if I need to pack it with $30 in tungsten powder, or melt down some lead, or beg some steel shot from the local armory.  Or something.  Having a target weight might help.
I'll see if I can get some cheap lead tomorrow...
I like to use pool balls for shift knobs by drilling and epoxying an insert (perhaps a seven ball?) or rod with a bolt-on lever (like a ford application T5). Very comfortable for large hands. Adding weight to a shifter makes no sense to me. Most oem shifters are isolated by rubber in the shaft or mounting flange.
WWCD?  What would Colin (Chapman) do?  Don’t overthink it; it’s a Seven, go light!
on a serious note, I replaced the worn plastic shift knob on my Tacoma 4x4 with a stainless steel shift knob, not because I needed the mass, but because I thought hewn from a stainless billet was more cool than worn plastic. I noticed nothing function-wise. Frankly, I think the “weighted shift knob” thing is pure marketing.  Part II, the metal knob is HOT in the summer and COLD in the winter.
Simplify and add lightness.
Mark
it's a seven so lighter is better.
if you need to fiddle try some different shapes.  that was my winter lathe project a few years ago and the shift knob that ended up working best for me was pretty far away from where I started.
I've always liked a small sphere, but the stock knob had a pretty deep inset "S" that feels weird.  And it's solid metal, so kinda warm in the summer and very cold in winter.
I've got a polished plastic sphere with the insert Lotus logo, it looks good and feels good.  I'll try packing it with lead to see if there's a useful difference with added mass.  I think the range will be about 30-250g without having to get too creative...
testing 2 models, shifting 3-4-3 in neutral.
unit A, 31.8g vs unit B, 136g.  Similar materials and construction; both ~ hollow plastic.  Unit B mostly filled with lead shot; it's loose, so this may also provide dampening (like a deadblow hammer)
Both work, unit B is "smoother" -- less notchy bouncing in/out of neutral.  No meaningful difference in the effort required to shift in/out of 3-4-3.
For the reference: a similar sphere made of water would weigh about 56g, so I assume a solid wood knob would be about 50-60g
again the internet is torn on this -- range is "don't do it" to "it makes no difference", but clearly there's an upper limit.  I don't necessarily think the Caterham setup is perfect in every way, but I figure as long as I don't make it heavier than the 200g stock knob (about 7 oz) I won't be creating any new problems.
Google seems to think it was a 917.  Interesting.  I can get down to about 28-30g total, including the sleeve to cover the gap between the ball and the boot.  The 917 model seems to come in around 35g with the internal shank to hold it together.
Pretty sure I ate about 350-500g of dinner tonight.
Edited by Austin David
