Timothy Keith-Lucas Posted 19 hours ago Share Posted 19 hours ago Is there a secret to removing pop rivets? I want to remove two panels with 48 rivets each and one with 20. I can drill out some of them, but others spins with the drill bit. I've considered but not tried grinding the tops off, but that would be very delicate work. Thoughts? You wonderful folks are giving me a rapid education in 7 renewal. Link to comment Share on other sites More sharing options...
7Westfield Posted 18 hours ago Share Posted 18 hours ago once they spin...it gets tricky I've ground some with a dremel also a narrow wood chisel Link to comment Share on other sites More sharing options...
MV8 Posted 18 hours ago Share Posted 18 hours ago Lightly push the head from the side with a flat blade screw driver, tilt the drill to one side, light pressure, high speed. Link to comment Share on other sites More sharing options...
fastg Posted 18 hours ago Share Posted 18 hours ago Try using a smaller drill at an angle. If you get the angle right they will not spin. Go around from a few different sides. Then a sharp tap with the same size punch and you should have success. I have never had to grind off a rivet. Graham Link to comment Share on other sites More sharing options...
wdb Posted 17 hours ago Share Posted 17 hours ago Curious as to what y'all do about all those drilled out rivets jingling around inside the frame tubes. Link to comment Share on other sites More sharing options...
MV8 Posted 17 hours ago Share Posted 17 hours ago A little waxoil or straight boiled linseed squirted into each open hole. It gets thick and gels as it dries. Prevents rust too. 1 1 Link to comment Share on other sites More sharing options...
IamScotticus Posted 15 hours ago Share Posted 15 hours ago 2 hours ago, wdb said: Curious as to what y'all do about all those drilled out rivets jingling around inside the frame tubes. I don't think they can be heard over all the other running noise. Yes, rust proof the frame. 1 Link to comment Share on other sites More sharing options...
