Carz01 Posted January 12 Share Posted January 12 I’m on the hunt for an air filter for my S4. It’s a BV TC running Dellorto DHLA carbs. I’ve been unsuccessful finding a replacement, and thought it was a K&N based on the sticker, but no joy there. The assembly covers both carbs showing measurements, and installed on the car. I don’t want to cut into the Bonnet. Any thoughts are appreciated. Thanks in advance. Link to comment Share on other sites More sharing options...
JohnCh Posted January 12 Share Posted January 12 I've never seen the pleated style that covers both carbs, so can't help with a direct replacement. However, if no one recognizes it and you are open to similar filters that use one per carb, both the Dellorto Shop and Redline have some options that should work: https://www.dellortoshop.com/contents/en-us/d107_Airfilters_Shop.htm http://www.redlineweber.com/html/application_guide/air_filter_applications_by_carbu.htm Another, albeit more modern looking option, is the ITG JC40/25. It's the same height as your current filter, about 1/2" longer and 1" wider. They also do a sausage version in that size (JC40S/25) and sell blank baseplates that you can drill to fit: https://www.itgairfilters.com/products/jc40-small-twin-carburettor-filter-black-framed Link to comment Share on other sites More sharing options...
Carz01 Posted January 13 Author Share Posted January 13 Thanks for your feedback and insight @JohnCh, I agree the others may work out. I’ll also look at the ITG. I was hoping someone would recognize it. part of the issue may be the car was originally made in NZ (Steel Bro) so it might have been a somewhat custom part. Thanks again Link to comment Share on other sites More sharing options...
JohnCh Posted January 13 Share Posted January 13 39 minutes ago, Carz01 said: part of the issue may be the car was originally made in NZ A long shot if you strike out here is to post something on https://www.ozclubbies.com.au/ It's a se7en forum based in that part of the world. Someone there may recognize it. Link to comment Share on other sites More sharing options...
mrmustang Posted January 13 Share Posted January 13 Looking at the pleating, it certainly appears to be a K&N filter, have you thought to send pictures of the filter (pull it out of the car, lay it out flat and take shots showing the dimensions and the general overall filter itself) to K&N's tech support division? tech@knfilters.com Bill Link to comment Share on other sites More sharing options...
Carz01 Posted January 13 Author Share Posted January 13 @JohnChthanks for the recommendation to the OZ Club, I’ve also found the NZ Club, so maybe one of the will recognize it. @mrmustang the KN Tech was my first try. I agree it certainly looks like a KN filter, but they didn’t have any details. I never thought it would be a challenge finding a filter, but worst case I’ll install a couple of low profile KN. Thanks both for your help. Link to comment Share on other sites More sharing options...
MV8 Posted January 13 Share Posted January 13 K&N offered a huge variety of filters at the beginning but have narrowed it down greatly. You could fit a round filter that is about 13-14 inches x 2 inches and bend it to fit the assembly. I don't know why you need to replace what you have. The filter can be straighten and sealed if there are any damaged areas. It is just window screen and cotton gauze. Short of adapting a round filter, you might as well add individual assemblies that are common and come in different heights. Link to comment Share on other sites More sharing options...
Carz01 Posted January 13 Author Share Posted January 13 @MV8thanks for your thoughts. I may try to repurpose a round and see what luck I have shaping a filter. I’m also going try and straighten and reseal where needed as you recommended. I was a little concerned with the bent areas, but overall the other side is much better. Link to comment Share on other sites More sharing options...
7Westfield Posted January 13 Share Posted January 13 maybe you can make this work listed for a Datsun 240z https://www.speedwaymotors.com/Speedway-Reusable-Air-Filter-15x2-Oval,351226.html?utm_medium=CSEGoogle&utm_source=CSE&utm_campaign=CSEGOOGLE&store_code=SMI-LNK&gad_source=1&gclid=Cj0KCQiAkJO8BhCGARIsAMkswyi6uQI2pBTFaHy41ikQZ2wpJQ0-TNLr6oQdPA3HDehk-UInQOpxpjQaAgVkEALw_wcB Link to comment Share on other sites More sharing options...
wdb Posted January 14 Share Posted January 14 You've probably heard this before but you are likely giving up some performance with an air cleaner that shallow. There can't be much in the way of velocity stacks under there, and what stacks there are will be very close to the outer cover. I'd be tempted to find a domed unit that would allow air in over a larger surface area, particularly directly in front of the carb throats. Link to comment Share on other sites More sharing options...
Carz01 Posted January 14 Author Share Posted January 14 @wdb, that’s an interesting thought. The S4 manual show a box type unit, but with an air inlet in the front of the unit, which is different than the pancake style installed. I need to see how much space exists between the filter and Bonnet to see what I can fit. Thanks for your insight. Link to comment Share on other sites More sharing options...
JohnCh Posted January 14 Share Posted January 14 53 minutes ago, Carz01 said: The S4 manual show a box type unit, but with an air inlet in the front of the unit, which is different than the pancake style installed. This is also how Lotus did it in the Elan. It wouldn't surprise me if the parts are the same to save money. There are a few people here with Elans that might be able to take measurements for you. I'm happy to measure mine, but my Elan is a Stromberg car, which may have different dimensions than the DCOE airbox. 1 Link to comment Share on other sites More sharing options...
IamScotticus Posted January 15 Share Posted January 15 Go remote https://www.borlainduction.com/gallery/gallery_detail.aspx?gallery_cat_id=2&gallery_id=19#popUp Now ain't that purdy? Link to comment Share on other sites More sharing options...
Carz01 Posted January 15 Author Share Posted January 15 @IamScotticus, that’s are really nice airbox, thanks for sharing it. I think it I need to change my setup! I also appreciate the link on the S4 development. I had not previously seen it. This Forum is truly amazing! Link to comment Share on other sites More sharing options...
