JohnCh Posted February 4, 2025 Posted February 4, 2025 This forum has been strangely quiet given the number of people who 3D print, so let's start a thread for people to show their favorite print(s) they've made that's related to their passion for se7ens. The print doesn't need to be something you personally designed but should be a car part, tool, artwork or other related item you have printed. That means no searching on sites like Thingiverse and posting a bunch of things you think are interesting but have never tried. We can have a separate thread for that. Hopefully the items shown will give people ideas for their own projects. -John 1
fastg Posted February 4, 2025 Posted February 4, 2025 Throttle pulley for the 90mm throttle body. The supplied one was huge and I was only getting about 1/2 throttle. I experimented with sizes until I got just the right movement. The 3D printed one lasted well, it could the 20 min track day sessions were fine, but the 30 min session it started to deform badly. I had to turn it to a new hole between sessions. Finally I sent the file off and had a CNC machined pulley made. Graham 4
JohnCh Posted February 4, 2025 Author Posted February 4, 2025 @fastg what filament did you use for the pulley?
fastg Posted February 4, 2025 Posted February 4, 2025 It was a Prusa PLA+, nothing special. I believe using some of the newer filaments that can stand high temps it would have been OK. Graham
JohnCh Posted February 4, 2025 Author Posted February 4, 2025 Under bonnet temps are pretty extreme for PLA or even PETG. Some of the major filament makers provide data sheets that include max temp ratings (claims?) before softening that are often helpful in filament selection. There are also some good YouTube channels that regularly test filaments to separate those claims from reality. If you haven't found this one, I highly recommend it. He has a PhD in Mechanical Engineering and teaches at the University of Budapest. His filament testing procedure reflects this background. https://www.youtube.com/@MyTechFun
Austin David Posted June 19, 2025 Posted June 19, 2025 I've got a few under the bonnet; PETG and TPU do OK near the firewall. I'll get some pics when it's open. Yesterday I printed brackets for dashcams on the rollbar. They're working well, secured with VHB tape under the bracket and zip ties slotted in. Also made a little tray for a radar detector, mounted on the aeroscreen mirror post. The detector is secured with Velcro. The mount works well, but I can't really hear or see the signals so it might not be helpful. I've lost track of the other things I've done. Mount for the custom roll at brake light, visible above. There's a riser for the boot floor to accommodate a fuel return, and a bracket to secure my tool kit. Updated o-rings for my gauges. A massive (for me) printed template to drill the ITB backplate. Several fittings around the cooling system to secure hoses. AN6 braces for the new fuel lines through the tunnel... 3
Origin7 Posted Wednesday at 10:00 PM Posted Wednesday at 10:00 PM There is some good real estate under the steering column that I decided to put to good use. I used some brass heat-set inserts for threads. For everything outside the engine bay, I use PETG with carbon fiber. I highly recommend it. This area is a perfect fit for an Element Extinguisher. I realize these aren't as good as a bottle of novec 1230, but it will probably be sufficient for my needs. 4 1
JohnCh Posted yesterday at 12:10 AM Author Posted yesterday at 12:10 AM Very nice! For under bonnet items, check out PET-CF. Prints just as nicely as PETG-CF, but can handle very high heat. 1
Origin7 Posted 13 hours ago Posted 13 hours ago Thanks @JohnCh It’s nice to hear about PET. I work in the industry and actually tried developing a recycled PET filament about a decade ago. It didn’t gain much traction at the time, so it’s great to hear it’s being used now. It’s a good material and readily available. I’ve also been experimenting with high-durometer TPU in the engine bay. I’ll report back on how that goes.
JohnCh Posted 11 hours ago Author Posted 11 hours ago I may be using TPU for a tricky airbox to air hose connection in another car. I'll be interested to hear how things go for you.
Scott_ Posted 45 minutes ago Posted 45 minutes ago On 5/6/2026 at 6:00 PM, Origin7 said: There is some good real estate under the steering column that I decided to put to good use. I used some brass heat-set inserts for threads. For everything outside the engine bay, I use PETG with carbon fiber. I highly recommend it. This area is a perfect fit for an Element Extinguisher. I realize these aren't as good as a bottle of novec 1230, but it will probably be sufficient for my needs. Very nice. I have been considering one of those. Scott
