Anyone ever use the rattle can bedliner spray?
I'm considering it for the front of rear wings, instead of the present metal guards.
I did the brush on stuff on the underside of my rear wings when I built my car to try to prevent star cracks in the GRP. I did a few coats but it is chipping up quite a bit after just a couple years. I doubt it would last well on the front of the wings, which really take a beating. But maybe my product was just not a good one or I didn't get enough on there. You would need a super thick, rubbery layer to perform well I would think.
Consider bedliner coating the front of the new .050" steel guards after painting.
Edited by MV8
Please not diamond plate.  It would look horrible and not be any more effective than flat.
The problem I see on my Caterham is that the stainless guards are very good, but do not go high enough.
Many on here have seen the green with yellow Xflow that was up on bat. It has black bed liner coating on the rear fenders that wraps around to the opening. Personally I do not like the look. I much prefer PPF on the exposed area beyond the OEM stone guards to allow the car’s colour to show through. I have seen were an owner used an adhesive backed rubber to cover the majority of the stainless guards but left about an inch of the shiny silver perimeter (where the rivets are) visible. That looks really classy.
On another somewhat related subject…
My front fenders are out getting the undersides sprayed with truck bed liner. I will do the inside on the inside of the rears myself with a rattle can product if/when I ever get the car home.
Edited by theDreamer
I have ppf on my carbon (faux carbon?) stone guards 2023 420r.   And some on the exposed outer edge up to half way around the fender.  I’m a little bit crazy and kind of wish it went all the way around. The paint shows some wear past the ppf line.  Maybe I’m too precious. I also have the front half of the front fenders . And full side panels (which get pretty hammered in hard lock turns ).  I like the body colors to show.
Most of the spider cracks come from the inside of the fenders, as stones are spun up from the tires within the wheel well. I used 3M rubberized undercoating from Amazon on my 360 and 620, and then PPF on the external surface of the fenders. Works great!
Pickles
