Post your power to weight ratio.
Yes another question thread, but as I rudely highjacked the last one, I thought it only right to make this separate.
If you read the slower = funner thread you will see how this came about.
What we would like is your power to weight ratios expressed in bhp per pound (BHP/LB), if you wish to post your actual bhp (flywheel/ rear wheel) and the overall weight then please do so.
Will post mine shortly, need my calc :D
Rich
k, estimate flywheel 480 hp (confirmed dyno @ 385 before last mod - estimated gain since at 40 hp based on others with similar mod).
weight measured at 1750 lbs.
That works out to 3.64
Engine is suposed to be 280 at the crank. No idea of rwhp. Weight with full fuel 1560#.
Equals 5.57#/hp ?
At LOG I was able to get 3 Dyno pulls. 1st was just to ck a/f ratio. 2nd pull showed 230hp. Jim Summerville @ Speedsouth felt my sparkplug gap was too big. We re-gapped to 0.035". On the 3rd pull we got 240 hp @5600 rpm. Max tq was 252. I thought we had a problem because the engine was cutting out @ 5600. I was under the impression my rev limiter was set @ 6500. After calling Dennis @ Stalker this AM I found my limiter is actually set to 5600 rpm. Jim S. thinks at the crank I'm getting about 290 hp. Not too bad for a stock engine advertized @ 240@crank. Only mods are to ECU, headers, air cleaner and no pollution equip. Jim
Edited by Flibbie
Dyno run
301 RWHP, so maybe 321 HP at the flywheel. 1,350 lb with half tank of fuel.
Using estimated flywheel HP, my car would be 4.2 lb/hp.
Using RWHP from the dyno it would be 4.45 lb/hp
My car is a WIMP compared to Mazda's Franken7. :o
I'd love to take one of these boosted cars for a spin (well, not literally) :D
My Birkin is 1240 pounds and 136 whp (figure 150ish at the crank) so that makes for 8.2 lbs/hp.
But since the car can't go anywhere without my butt in the seat - the car weighs 1430 with me in it and that makes the real life ratio 9.5lbs/hp.
Dave
1149 lbs no fuel
120 HP but will not run without fuel
9.575 lbs per HP
I just tell people its power to weight is about 10 lbs to 1 HP or fast enough to get you a ticket.......About what Franklin 7's Starter produces......
I'd love to take your car for a ride as well. Someday I will make it to an event and we can try each others cars.
I might be close to skip's number.
The car was dyno'ed at 300rwhp (probably 320-330 at the crank) but is kind of fat.
the roll cage must weight about 150lbs easy from his 1400lbs base weight.
I need to weight it to be sure. But let's say 1550lbs
That's 5.1 lbs/ whp
or 4.84 lbs / crank hp
Still a fun fast car! :)
That's 5.1 lbs/ whp
unless you have a nascar style roll cage, it's not going to be 150 lbs.
