Isn't this a little embarrassing:
Well, the Kenworth has much more total drag since you have to multiply the Cd x Frontal Area to get total drag. Good thing the Se7ens are so small.
For example, typical examples of drag coefficients for typical automobiles are between 0.3 and 0.5. In particular,
1. 0.36 : Honda Civic (2001)
2. 0.31 : Honda Civic (2006)
3. 0.29 : Honda Accord Hybrid (2005)
4. 0.35 : Toyota MR2 (1998)
5. 0.34 : Ferrari F40 (1987)
6. 0.57 : Hummer H2 (2003)
7. 0.7-1.1 : Formula 1 car
Typical drag coefficients for some other bodies are:
1. 2.1 : smooth brick
2. 0.9 : bicycle + rider
3. 0.4 : rough sphere (Re =106)
4. 1.0-1.3 : person (upright)
5. 1.0 -1.1 : skier
Note that the Hummer has a better Cd than the Se7en.
In any case, its a drag, man.
But we're better than the smooth brick! :party:
The numbers above make the original Lotus Elite all the more remarkable: 0.29 in the late '50s.
Amazing that the Elite and Seven were concurrent models from a small manufacture. If I ever get to meet Hazel Chapman I am going to thank her for enticing Colin into making the Seven.
So if a Hummer and a "7" were dropped from an airplane the Hummer would win the race to crash into the desert floor?
I propose we drop all of the Hummers ever made from about 5,000 feet and then find the slowest elasped time and post it. Then instead of wasting a perfectly good "7" we just concede the race. Maybe we can get the SPEED channel to spring for the airplanes. LOL.
Remember Galileo?? Proved that theory ...wrong.. a while ago :-)
Driving a Lotus Seven, fitted with clamshells, anywhere near 100mph is for V brave men or complete fools. Always has been.
This is why the 7 has such a limited top speed. Mine at 202 hp may hit 125. I hear some can hit close to 140 but probably need 300 hp to do it. By the way, a conventional school bus has a lower cd of around .56 or just ahead of the Hummer.
If I remember correctly, Colin Chapman came out with an aero body for the 7 chassis around 1959 that covered the front wheels and extended to the rear wheels....not sure what came of it. Apparently he realized the one shortcoming of the design. Personally, I wouldn't change anything.........well maybe the wiring.
Is an aero body for a seven not called an elan? :)
Just add 300lbs and you get doors, electric windows etc.
Parked side by side there's only an inch or two difference in wheelbase and track.
The XI used a Seven frame with a few modifications for attaching the body and strengthening it for competition. The Elan's structure bears little resemblance to the Seven's.
IMNSOH the XI is the best looking car ever built by Lotus.
I visited Westfield a couple of weeks ago, after the British Grand Prix, and they had one of their Elevens on a flatbed returning from its registration inspection. They had a couple of XK120-ish headlight pods mounted on it, so it would pass. We all know what will happen to those next... Cool car.
Edited by turboeric
"The XI used a Seven frame with a few modifications for attaching the body and strengthening it for competition. The Elan's structure bears little resemblance to the Seven's."
Skip, I believe the XI had IRS, which would have entailed some significant changes from the S1 Seven frame's live axle.
The Lotus 11 was available with different rear suspension setups. The base and club models had drum brakes and a solid (live) rear axle while the Le Mans version had a DeDion suspension with disc brakes.
Actually, it was the other way around. The Seven used an Eleven frame since the Eleven was out before the Seven. The Seven was to be a cheaper version of the Eleven. Theory was, it would sell more units and bring more dollars into the fledgling company. I guess they were right.
