You are soooo right...tough to explain that to some thick-headed know-it-all. I bet some would try to claim the video was an internet hoax!
Very educational...
Thanks for sharing!
Interesting demonstration, I remember studying this in machine design. Way back in time when a 4 banger was also a calculator and slide rules were still used.
Didn't know there was that much to it. Curious what you do for phasing when you buy a new shaft?
Mondo,
When you order a new shaft, the U-joint cradles should be phased by the drive shaft builder. The burden of getting the angles right is on the shoulders of the installer. Here are two links to a couple of photos of drive shaft I've had built. Notice in both photos that the drive shaft cradles are 'welded in phase' by the shaft builder:
http://www471.pair.com/stalkerv/gallery2/main.php?g2_itemId=9538
http://www471.pair.com/stalkerv/gallery2/main.php?g2_itemId=24447
This was posted on the Stalker forum by one of our own; thought I'd pass it along. Probably the best (and simplest) explanation I've ever seen regarding proper driveshaft setup:
http://www.macsmotorcitygarage.com/2014/07/26/video-driveshaft-angle-and-phasing/
Hi Shane, That's a great explanation on how a driveshaft works or doesn't.
Also thanks for posting those two photo's of driveshafts you had made, I just
spent a good half hour looking at all your build photo's. Time flys when your having fun....
Tell your Dad I said hi.. Fun Guy...
Steve
Great video. For front wheel drive, phasing the U-joints is not good enough because of the bigger angles. They usually use a Rzeppa joint, also called Constant Velocity, or CV joint. This video's not as good, but...
Steve
Hey, Steve,
Dad and I had a fanstastic time! I do hope to do NJMP again next year if all works out. I'll definitely tell him you said hello. Can hardly wait to see what Croc comes up with, video-wise that is. :cheers:
Well, I've learned a new word tonight . . . Rzeppa. I can't pronounce it, but I can spell it and I know what it does. Very educational. :jester:
SHEP-a. Like shepherd. I heard it's Italian.
Brief OT to just say I am waiting for the last videos to arrive in my hands and then I will start watching and watching and watching....
