Guy's while chasing down a coolant issue on Monday, I did a pressure test of the system and brought it up to 16psi about equal to what my cap is rated at. At that point, I noticed that there was a very slight leak from the bottom corner of the rad. Not much, but after blowing it out with some compressed air, the leak appears to be coming from inside the rad, not from one of the outside channels. I can't see any leakage, but a drop or two every 10-15 seconds happens. Unpressurized, there is no dripping, but today, feeling the bottom of the rad, I did find that the bottom was wet, but nothing on the floor.
Can aluminum radiators be repaired, or should I put my order in at Caterham UK tomorrow morning? I'm assuming that those radiator sealer treatments in a can are for temp fixes only correct?
Tom
A good radiator shop should be able to repair it. They use special epoxy and flow it into the leak area. When I worked on a motorcycle race team, damaged radiators was a common problem. We ended up with some very strange bent and deformed radiators, but they were water tight.
Graham
Tom,
Just picked mine from a local radiator shop that I found searching "alloy radiator repair". The first radiator shop just said go buy a new one. Mine doesn't look as pretty as when it was new, but they said it is water tight. I am thinking now of adding an aluminum angle to the bottom.
Hope that your shop works out for you.
Wayne
Tom - If you end up replacing rather than repairing, you should consider a Radtec radiator. I bought one for my Crossflow, and the increased cooling is significant. Believe that Lotus 7 Club members get a discount. Plenty on Blatchat about Radtec vs. Caterham radiators.
Steve
Went to the radiator shop around noon. They weren't too hopefully with an interior leak on an aluminum rad, but said they'd take a look. I went home, pulled it of and took it over. Neat place. Their dunk tank is from 1951 and is wooden. They don't make them like that anymore. On first dunk we couldn't see any leaks. I mentioned that it was a very small weap at 16psi, so he pulled it out, flushed it out and cleaned it out and resubmerged it and this time cranked the pressure up to 16psi. Still no leak visable, but just as he said "looks like you are lucky" he saw a very very,very small stream of bubbles. So small that I had to get almost in the tank to see them. Good news is he said he thinks he can get to it. So Fingers crossed. I should know later today or Tomorrow morning.
Tom
Just use a raw egg or three. What could go wrong? :iamwithstupid::D
Are you going to include the 'banana' fix and some rhetoric about a noisy diff with that tidbit of advice? :jester:
Croc, you can put those eggs where the sun don't shine.:jester:
I just got the call, they were able to fix it and I can pick it up tomorrow morning. :hurray::hurray::hurray:
Tom
. . . . . I just got the call, they were able to fix it and I can pick it up tomorrow morning.
Tom
. . . . . . :cheers::hurray::party:
How about them eggs!!!!!! :smilielol5:
Tom
Once you have laid them they don't go back in? :confused:
LOL!!!! . . . . . . :smilielol5::smilielol5::cheers:
