JohnCh
Administrators
Everything posted by JohnCh
  1. I wasn’t able to devote much time to the engine last weekend, but did make a little progress and dealt with a couple of minor issues. With the proper o-ring/gasket for the now infamous oil pump to sump wedge connector in hand, the plan was to install the oil pump, assemble the sump, and seal up the bottom end. First problem was uncovered when attempting to attach the windage tray to the mains girdle. One of the key differences between the early Raceline sumps and the current generation is the windage tray was redesigned and now attaches to the sump baffle plate. In contrast, the original tray is secured in two planes: it bolts to the mains girdle via five M6 bolts, and to the wedge via an M5 bolt that goes through a tab bent 90 deg downward. The pictures below show my original sump bits when they arrived in 2004 and Raceline's current windage tray attached to the baffle plate (shamelessly stolen from their instructions.) Quite a different design. During the initial install in 2004, I had to slightly elongate the hole in the tab to align it with the threaded hole in the wedge. Interestingly I had to do that again this time. It was only off by hundredth or two, but it was just enough that the bolt wasn’t perfectly perpendicular to the hole and consequently wouldn’t cleanly grab the threads. A few strokes with a file and things fit correctly, so out came the Loctite 270 and the windage tray was affixed. Temporarily. Yes, that’s foreshadowing… Next step was test fitting the sump. Not expecting any issues, I was surprised to see that the oil pump side of the sump was standing about 0.02” proud of the front of the block. This should be flush to achieve a leak free seal of the front cover. Sliding the sump back and forth, it was clear it was hitting the front of the oil pump. Added to the issue above, it appears that that new oil pump casting differs from the original by a couple of thousands. Not a big deal for a normal installation, but unfortunately I don’t do normal. In the first picture below, black Sharpie identifies where material had to be removed from the pump. Although it’s a simple fix with a file, it required removing the pump which in turn required removing the windage tray. The more astute among you will ask yourselves “hey, didn’t he just Loctite that in place??” Why yes, yes I did. And yes, the Loctite was starting to set. Fortunately it was early enough in that process that no heat was required to break the bolts free, but it had begun to harden and required chasing the remains off of the bolt and bolt hole threads to ensure reassembly and toque readings weren’t affected. Second photo shows the material removed and the oil pump installed. With that problem fixed, it was time to seal the sump, but I really needed a beer, so pushed that off to next weekend. -John
  2. If it stops working after a while, it could be heat related. A failing connection can go intermittent as the joint expands from heat. After you shut of the car, does it take a while for those items to start working again correctly? If so, I'd be tempted to remove the scuttle and carefully use a heat gun on suspected joints to see if you can track it down that way. -John
  3. I've gone from 14" to 13" and the biggest differences I noticed were identified by Croc: improved breakaway characteristics and ride. I read an article many years ago talking about why, aside from the rule book, F1 cars were on 13" wheels. According to the author, very light vehicles run into issues with short, stiff sidewalls due to the low air pressure required. As the car corners and the tire deforms, that deformation takes the path of least resistance. If the tire has short, stiff sidewalls and low air pressure, that deformation happens in the tread which buckles in the middle, decreasing the contact patch. If, however, the sidewalls are taller and softer, it happens in the sidewall as tire engineers intend. -John
  4. Interesting. I wonder if there are more than two versions? According to Peter, the wedge without an o-ring groove on the sump side has to be used with the thimble assembly, and that requires the top of the port to be opened up from 16mm to 24mm. If you didn't have to do that machining and you are using the thimble, then there must have been an interim version. The photos below were taken from the most current installation instructions and show the assembled thimble, port with larger top section (have to look hard to see the step), and the thimble in place. -John
  5. Thanks, but I'm set. The o-ring (actually a gasket) arrived and is the correct part. I'm curious about your update kit comment. Are you referring to the oil pump/oil pickup interface, or do you mean a balance shaft delete kit for the 2.3L? My wedge was machined correctly, it's just that they changed the design after the first dozen sumps and that gasket was no longer used. To convert to the new one would require machining the sump as well to allow the thimble assembly to fit. Thanks, John
  6. The part arrived and I just did a test fit; we have a match! Hopefully I can spend some time in the garage this weekend assembling the engine. Which reminds me, has anyone started a pool yet on when I discover the next blocker to that process? -John
  7. JohnCh
    New Build
    Thanks. I took the comment that the honeycomb has to be fitted prior to the fuel tank to mean that dropping in from above is difficult due to space constraints. -John
  8. JohnCh
    New Build
    I'm surprised Caterham doesn't supply the boot floor in two pieces so it can be easily removed from above for maintenance access. I did my floor that way when building the larger custom boot box, and it has come in handy on a few occasions. Glad you figured out the assembly order of the roll bar and suspension before it was too late. -John
  9. Good point. In the future, when pointing out that something isn't that difficult, rather than say "It isn't brain surgery" we can say "It isn't rebuilding a Duratec." -John
  10. Thanks to prompting from another forum member, I may have had a breakthrough on the O-ring issue. He asked if it was possible the old O-ring was really two stacked O-rings that created a virtual oval. Although certain that wasn't the case, thinking about it, I vaguely remembered the O-rings were pretty distorted, so out to the garage for another look. One O-ring was pretty flattened, but the other was more wedding ring shaped and upon closer examination appeared to have tiny numbers molded into the side. These weren't legible with the naked eye -- or at least not mine -- but a USB microscope shows 1S7G 6625 AB. Closest I can find online is 1S7G 6625 AA, which differs only in the last letter. Apparently that simply designates the version number. Fingers crossed it's the right part and arrives in a reasonable timeframe. -John .
  11. Thanks for checking Skip. Sounds like it's time for Keith to update their website. Their Exocet FAQ includes the following; "WHY SHOULD I BUY FROM FLYIN' MIATA INSTEAD OF EXOMOTIVE? Well, we're very friendly and quick to respond. You also get 5% off most of our parts for the next year when you order an Exocet, which can save you a bunch of money as you finish your car." Sounds like the correct answer is "You shouldn't!" :jester: -John
  12. Hi Skip, according to their website they changed the Catfish to referral only, but they still list the Exocet as something they sell directly. Did that change? As for the Westfield, they haven't advertised that on their website for a few years and are no longer listed as a dealer on Manik's site. -John
  13. Nah, I had to stop doing that a couple of months ago. Given the frequency, my doctors feared I was at risk of developing CTE. These days, I just scream obscenities at the top of my lungs followed by very heavy drinking. In fact, I'm having a big ass martini right now. -John
  14. Your best bet is to visit Miata.net which is a major Miata forum in the US. They have a Sponsors page that features a number of companies that could fit your profile. BTW Flyin' Miata was a dealer for the Westfield SDV that was based on the Miata and I believe they are still a dealer for the Exocet. -John
  15. Those of you keeping score at home may remember Issue #3 from this post where I identified that Raceline had changed the sump design since my early unit and had supplied some O-rings in my rebuild package that were not utilized in my version. Peter explained they changed the connection method between the oil pump and the port at the top of the sump that leads to the oil pickup. Both versions make this connection via a wedge-shaped aluminum block that bolts to the oil pump and seals that area with an O-ring, but these wedges differ on the sump port side. My version has grooves cut on both faces of the wedge to accept O-rings, but the new wedge only has a groove cut into the oil pump side. The sump side is machined flat and seals to the sump via an O-ring assembly that is pushed into the sump port. This assembly, which Raceline calls a thimble, consists of s very short aluminum tube to allow oil flow, with O-rings fitted to the outside at each end. To accommodate this approach, the sump port is drilled to a much larger diameter and is reduced down to the correct size via the thimble. Apparently this newer design made it easier to assure that the hole in the wedge and the sump port are perfectly aligned. These photos show the sump port, wedge, wedge temporarily attached to the oil pump, and the pump/wedge assembly sitting on the sump port. Things turned interesting on Saturday morning when I started to assemble this area. After removing the old O-rings on the wedge, I discovered that the grooves are cut to accommodate two different size O-rings. One looked like it would accommodate the 2mm x 19mm O-rings I was supplied, but the other was a smaller diameter and the groove was much larger. Out came the calipers to measure both grooves: O-ring 1 Outer Diameter = 23.52mm Inner Diameter = 19.66mm Groove Width = 1.93mm Groove Depth = 1.98 - 2.21mm (this varied a bit) O-ring 2 Outer Diameter = 23.88mm Inner Diameter = 18.08mm Groove Width = 2.92mm Groove Depth = 1.32mm Looking at groove 1, there is a problem. The groove is deeper than it is wide, and is not machined to uniform depth. That means that an O-ring which will fit into the groove won’t protrude above the surface and create a seal. I connected with Peter at Raceline this morning and shared the pictures and measurements. He seems to recall they used an oval cross section O-ring from a Zetec oil pick up tube, but will have to do some digging to confirm. Looking on RockAuto, the Zetec in the Focus doesn’t appear to use O-rings for the pickup tube and digging through websites of O-ring suppliers and manufacturers, no one seems to make oval cross section O-rings. I ordered some plastigauge this weekend and will use that to determine the actual clearance between the wedge and sump port. If it’s really tight, liquid gasket may suffice which is the easy solution. If the initial design really did use an oval O-ring that is now unobtanium, then a trip to a machine shop to recut the groove may be the answer. This build remains…um, interesting. -John
  16. I had the same thought. Prior to those tweets I had no idea he was a car enthusiast. Learn something new every day... -John
  17. It's a long shot, but do you have 4-pots up front with inner bleed screws that you didn't bleed? -John
  18. The Lotus Elan forum has a very active thread where people chime in with brief updates on what they've recently done to their Elan. Let's see see how that concept works here. Doesn't matter if it's a repair, maintenance, upgrade, taking it for a drive, or just sitting in it making vroom vroom noises while drinking your favorite beverage and waiting for local lockdown orders to expire. If it's tied to your se7en but you don't feel it warrants a dedicated thread, then share it here. Since I already have a long, active thread about the current damage I'm doing to my Westfield, I'll start things off by admitting I sat in the car today during lunch -- I plead the 5th on drinking a beverage and making vroom vroom noises -- and reminded myself of that aspect of the driving experience. I can't wait to get this sucker back on the road. On a more productive note, I also played around with placement for a USB port. My objective is to keep it hidden when not in use, but easily accessible when the phone needs power, so I'm thinking about affixing it behind the dash with velcro. When needed on tours, simply pull it down and plug in the device. Ok, who's next? -John
  19. JohnCh
    New Lotus
    Good idea. Let Caterham buy the rights, then Westfield can make their own copy that's a little closer than Caterham feels is reasonable, and we can watch the resulting litigation on the Court Channel. It will be like old times! -John
  20. Back when I looked into this, the exchange rate was far less favorable than it is today. If I were looking for wheels now, I'd be very tempted by a 3-piece from Image Wheels. Lots of choices in design, size, and offset, and the billet versions are very light. At the time they quoted a 13x6 at 8.6 lb. -John
  21. Found the list. Rial also made a really nice 13" wheel back then, but my understanding is they stopped producing it several years ago. Other folks may be aware of additional manufacturers, but this will get you started: Image Wheels, Panasport, Compomotive Motorsports Wheels, Revolution Wheels, Kodiak Racing Wheels, Pro-Race wheels (aka Rimstock) -John
  22. If you do want to explore other aftermarket wheel options, let me know. I put together a list several years ago when I went through this process myself and am happy to dig it out. -John
  23. Your 310 uses 4x108. It's not very common, and you need to make sure the offset is correct. If you are getting a set for the track, is there a reason you want to stay with 14"? Personally, I'd look into a set of 13" Caterham wheels. There are some aftermarket manufacturers, primarily in the UK, who can make wheels with the correct PCD and offset, but the Caterham wheels are tough to beat at the price. Even I run them on my Westfield -John
  24. I spoke with Peter at Raceline this morning and once again he came through. It turns out Ford stopped fitting the second dowel pin to the oil pump about 10 years ago, so that is the new normal and perfectly fine. This means I am ready to start reassembly...until the seemingly inevitable next issue arises -John
  25. Thanks Paul. These parts are both for Fords, and they show they are for the same years, so it's not even a running change. Looking more closely at the RockAuto listings, there are different part numbers for the two styles although the descriptions are the same. Unfortunately the online listing at Village Ford, where I initially ordered the gasket and is shown below, includes a drawing of the part I need, but uses the part number of the other gasket. I guess there is no point making this easy It appears that part # 6G9Z-8255-BA is for the extruded gasket, and 1S7G-8255-BD is for the flat gasket. I'll know for certain once the order from RockAuto arrives. Now if I can just figure out the deal with the oil pump... -John
