seschm1234
Everything posted by seschm1234
To the managers of this site. Croc's post should be placed in a set aside section for a good starting point for troubleshooting engines. I'm sure there are many more that are excellent guidelines for various problems. I'm afraid it will get buried here and years from now it will be difficult to find.
Come on everyone, we are better than this. The science of climate change is done. The denial of its reality is just being contrarian to the detriment of future generations.
Looks kind of like Mike's car if my memory is correct at around 11 minutes in... I hope you will chime in on whether this is it
thank you both for the very helpful replies. Paul
Hi all Relatively recently I purchased a wcm 2sk xr7. The windshield that was included with the purchase was cracked ( as clearly described by the previous owner) and I'm currently trying to fix. The windshield.. at least for this variant is an aluminum u channel with custom automobile glass at the top and Lexan at the bottom which forms around the curves of the hood. I took this entire windshield up to a local specialty place and they said to recreate the broken glass would be quite expensive as the risk from taking the assembly apart is quite risky. If however I could do this myself the Lexan would be cheap.. all they needed was a template and to extract the glass and bring it up in as close to the original shape as possible.. . The u channel aluminum was glued with great enthusiasm to the automobile glass and that combined with the very fractured glass did not allow me to extract other than outer dimensions the frame (aluminum u channel). At our local Lowes I have found a reasonable substitute (pretty close to exact) so my last problem is recreating the shape. My question to the group is as follows, should I : a.) make a wooden plywood template which I would then have the Lexan customizer build and then mold the Lexan around this piece(i purchased a 1/4" piece already as it was cheap) b.) build a bending rig which gives me the curvature needed and run the aluminum frame through it and then place the Lexan piece within the frame? ? Finally.. should I glue the Lexan into the frame or should I rivet it? I've seen the rivet method on youtube.. and obviously first hand experience with the glue Thanks for any suggestions. Paul
Caterham Cars Has New Japanese Owners (jalopnik.com)
Just purchased the Zamp RZ-62 after trying on a bunch of helmets this weekend at Summit Racing Equipment. I was surprised how different many of them felt so I would highly recommend finding a place where you can compare how each brand fits your noggin. I really liked the Simpson helmet looks but it was a nonstarter by the way it rubbed my forehead.
Beautiful car, congratulations!
Hi All Having a very difficult time fitting the 2 gallon Peterson dry sump oil tank into my WCM (2.2. liter Honda). Currently its in the passenger footwell but will greatly impact who can sit in the car as a passenger (i.e. less than about 5'6"). The 1.5 gallon tank may work but I'm unsure about whether this is enough capacity. Currently there is not a oil cooler so if its just a matter of cooling I do have room to fit a cooler at the front. Anyone have any advice/suggestions? Thanks Paul
seschm1234 replied to Croc's topic in Cars For Sale
He didn't seem like a bad guy, many reasons he could of sold, perhaps he did want more power, perhaps over his head. Given the lack of information the criticism seems too much. -
Hi Jefferson I have the same issues with the dry sump installed on my WCM. Right now its located in the passenger seat footwell making the passenger seat almost useless. I'm 5'8" and I can't get in without me knees hitting the dash. I think your plan with the check valve is brilliant. I was concerned that the pressure head might overcome the 2psi cracking pressure but a few simple rho*g*h calculations and I've convinced myself that 2 psi should be fine. Just wanting to confirm...you didn't blow up your engine yet. :-) Additionally, did you (or anyone else) ever install a remote filter/primer like this to reduce startup wear? https://www.speedwaymotors.com/Peterson-Fluid-Systems-09-1501-Remote-Filter-Mount-Primer-Pump,350918.html?sku=91091501&utm_medium=CSEGoogle&utm_source=CSE&utm_campaign=CSEGOOGLE Thanks Paul
that is a great video, I was smiling :-)
2006 wcm ultralite s2k and custom trailer for sale
seschm1234 replied to Foxfire S2K's topic in Cars For Sale
did you sell the trailer? -
A peak into a CatKong like build at a track! The closing speed is crazy on the other vehicles. And then the 2.5 liter variant. Croc, your going to need a double coating of that paint overcoat
I will answer this question myself. My first 7 was a Caterham from the state of Washington. Having never had a car like this I didn't realize that there are good VINs and there are bad VINS. While i'm sure the state of Washington had there reasons, the VIN assigned to my car wasn't standard and therefore wasn't recognized in the "common" VIN system, it had 1 less number (i think). When I went to register my car Ohio DMV didn't know what to do with the VIN so sent me to a inspection agency within the DMV. Once there I had to produce documents that showed the engine and transmission were purchased separately. Fortunately, I had those documents and they placed a new Ohio VIN on the chassis of my CSR. The car I'm now buying is from California and it was assigned a VIN by California and Ohio will recognize these VINs so I do not have to produce drive train and frame documents. I therefore just have to take it to a Ohio DMV for a VIN inspection. Hope this was clear Thanks Paul
Hello All I'm considering purchasing a Ultralight S2K that is registered in California. It has a CA SB100 registration. Does anyone know what documents I will need to register this in ohio? Can it be registered without a windshield and wipers? Thanks Paul
Nice to be thinking about a new fun car. -
http://www.roadandtrack.com/car-culture/videos/a29846/crazy-caterham-airways-ad-shows-just-how-bonkers-their-cars-are/
The 620R is the 2.8 sec.. those heated seats, 5 speed manual and wider body on the 620 S add up to make it a real dog :-), my guess is that the 5 speed causes you to have to shift once.
http://autoweek.com/article/car-news/small-volume-carmakers-get-big-break-motor-vehicle-safety-act With the passage of the Motor Vehicle Safety Act, small-volume carmakers are exempt from Federal safety standards. http://hanabi.autoweek.com/sites/default/files/styles/gallery-thumbnail/public/img_2701.jpg?itok=gSgusD7v http://hanabi.autoweek.com/sites/default/files/styles/gallery-thumbnail/public/img_2702.jpg?itok=7gJ4TV04 http://hanabi.autoweek.com/sites/default/files/styles/gallery-thumbnail/public/sema_low-volume1-002.jpg?itok=N85ULLXZ http://hanabi.autoweek.com/sites/default/files/styles/gallery-thumbnail/public/sema_low-volume2-002.jpg?itok=nPfbTzQa [h=2]THEY ARE EXEMPT FROM NHTSA CRASH TEST STANDARDS AS LONG AS THEY MAKE 325 CARS A YEAR OR LESS[/h] Read more: http://autoweek.com/article/car-news/small-volume-carmakers-get-big-break-motor-vehicle-safety-act#ixzz3teAXYsLC
