Everything posted by Bonjo2
Where did you get the splitter and how much. I am trying to fab one now but am falling short on time. Car is an inspiration. A
Last call. New Prices. $265 plus shipping (about 20) takes all. ($504 value). 24-006 - ACCUSUMP 3QT NO VALVE (24-006 $249) New, test fit, still factory air charge w/manual valve +. # 24-270 - ACCUSUMP ELECTRIC VALVE KIT (24-270 $189) Electric Accusump Valve kit provides a convenient way of operating the Accusump. They are useful when the accumulator is mounted in a hard to access location. When wired directly into the ignition switch the Accusump can be operated automatically to provide pre-oiling. The kit comes with the electric valve which has 1/2" N.P.T. female threads, a 1/2" N.P.T. pipe nipple, a toggle switch, a length of wire, terminals and installation instructions. Recommended for use in street and pre-oiling applications only. T-fitting + check valve + Mounting clamps included $85 Differential Cover High capcity w/brace adn fill/drain plugs. Trick Flow Specialties TFS-8510400 GM 10-Bolt 7.5/7.625 ($143) $40 Hyundai radiator Locost, Brunton Stalker, Westfield, Caterham used, approx 15 miles. $250. Birkin Rear wings/fenders. New. Primer finish. Never fitted. Drivers side has recess for muffler. Local only. $25 each 10 Ft push-lock hose. -10 AN oil line have 30 ft.
Another military move planned. Before I ebay or craigslist. See the photos, ask questions.. Willing to bundle. I drive to Montgomery Village MD/D.C. from Hampton VA almost every week, through Richmond. Can meet most Fridays and Sundays on 64, 295, 95, 495, 270 $150 Heater. New Heatercraft R08208 Ducted heater set. New. Complete. Now listed at over $300! I will include Four Seasons 74627 Manual Heater Valve ($19). Perfect heater (water w/electric fan) for HOT RODS, JEEPS, off road vehicles, Lotus and Cobra Kit Cars or most any other water cooled engined vehicle. Details here. http://www.jcwhitney.com/heater-kits-fo ... 5c2307u0j1 Shipping, about $18 lower 48. $150 Steering Rack. NEW Flaming River Ford Mustang II 4" x 4" short steering rack. Still in package. Popular for Stock Cars, Drag, Cobra Kits, Manual Rack Conversions, Hot Rods, Street Rods, and Muscle Cars that use Mustang II/Pinto Style rack. Sold race car and have no use for item. Paid $469 two years ago. New, Still packed in original box. More info - http://www.rjays.com/Flaming_River/racks-01.htm Local pick-up/delivery. Shipping ADD actual costs, around $29 $40 each. 2 American Racing AR 23 wheels. 4x4.75, 3.5 backspace, 15x7". 5 spoke aluminum wheels. $200. 24-006 - ACCUSUMP 3QT NO VALVE (24-006 $249) New, test fit, still factory air charge w/manual valve $100. 24-270 - ACCUSUMP ELECTRIC VALVE KIT (24-270 $189) Electric Accusump Valve kit provides a convenient way of operating the Accusump. They are useful when the accumulator is mounted in a hard to access location. When wired directly into the ignition switch the Accusump can be operated automatically to provide pre-oiling. The kit comes with the electric valve which has 1/2" N.P.T. female threads, a 1/2" N.P.T. pipe nipple, a toggle switch, a length of wire, terminals and installation instructions. Recommended for use in street and pre-oiling applications only. Add. T-fitting + check valve $20 Mounting clamps $10 $50 NEW Lingenfelter oil cooler adapter is designed to allow the installation of an oil engine oil cooler on GM Gen IV V8 engines including the LS1, LS2, LS3, LS6, LS7. The LPE adapter is machined from a single piece of 6061 aluminum and is then black hard coat anodized for additional durability. The adapter features -10 fitting for the oil inlet/outlets along with a port for the oil temperature sensor and oil feed line. This adapter was specifically designed to reduce oil pressure drop over other designs on the market, retains the factory oil filter location & includes gasket and bolts. Oil exiting the adapter is filtered oil. Will not fit 2004-2006 Pontiac GTO. $65 JAzz 0-90 ohm 11" long fuel cell sender (tube type works with foam) #371-090-03 ($119) $20 VDO 0-90 Fuel Gauge ($36) $85 Trick Flow Specialties TFS-8510400 Differential Cover GM 10-Bolt 7.5/7.625 ($143) $25 Longacre 1.75" roll cage rear view mirror racing stock car ($49) $20 Generic 16-row oil cooler, new. -10 AN $50 Hyundai radiator Locost, Brunton Stalker, Westfield, Caterham used, approx 15 miles. $40 Caterham style front indicator pods, carbon "look" with turn signals Modified to fit Brunton stalker or Locost style mount/perch. $5 LS Oil level plug $45 Locost/Lotus seven grill, alumunum $300. Birkin Rear wings/fenders. New. Primer finish. Never fitted. Drivers side has recess for muffler. $300 local only. $10 JDM Honda Civic side markers, only the lens housing, no bulb holder. $10 Wilwood brake fluid level remote reservoirs 2 with mounts, 1 without. FREE Fuel Level Sender. NEW British standard fuel level/Float Type. 260 Ohms at empty to 20 Ohms full. Free. + Shipping $25 each 10 Ft push-lock hose. -10 AN oil line have 30 ft.
I have a new set of Birkins that never made it onto my locost due the arch a bit larger than stock. Collecting dust. 12" wide.
Xcarguy. I didn't realize any of the alu wings were smooth on bottom and a real airfoil shape. Do you think there's enough surface area though or enough open/clean air to make the wing work--underside of the wing most important so acts more wing and less spoiler. I cannot wait to hear your feedback on the wing. I bet it could easily be modified to work on front. Suicide plywood roof--Yikes..
Yeah, that video is very tame... I will have a bonjo2 channel setup soon to document the car exploits.
I know Meyers hit high 170's, like 178 at VIR. A kite is a great way to describe the feeling over 140. I am considering the ugly Donker D8 270 style wings in front and rear, but am hesitant given the open cockpit and roll cage. Anyone have any photos of a decent lower cost (not the $1400 front and $2300 rear GT style carbon) option on a seven?
Would love to try a monster mile...
Anyone know what it would take? My initial guess is 500BPH and proper gearing, no fenders, lots of duct tape, no windshield/screens, covered pax compartment, and some Indy/F1 style front and rear wings. Right now my car is nutty quick, but scary over 100mph, like hydroplaning. It's like the car wants to lift off with the panel behind the seats, front wings/fenders, rear wings/fenders, and brooklands wanting to blow apart.. Let off the gas at speed and the throttle-off rear lift/oversteer is worse than an old 911.
I drive the car all the time. Rear wings already sandblasted. Very cool, very rapid.. I hope to replace the seats and maybe finish up the body and wiring sometime in Jan. It's just so much fun to drive. Not fun to work on.
Dude, Your "last weekend" photo rocks. My new favorite, big toy next to kid toy. I might have to order some new front wings if you can report on how stable they are at speed. Mine flop around like mad at 60. Your garage ad car too clean though.... Mine already looks sand blasted and worn and only 647 miles on the odo. A.
I think if you can find some 225 drag radials you'd be shocked at how much a properly spec'd tire can do. If 1000+ lbs heavier the larger tire might prove quicker. I just cannot imagine this little car being able to generate enough heat to make work on the street, esp Sep through May. I am running the 225 BFG drag radial dot approved. They are plenty stiff, provide great feedbacks, heat evenly and quickly at 15-20 psi. The only drawback, aside from the odd truck bolt pattern American Racing boat anchor wheels, are the limited sizes offered. I had to re-learn the whole tire economics game.
The car is wicked brutally quick. No drama, it's just a rocked. If I start in 2nd I can get to 60 without a shift in about 3 seconds. If I push, and stick, maybe much quicker. I really need to get some track time so I'm not always getting surprised on public roads and grinning like a retard. It's funny how the tires broke loose and marked the road accelerating from 55 to 80, and how 80-110 happens about as quick as a breath. Now, replacing the pinion seal and axle yoke. For some reason the yoke flange/dust cover has a split in it and tore up the pinion seal, pouring all 3 quarts of 90 weight onto the lot.. Aside from my drippy rear end, the only downside so far has been wind buffeting over 80, seatbelt slapping face at 90, and anything not buttoned down flying high into the air over 100.
I'll probably keep. They are about 14.5" standard size. You can get them on Ebay for 100-150 brit pounds, then add about 75 pounds to ship from the UK. They now have a cut down style for 2012 in all colors. http://www.ebay.co.uk/itm/Black-GRP-Seats-for-kit-car-locost-westfield-robin-hood-/110964297214?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item19d5fccdfe
I've a pair of new Birkin rear wings, 12" in primer with a thin coat of bed liner on the underside. Unmollested-no holes other than the mount holes they came with. Drivers side has a light rise in leading edge for what I assume is clearance for exhaust. Looking for a local VA-D.C. sale. I drive to D.C. every two weeks and can deliver. I opted to go with the Stalker rear fenders to avoid a gaps and having to custom fab mounts.
My fiberglass racing buckets are too narrow for my big butt. Looking for a pair of the standard Caterham, Westfield, Birkin seats.
Yes. Mike gave me a very spirited ride. Car is fantastic. I was most impressed by the no drama acceleration. Car was mad. I post some photos on the Brunton web gallery #156. My car runs, now it's just a matter of finding time to get bodywork together. Email me anytime. bonjo2 at gmail dot com
finally. No gotta get that carbon dinoc on the hood and scuttle, put sme fenders on, and go for a ride...
Thanks wolfe. Red Park Black GRND Blue w/White Stripe High Beam Blue w/Red Stripe Low Beam
Europa Spares 9060A (Caterham Style) Tail Lamps are.. Red LIGHTs Black GRND Green TURN Green w/Purple Stripe BRAKE
Does anyone know offhand the breakdown. Thanks in advance. Caterham Headlights. Red Black Blue w/Stripe Blue w/Red Stripe Eropa Spares 9060A (Caterham Style) Tail Lamps are.. Red Black Green Green w/Purple Stripe
Awesome!!
Shark's car is nuts. He gave me a spirited ride a couple weeks back and I was shocked at how it just hooked up and hauled the mail. I was expecting lots of wheel spin and oversteer. Amazing car, well built too. I sorta wish I could just buy it and drive vs. spending any more time in the garage finishing mine. I do not believe you could build anything as fast and that works as well any cheaper.
Looking to sell locally before going the ebay/craiglsist route. Best Offer for any USA7s, Locostusa, or StalkerV6 friends. Please email me at bonjo2 at gmail dot commm vs. PM me. - Brookland Aeroscreens. Pair. These cost about 55lb/$90 each from the U.K. - Steering Rack Flaming River Mustang II short pinion steering rack FR1502-4X4 $200 - American Racing AR23 wheels, 15x7, 5 on 4.75 bolt pattern (chevy), 3.5 BS $120 Pair, or $200 with tires below. - Pair 205/50R15 Yok ADVAN Neova AD08 Mounted and balanced-less than 10 miles on setup. Sold $110 pair without wheels. $200 for pair w/ American racing wheels above. - Pair Pypes polished stainless steel muffler tips, stainless 3” input, dual 3" square slash out, weld on bling for big pipes $65 -Lingenfelter oil cooler adapter Part Number: L300025297 List Price: $99.95 designed to allow the installation of an oil engine oil cooler on GM Gen IV V8 engines including the LS1, LS2, LS3, LS6, LS7. - Universal remote oil filter adapter, sandwich plate and filter adapter.. ebay special. $10, no hoses. Has -10 AN fittings, fits acura oil filter. Has 2 fittings for temp and pressure sensor. Machined alu, straight from China. - Corvette C6 LS3 Stock OIL PAN. No gasket or bolts -Aluminum Hyundai Radiator. Small and Light. Perfect for Locost/Westfield lotus seven kit cars. Also works great for nearly all fwd import drag cars. Simple. Lightly used. Great shape. Stock on Stalker V6 and V8. - JAZZ 0-90 OHM fuel sending unit. 378-090-03. GM 0-90 ohm 8-1/2" long. Great for fuel cells 9.5 to 12” deep. Came pre-installed in fuel cell. Swapped out for Ford Sender. Matching VDO Cockpit electric Fuel Gauge. NEW $50 for both.
