Everything posted by CBuff
CBuff replied to Croc's topic in Cars For Sale
My 2023 420r with 3.91 rear end and 5 speed (11k miles ). The lsd has started to make a lot of noise. Slow full lock turns sound like it’s coming apart. Pre load is still at 38lbs and the wheel turn in the same direction when raised. the sound makes me think I am living on borrowed time. And I can’t stand the clanking grinding noise anyway. spoke with Steve perks at Tracsport. He is sourcing me a new 3.64 diff from caterham and dropping in a Tracsport lsd and sending me the entire unit. We will see if I have the skills to replace the unit. Money sent late last week. Will see when it arrives. -
I know I am relatively new to the group. But it will be strange to not see @Croc in the grey csr. Now just a purple streak going by.
This topic had thinking more about this. Decided I needed more kit. Just got this https://no.co/gb20/specs I figured $80 and 2.5 lbs was worth it for me. I can keep it in the boot and keep it charged with the usb I have in there. And use it if needed. They also have one with integrated air compressor but opted out since I already have a small usb air compressor I didn’t love the bigger size. https://no.co/ax65 The gb20 came same day (Amazon you’re scaring me). Good quality like most of noco products. Small. And I can use it as a power bank in a pinch. Flashlight and strobe if I end up on the side of the road.
So I am only 9sec off the pace. (An eternity). Devils pass? Maybe the slicks will help me, likely not 9 secs
I have some cost effective no name agm battery. With my kill switch off I have let it sit for multiple months and it starts with no issue. I do have a noco battery tender but rarely need to use it. If I am fettling with the car or testing electrical stuff and have a decent power drain I will plug in the tender. So far so good.
I kinda liked @Croc with an older car with questionable tires and transmission. That somewhat leveled the playing field. consider this my standing point-by for you on our next outing.
Small update. Haven’t tried the Hoosiers yet. The r888rs have been on for a couple hundred miles, all street and some fairly aggressive. No signs of contact on the stays. The tire pubes got knocked down a bit (assuming with contact on the stays). But there is still a little pube still there so I assume that’s the clearance that remains. need a track day to test the Hoosiers. Or maybe pick some good roads and do a soft street drive in them.
Hoosiers r8 mounted to the extra set of wheels. 195/60/13 front and 215/60/13 rears. The tire shop took days to mount them as they broke 3 “spoons” (I’m guessing the name of this ) on the tire mounting machine. That bead is no joke. But to his credit he was not going to concede the defeat. Tires mounted and the clearance isn’t all that different to the Toyo r888r. I think (hope) the stay clearance works. Have not had the courage to test them on the road yet. I guess if I can make a track day soon ish will be the real test. I have run the r888r hard and haven’t seen and contact. Will see how much the Hoosiers will deflect at full tilt on the track.
I’ll guess I’ll pray for mechanical breakdown otherwise feel free to wave hello on your way by. what size slicks are you running in the front. I went with the 195 60 13 Hoosier r8. Yours seem skinnier than that but may be the photo. Are those the Apollo 6” wide 13” wheels ? tell me your secrets.
@Croc tell me that’s your 620. I think you might have a slight caterham addiction (envious eye roll).
CBuff replied to savagete2860's topic in General Sevens Discussion
Just came across this option for rear coverage. Haven’t tried it myself so caveat emptor -
Mine started acting up last year. Tweaked the gap spacing and it worked as intended. The light does pulse when you rotate the hub and the reluctor wheel passes by sensor. One attempt had it reading well at low speed but above 60-70 it would act erratic. Small tweak to gap fix this. (2023 420r) https://www.caterhamlotus7.club/forums/topic/257730-speedo-sensor-replace/
I am always excited to get into the cat and go for a drive. If it’s a decent amount of miles I am also excited to get out of it. That’s how I know it’s a long enough drive. A trip out to Colorado or across the country is on my bucket list. @CWThomson well done. That’s no small achievement.
At least in ny you need a vin to get insurance. And insurance to register. So the ny dmv inspects and assigns a vin. At that point the make is “custom”. Preliminarily I asked Hagerty if they would insure and caterham and then asked for a quote. $2400/ year which surprised me. Then when I got the vin assigned and they designated “custom” it was $1200. Even with my mco and all the invoices from caterham to prove worth. Hagerty said. It’s custom not caterham $1200. but @Vovchandr agree with you on the model/maker designation, especially on agreed value makes no sense. I’ll take one of the few financial wins in that whole process.
I just renewed my hagerty policy. No change in price from the last two years. In NY it's $1130 (plus $70 for the club membership). For agreed value of $80K - 2023 420R. In new york it's titled and insured as a "custom" as when I originally did it with "Caterham" it was $2400. But all the back up was caterham stuff so I was transparent. They said, if NY titles it as a custom then thats what it is. A very rare occurrence that after jumping thru all the hoops, it saved me a little money
Received my zoom mirror the other day. Haven’t had a chance to mount it yet. But looks great. Thanks for the inspiration.
@Vovchandr you drove there? Hey hey!!! Get the miles on that thing.
https://www.caterhamlotus7.club/forums/topic/261100-headlight-dipped-and-main-beam-problems/ this may give you some ideas on where to look. Although it’s likely a bit different wiring layout. maybe use a tracer to find where the cut out is happening. https://a.co/d/07OC6834
Would something like this work? https://www.amazon.com/BTMETER-Travel-Protect-Handheld-Anemometer/dp/B07JVNYNB3/ref=sr_1_1_sspa?crid=34QWL1KG36VVG&dib=eyJ2IjoiMSJ9.Hku2tRKa0IcyYiLdSpw_rBTmZmcoVh17yuDdzcO5YBIO0iCPodLACS4BuzC2XbBcAOdcKFXeuZ0RgoNoj7IEAi1ZW5mCpmNjkiCbRM1SkFrL-cnJbkYqt2MuDMfVZTuN2JWDBTqoisU9AFext8uSIgiXC45V3rtRuLonbpHZ1DseOSg_vkkQssXCrYQvowezbCGCBp1-X4RFk2KsZG40rP2wknEKwKmEWv1Gg1y5hepoy7PWvb_68p_hDW4h0UdE92aId7AGsBW7LFyFsIoAXje3JAAFRZYugxKDpcFxPGI.h7USq8Cp-pyGHminHej30D6fkaC7LETzdAFoxBBsl04&dib_tag=se&keywords=wireless%2Bair%2Bflow%2Bmeter&qid=1779142854&s=industrial&sprefix=wireless%2Bair%2Bflow%2Bmeter%2Cindustrial%2C120&sr=1-1-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9hdGY&th=1
I’m filing that under “seven immunity” like not mounting my front license plate.
