CBuff
Everything posted by CBuff
  1. Well after a year and 10 tracks days without incident it looks like I too have the brake reservoir issue. On Sundays track day at nyst I noticed some fluid (brake) on the right rear wing. The ppf did its job although it has left some evidence on that. The paint seemed to fair on. There was about a 20% drop between the min and max line. seems like this is a common occurrence with hard track driving. Maybe I just wasn’t pushing hard enough thus far. in looking online. https://www.caterhamlotus7.club/forums/topic/267797-leaking-brake-fluid-resovoir/ Seems like the ac race cape with bellows is the strong suggestion. But with this you lose the low level warning. I hate to lose this function but I check quite frequently and not sure I would even see a warning light in the middle of tracking it. The risk of paint damage is far greater than the warning light. I have read about needing to remove the baffle and rubber seal as the bellows performs both functions https://caterhamparts.co.uk/master-cylinder/914-brake-master-cylinder-cap-race-no-float-switch.html will likely get a brake reservoir sock for a belt and suspenders approach. question: I assume the float switch is open unless the level drops thus closing the loop and triggering the light. So leaving it disconnected (as the race cap doesn’t have the float). The light would remain off. Might just shrink wrap it and zip tie it out of the way
  2. Clearly I wasn’t going fast enough if they got a pict of me.
  3. Great day at nyst. Thanks @11Budlite for the camaraderie and competition. It was nice to meet your son and watch those Exocets make us look slow.
  4. Inertia switch ? When I change the oil I unplug it to cycle the engine without starting. Sometimes when I reconnect it doesn’t quite jump into action without some fiddling. Once it’s working it’s fine. Mine is mounted next to brake reservoir. On firewall.
  5. A great couple of days, sadly can’t go tomorrow. Some sevens in attendance. https://limerock.com/events/historic-festival/
  6. Weather looks good. I registered. See you all there !
  7. I got the license plate holder from Josh at rmc. Works great. Also put a silicone surround in the plate to make it a bit neater.
  8. Yes you can drain and fill in place. The new builds have a grommet from the left (driver) footwell. Inside the cockpit. If you have carpets it should just pull back to expose. You will need to cut a plug out of the heat insulation but you can stick it back to the grommet to reapply and cover with heat tape for future removal. Restick the carpet with temp spray stick.
  9. You usually want to make sure you can loosen the fill before you open the drain (in case you drain and realize you can’t refill). But if you’re pulling it it’s less than an issue.
  10. 420 r with Miata 5 speed trans fluid fill (there is a grommet into passenger footwell) Drain
  11. My daily just got hit while parked by a New York DOT employee minivan. Apparently New York self insures (ie no insurance). They advised me to mail a letter to the comptroller of the city. And they would respond in 4-6 months. Also advised they would likely pay a portion of the invoice. So I went thru my insurance - $17k in body work later the car is back. Still fighting with the insurance and the city to get my $1000 deductible back. Which is more about the principle of the matter than the money. Totally ridiculous.
  12. Hagerty agreed value. State Farm and Allstate etc couldn’t figure it out in New York. My rates actually went down since I initially was quoted from Hagerty as a “caterham”. But when it was titled in New York as a specially constructed vehicle rates went down by 20%. I was very clear with my paperwork of the origins of the car. Hagerty said “if that’s what ny calls it then that is what it is”.
  13. I am always game for a track day. Happy to invite myself if @yellowss7or @Croc are game. I’m probably getting to the expensive gift point in my mooching.
  14. All my passengers are silent or near silent. Possibly with fear. They only start talking when we stop.
  15. https://www.motorsportreg.com/events/masstuning-trackfest-sep-7-2025-new-york-safety-track-nyst-748419 Some talk of a few sevens heading there. Likely wait to commit to a few days prior for clear forecast. Get em running !! Fun track and mass tuning runs a decent operation and I believe allows ride along etc.
  16. When I checked my turret oil in my 420r (Miata 5 speed). In checking online videos, mostly of Miata’s, they have a lower dust boot. My 420 does not have this and the leather outer boot is the only thing separating the inside of the tunnel to the cockpit. But I guess if you really wanted an open gated shifter you could figure out how to attach the lower dust boot.
  17. Is there some type of rubber grommet or boot under the gated shifter. If not I would think you would get wind, rain , dirt blowing up into the cabin.
  18. It’s the go you have trouble with.
  19. @slowdude you”re earning that moniker recently.
  20. https://bringatrailer.com/listing/2010-world-class-motorsports-seven-replica/?fbclid=IwY2xjawMKEJtleHRuA2FlbQIxMQABHnyy0Qdpb6Kn5aS6jrbdpr3C52MaRoMhgrckVqFADXDBOaootbt1T2W7dbEa_aem_KK11emR7BGkLETWzHAUlGg
  21. Cannot really argue with you on the factory center mirror. I still use it with windshield but it shakes around. Likely upgrade at some point. I do have the spa style on the aero and both side and center are solid. I think folks have mounted the spa on the scuttle even with the windshield. Some discussions on long post or cut down post to change the heights but love the spa in action. They can be a little delicate so be careful with any strong cleaning agents etc.
  22. https://www.dpr-motorsport.com/news/dpr_mirror_mounts the dpr are convex and although tiny give a nice solid view behind you. mirrors https://parts.dpr-motorsport.com/contents/en-uk/p85
  23. https://bringatrailer.com/listing/lotus-seven-replica/
