slowdude
    NYC
    95 S3 DVA Power
4,096 profile views
  1. She sounds great. Good tickover.
  2. Will ping you on ig. I'd be down, depending on sleep levels.
  3. There is a mod to completely bypass the MFRU. It may make more sense. I carry an extra MFRU from eliseparts in the car just in case. https://www.caterhamlotus7.club/forums/topic/267524-k-click-relay-mod-to-bypass-mfru/
  4. Did you leave the knuckle magnet with the car or can I put it on my (questionably) running car?
  5. Pm'd back. Send me a photo of your plug - I have a bunch and there are two temp sensors with different threads.
  6. those look so cool. cant wait to see those on the track this year.
  7. Further info. Car went out for a bit, was getting lean spikes when i accelerated. Went through and tweaked: Accel enrichment: Accel Max enrichment upped to 35% Clamp 50 Decay 22 Accel Rate Threshold Then, I was also getting some timing advances randomly when I would clutch in and coast -> Idle ignition control was set to 2100 RPM. Backed this down to 1350RPM, slightly above idle. Next break in the weather and I will go out and test the changes. I didn't push too far given the lean spikes.
  8. I've seen the car in person. It's very well built / thought out and the attention to detail is imppecable. Seller is a great guy.
  9. I actually may have an A127 equivalent - A127's are near impossible to find new. I have a 100 amp Powerlite 676 (right) side alternator. (RAC676) Alternator 100 Amp "Right Hand-Unit" - PowerLite Units one of these, but I wouldnt charge you near that price..
  10. Overdue update, car is still misfiring on the K6 ECU. I sent it over to Emerald in April for them to review. Still waiting on a verdict. In the meantime, I snagged a used emerald K3. Ported over my map. Just got done confirming timing. I was able to get the car running, idle it is dead solid at a 12 degree advance (locked). When unlocked, and given gas, the timing mark moved to the right, it didn't jump. I'm hoping this ECU is the culprit, and will go test it this weekend. QED lightweight 1.4/1.6 Rover K series Emerald flywheel settings (in case anyone needs them): 36/4 EU2 Rover Flywheel drop down Reference: 125 degrees (124 or 126 had a slightly worse idle). This is based off the idle stop screw being set to a good idle on the previous K6 ECU. Will update later.
  11. Josh is a good dude, always willing to help out.
  12. Oatman was amazing. The whole time I was driving it, all I could think about was having a 7. I didn't miss the 7 for that stretch out into california - outside temp was close to 100 degrees. Did you run a half hood?
  13. Hey Terry, I am going to have the 7 out this weekend, may go for a short drive with another 7. You're welcome to come by Saturday. I'll PM you my address.
  14. I wish I had seen this earlier. I just got done with a 2.5 week chicago to LA route 66 trip. I am sad I didnt see you. I suppose any advice now is moot.
  15. Good and bad news. Good news is the car is running on the new ecu and means it can be tuned / driven. Bad news is I'm travelling for work starting wednesday, and will be back around memorial day, if that can scratch your itch. happy to help you try the car out.
