You may want to connect with the Lotus Owners of New York group, based in the Buffalo area. Likely to be some Sevens in that group.
I recall a person I knew in Jamestown, NY making a Spitfire based “Seven” like car. This would have occurred in the late ‘80s.
Unfortunately, I don’t have any photos and it’s been quite a while. I see that he died in 2018.
It’s pretty important to have some filtration in order to prevent not just large debris but dirt and sand from entering the engine, which will cause premature wear of the cylinder walls.
The opening in the hood of my car is somewhat restrictive and I’ve been using a short K&N filter. I’ve experimented with foam filters over trumpets, but they made it difficult to remove the hood.
I’m in Canton. My car is a Series 3 chassis with the long cockpit and old style seats.
You are welcome to come over and sit in the car. Unfortunately, driving (the real hook that will get you to buy one) is out at this time of the year.
Unfortunately, Copart requires a member number in order to enter the lot.
It costs $99, so I'm not going to look at the Seven in Flint. Too bad, I was looking forward to it.
The person I talked to said the car would likely be sold on Wednesday.
I’ve stayed away from additives because of the concern that they can cause deposits in the combustion chamber. I use good quality fuel (Mobil 93 octane). The valves and seats are modern materials and my valve clearances remain within spec. I’d also state that I haven’t been thrashing the car on track, so that would also be a factor.
An Elise is bigger than a Seven and more civilized too. It does everything right. It’s a relatively simple car and quite reliable too. The engine is in the right place and the driver feedback is unmatched.
