dhubbard422 started following DaveD
DaveD started following Off Road SHO
Tom, I don't feel so bad, looks like I was in good company. Please add Bev and I to the list of attendees. I hope to work on getting Bev to drive in the Green group this year. I am really looking forward to driving Thunderbolt unobstructed this time! Thanks, Dave
If you still need the Datalog software, send me a PM. I use the Pectel software on my Zetec.
Tom, No. Car is sitting waiting for new timing belt pulleys. The idler pulley bearing disintegrated. I cracked one of the front fenders at the mounting bolt (thanks to one of the many bad spots on the roads here). I have not driven it much this year. I had hoped to work on it this year and paint it, but too many other things have taken priority.
Todd, Thanks for posting a couple of excellent driving videos. I see so many videos of cars that are being thrown around and the driver is so animated with yanking the wheel back and forth trying to squeeze too much speed out of their car. Your video is an excellent example of smoothness and consistency and the speed that is rewarded by doing so. I was surprised to see the Mustang at the end of the race in the first video. It looked to me like when it was just the 2 of you in the second video, he was able to slow you up enough in the first couple turns after the straight that it enabled him to keep you in range to pass again on the straight. But that did not happen in the first video. Kudos to you. I like your car too! Dave
I am jealous! Maybe one day I will move to Montana where a vehicle driven year round will last a while before it turns into a pile of rust! Dave
DaveD replied to Croc's topic in Cars For Sale
I contacted Dave Cope a couple of times. He was not able to help me. Here is the information on my car. Much of it I received from the original owner. Vehicle Description This is the ULTIMATE Superformance S1 (Lotus 7 replica car). The Superformance S1 was produced until 2004. This car is number 50 of about 56 cars produced. The car came from the factory as a rolling unit with only the installation of the engine and transmission required to complete the car. This car was produced in 2003 and was built up by the original owner in Ohio. I purchased the car used in 2005. I use it mostly on the weekends to tour the country side and have also auto crossed the car and participated in a couple of track days at Summit Point and 3 track weekends with the USA7s at NJMP. It is loaded with many performance and appearance options. It is one of the coolest looking Superformance S1s built. It is also the highest horsepower, naturally aspirated, Superformance S1 that you will find. The car idles smooth as silk, is as streetable to drive as your daily driver, has incredible acceleration (4 Flat - 0-60!!), it pulls hard all the way to the 8500 RPM redline. This car was dyno tuned and puts out 150 HP at the wheels. This serious driver's car turns more heads than anything on the road. It's the best balance between "Show" and "Go"! Wheels/Tires: 17" Chrome ASA KA-1 Wheels. Toyo Proxes T1-S Tires. 205/40ZR-17 Front, 225/40ZR-17 rear currently used for the road and the stock 15" Wheels with 205/50R15 Hankook Ventus z214 Tires for HPDE driving. Interior: Carbon Fiber Dash, White Faced Gauges, Removable Streering Wheel, Lotus Logo Shifter Nob. Engine: Built by Performance Engineering, Ross, OH. Ford ZX3 DOHC (Focus) Block and Crank. Eagle H-Beam Connecting Rods. Forged JE Pistons, 10.5:1. Ford Racing Performance Head, Ported/polished, w/ 1mm oversized SS Valves. Piper Cams - Road/Rally Cams 3000-8500 RPM Band. Performance Headers, Ceramic Coated. Webcon Multiple throttle Body Injection System. Pectal T2 ECU - Fully Programable 3D system w/ Software - designed for the Zetec Engine. MAP Sensor controlled for better drivibility and tuning. Airbox - Cold Air Induction System. McLeod Ultra Lightweight Aluminum Flywheel. Centerforce Heavy Duty Clutch Transmission: Quaife Clubman - Semi-Helical Cut Gears. Rally Gear Set 1st - 2.40:1, 2nd - 1.54:1, 3rd - 1.21:1, 4th - 1.00:1, 5th - 0.87:1 (OD), Rear End Final Ratio - 3.90:1 Follow this link http://www.usa7s.net/vb/album.php?albumid=29&attachmentid=8155 to pictures of the car when I bought it from the Superformance Dealer in Cincinnati on consignment. It had just over 4K miles on it. Thanks, Dave -
I would like to try my S1 in the snow, if it were not for the caustic salt and liquid paint remover they put on the roads in MD/PA. I put it away at the first application of that stuff and keep it there until the rain has cleaned the roads off. I had a 95 Mitsubishi Montero SR that I loved. It was the best all round vehicle I have ever owned. That crap took all the paint off under the vehicle and it was falling apart from corrosion. I took it to a metal recycler and the worker who told me where to drop it off, asked me why I was getting rid of it. I told him to go look under the vehicle. He turned white when he saw how bad it was. I have seen video of sevens in the snow and it looks like, with snow capable tires, they would be a lot of fun as long as it does not get deep enough to turn it into a toboggan:eek:. Dave
Thanks guys for the good words for the S1. Thanks Mike and Shane for posting the pics and video. I really like my S1. The car as delivered is a great car, but I have spent a lot of time on mine to get it where it is now. I lucked out in that the original owner did a great job with the engine setup (Zetec), and type 9 trans with a Quaife Clubman Semi-helical rally gear set. It does really well on the track. I found with this setup though, it is only mediocre for autocross. My red-line, 8500 rpm, takes me to 65 mph in 1st gear. As far as what do you do about parts, so far I have had to take care of everything on my own. I tried the Superformance guys 3 times and did not get any help. I still have stuff I would like to take care of, but everything I have done so far, I have had to figure out on my own and find someone to fabricate parts that I could not do myself. The worse one was the front spindle carrier that broke when an instructor at the autocross school at the Carlisle Import/Kit car show put it into a chain link fence trying to show me how to take the chicanes (NOT!:banghead:). So for anyone considering buying an S1 be prepared to do most things yourself or find someone competent that can do it for you. I have pictures posted of the roll bar(s) here http://www.usa7s.net/vb/album.php?albumid=28 you need to be a USA7s member to see them. I would be happy to talk to anyone who would like to know more or has questions. Just send me a PM. Dave -
Mike, Thanks for the camping info. Dave
Mike, If I brought a camping trailer down, can I set it up at in the Paddock of Lightning for both days? And is there a cost to do that? Thanks, Dave
Dave's avatar is from 2005 when it first showed up in the garage. No, it has not been painted yet! :banghead: It needs touch up work first.
Count me and Bev in. We have attended the previous 5 years. Wouldn't miss the event for anything.
Yeah, but it still looks beautiful. The picture looks like a great ride! It sucks with it getting dark so early now. I am looking for a day like that on a day when I have time to get mine out. Dave D
Yeah, and all the wings and rubber to try and get that power those extra pistons are making to the ground!!!! Would love to see you use that power without them, like most of the rest of us. :willy_nilly:
