CSR Article in Pistonheads
lucky dawg
I'd be quite open to idea of CSR's if they weren't all SV based =/
They really should throw the IRS into a std. chassis. The front shock arrangement is cool, but doesn't bring a lot of function. It also make shock/spring changes more difficult.
Daniel
I'd like to see the IRS thrown into a deep canyon; but I digress.
It does improve the aerodynamics to some degree by cleaning things up and reducing drag. Maybe not by a huge amount but some and, besides, inboard, rocker arm suspension is downright cool.
Daniel
Nick
It does improve the aerodynamics to some degree by cleaning things up and reducing drag. Maybe not by a huge amount but some and' date=' besides, inboard, rocker arm suspension is downright cool.[/quote']
If I understand it correctly, the primary advantage is that using the pushrod/rocker arm inboard set-up turns the standard widetrack's falling-rate suspension into a rising-rate suspension, which is good. Or so a suspension engineer has told me, anyway.
Sean - That was definitely achieved by the modification. But there were others. Below is a link to the original Multimatic project powerpoint (spelling mistakes and all!)
https://www.sevener.fr/fichiers_articles/caterhamsuspension.pdf
Coffee Break - you are right. There were a couple of things causing the decision to fall that way 1) It was easier to start with the SV chassis for packaging purposes while testing - the rear end takes up a lot of room 2) There was discussion about then engineering it for the regular chassis but it was cost prohibitive - it is quite an expensive chassis to build relative to the regular S3/SV since it still has to come from Arch and 3) I have heard it said that the original marketing plan for the CSR was to be a grand tourer and a range leading model that attracted a new segment of customers to Caterham looking for a more refined product - something that was partially achieved. There were at least 2 IRS cars built on the S3 chassis. I think one of those may have been a Caterham technician building his own personal car in his own time. They have come up for sale in the UK from time to time.
John - I found it when noodling for a new kit in 2009. It is hosted by a keen Caterham owner in France. Not sure where he found it from? The other information came from one of my discussions with Caterham senior management over the years.
